Freedom Offroad lift problems pls help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by curtissp, Aug 11, 2018.
  1. Aug 11, 2018 at 7:45 PM
    curtissp
    curtissp [OP] Well-Known Member
    Installed the kit about 6 1/2 months ago.. For some reason I keep losing lift after it settles down this is the 3rd time I have raised and had a alignment done. Called the company they said its just the springs settling in.. 6 months and its still settling in???? I think its something more serious anyone else have any ideas???
    Anyone else have this problem??
  2. Aug 11, 2018 at 8:06 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Are these coilovers? Count the threads and make sure that doesn't change over time.
    Biscuits likes this.
  3. Aug 11, 2018 at 8:25 PM
    curtissp
    Yes adjusting coilovers with a locker on bottom. I can tell the threads never change due to the WD-40 wet spots. I keep cranking it up stays higher for about 4 days then I lose about 2" and I start rubbing on the tires.
  4. Aug 12, 2018 at 8:43 AM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Why the hell is there WD-40 on the threads to begin with? Sounds like that’s your problem to me.
  5. Aug 12, 2018 at 8:46 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    That is not a problem.
  6. Aug 12, 2018 at 9:36 AM
    curtissp
    Need to Lubricate it so you are able to crank it up otherwise you will strip the lockers.
  7. Aug 12, 2018 at 9:40 AM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    Any extra weight on the rig? Pics?
  8. Aug 12, 2018 at 10:07 AM
    SocalTaco15
    SocalTaco15 Well-Known Member
    Glen
    Socal, Orange County
    Set screws not fully engaged on the coil overs?
  9. Aug 12, 2018 at 12:33 PM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Who is the manufacturer of the coils themselves and what is the spring rate?
    Have you counted the individual threads on the coils when you adjusted them an compared that to the number of threads after the suspension sags?
    Do you have any pictures? Any before and after pictures?
    We'd love to help but we need more information! :)
    Juforrest likes this.
  10. Aug 12, 2018 at 1:40 PM
    curtissp
    No extra weight at all on them I dont tow anything with this truck.
    All the parts are Freedom Off Road. The UCAS,Coilovers, the spindle,The front and rear shocks. (The Rear is not the problem, it stays the same height)
    Everything is tight and measured! I will see if I can get some pics on here loaded.
  11. Aug 12, 2018 at 4:22 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Use a marker and mark where the adjusters are sitting,it it moves your set screw is not holding,if thats not the problem then your coilovers are bad.
