Free - Wheelin iPhone App
Discussion in 'Off-Roading & Trails' started by Box Rocket, Feb 3, 2012.
  1. Feb 3, 2012 at 4:05 PM
    Box Rocket
    Box Rocket [OP] Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    There are a lot of these out there, but I thought I'd share this one since it's free and has some cool features about it.
    This app is called "Wheelin" in the iPhone App Store. Lots of people will mount a Lev-O-Gage in their trucks so they can see how steep a climb or descent is or how far they are tipped off-camber. I ran across this app the other day and thought it was pretty cool for being free.
    Cool things that it does:
    You can use images of your own vehicle in the display which is a nice feature. You can see that I'm using my own truck in the captured images below. I did take them into Photoshop and cut out the background from the photos so they are just on a gray background.
    When you use it you put in into the mounting device in your car and stop on level ground. Once it's secured you touch the yellow "calibrate" buttons and they will zero out to level, then you're ready to roll........haha.
    There are two numbers for each display. The smaller top number displays the maximum angle you've been at and leaves a "ghosted" arrow at that angle. The larger lower number is the realtime feedback for your current angle. This arrow and number are constantly updated.
    You can set an alarm at whatever angle you want that will sound if you pitch your vehicle to or beyond that angle. Which is pretty cool since when you're on the trail and in a sketchy position you're probably not looking at your phone, but rather at your spotter.
    There is one big flaw with this app in my opinion. It only works in Landscape mode. I don't know about most of you but I have my phone mounted vertically in my car and this app only displays in a horizontal window so unfortunately it's tough for me to use unless I mount my phone differently. I'm trying to contact the developer to have it updated to support a vertical format also. Crossing my fingers.
    Anyway, just thought I'd share it here since some might find it useful.
  2. Feb 3, 2012 at 4:06 PM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    going to get this app.
  3. Feb 3, 2012 at 4:13 PM
    brett1586
    brett1586 Well-Known Member
    Brett
    Athens, Ohio
    Only issue is keeping your phone nice and level to the ground so it's accurate....
  4. Feb 3, 2012 at 4:25 PM
    Box Rocket
    Adam
    Syracuse, Utah
    No need to. Just park your truck on level ground and hit the "calibrate" buttons and it sets that at level regardless of if your phone is level.
  5. Feb 3, 2012 at 5:55 PM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    lol...i had a app similar too this but only had a jeep on it...this ones better cause i can use my taco...thanx for postin this buddy
  6. Feb 3, 2012 at 6:26 PM
    Hayes
    Hayes Well-Known Member
    Brandon
    Denver, CO
    2011 Regular Cab Tacoma 4x4
    Since you are only using it audibly, why not adjust your angles by 90 degrees and the alert will sound at your warning angle? Does that make sense?
  7. Feb 3, 2012 at 9:25 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    anyone find this for the android? i looked for a bit and nothing looked similar
  8. Feb 3, 2012 at 9:45 PM
    brett1586
    Brett
    Athens, Ohio
    Ahh well nevermind my ignorance haha...
  9. Feb 3, 2012 at 10:01 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    Nice. Thanks for the tip. Now I just have to make a swivel mounting bracket
  10. Feb 6, 2012 at 6:32 PM
    garcm329
    garcm329 Well-Known Member
    mario
    rancho cucamonga
    06 T4R
    Stock! For now!!
    Hahaha my friend and I just downloaded a similar app for the aneroid network on sat
  11. Feb 6, 2012 at 6:37 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    awesome just downloaded it
  12. Feb 6, 2012 at 6:38 PM
    BEEFY_CHEESY_TACO
    BEEFY_CHEESY_TACO DUDE MAN BRO
    Hot Carl!!!
    Roy UT
    2010 TRD-Off Road TACO Extra value package
    Icon Ext Travel w/ Resi Front and rear, Dakar leaf springs, total chaos UCA's, color matched rear bumper, color matched satoshi grille with black chrome TRD emblem, konig countersteer offroads (black) w/ 285/75 Duratracs, sockmonkey Trailiens 3rd tail light cover, Tacomaworld.com sticker (made by me), debadged all around, Relentless Front Bumper, Sliders, Rear bumper, and bed bars with Yakima rack w/ full size spare, shovel, hi-lift
    Great post! Thanks OP!
  13. Feb 6, 2012 at 6:50 PM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    What was it?
  14. Feb 7, 2012 at 3:58 PM
    garcm329
    mario
    rancho cucamonga
    06 T4R
    Stock! For now!!
    if you look up clinometer you should be able to find the same app for the android network
  15. Feb 9, 2012 at 9:54 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    Neat.
    Works in iPod touch with 4.2.2
  16. Feb 9, 2012 at 10:03 PM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    sub'd
  17. Feb 9, 2012 at 10:04 PM
    Jib Bandits
    Jib Bandits Pork eating crusader. An "infidel".
    Ari
    Cedar Fort, UT
    06 Access TRD Sport
    Red devil horn emblem, All-Pro Expo leafs, Fox shocks, K&N CAI, aFe throttle body spacer, Flowmaster american thunder dual exhuast, Defender roof rack, Hell Bent steel level kit, Rigid Dually LED lights, smoked halo headlights, smoked LED taillights, Cobra CB, red badge mod(+30 HP), Spider-Trax wheel spacers!
    Sweet! I'll have to check this out. on a side note... were you near bangerter and redwood the other day? I swear I saw a truck just like yours! except, I think it had a tiregate :(
  18. Feb 10, 2012 at 9:54 AM
    Box Rocket
    Adam
    Syracuse, Utah
    Nope wasn't me. There is a gold extra cab running around down in that area. Could have been him.
    Did it look like this guy? He doesn't always have the tent mounted.
  19. Feb 10, 2012 at 10:20 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    dear god those are some awesome trucks... i dont want to see the places they CANT go
  20. Feb 10, 2012 at 10:29 AM
    Hiemsnox
    Hiemsnox Well-Known Member
    Dan
    Beavercreek, OH
    06 DCSB TRD Offroad Indigo Ink
    downloaded
