Freedom Offroad UCA
Discussion in 'Suspension' started by seniorredwood, Jan 3, 2018.
  1. Jan 24, 2023 at 5:40 PM
    #241
    Idaho_Taco89
    Idaho_Taco89 New Member
    Devon
    Cda, Id
    02 tacoma Base 2.7L 4x4
    Lift struts, blocks in rear, wheel spacers, 33x10.50r15's, Doug thorley tri y header & custom stainless tubing, custom cold air intake, trail gear winch bumper, smitty built custom rear bumper, AC Delete
    I'm running them as we speak. Have had no problems at all....just had a thrust alignment done 2 days ago and was almost dead center of spec on all tire angles.....been a while since I had all green in the print out after an alignment.
    Have checked 2 times since using these ball joints for approximately 3 weeks now and they are fully seated, no pinching of the boot, no over extension of the knuckle (positive camber), and there are no new marks on the springs contact so I'd say so far these are the ball joints that I'm sure we weren't supposed to find....lol....instead of buying "their" joints.....
  2. Jan 25, 2023 at 6:24 AM
    #242
    D2.
    D2. Well-Known Member
    Dan
    Nova Scotia, Canada
    2009 Tacoma - access cab 4x4 2TR-FE
    Cruise Control install. Intermittent wipers Hood lights Bed Lights Sliders 3" lift 886's on Billy 5100's Icon AAL 285/75 R16 Falken Wildpeak AT3W's
    Minty!
    thanks again, you did what I could not.
    If you don't mind me asking, how did you find the information on all the different ball joint sizes/measurements? That was my first thought on how to tackle this but my searches for that info came up blank
  3. Jan 25, 2023 at 3:24 PM
    #243
    Idaho_Taco89
    Devon
    Cda, Id
    Honestly, I burned alot of time and I'm sure there were easier ways, buy after I popped the original ball joint out, I grabbed the calipers and measured the obvious parts.....I started searching for ball joints that were press in with a 1.8 diameter, after wording it several ways I got Google to pop up a short list of moog joints and there specs....I found one that was real close....it was k6696, so I looked that up on the moog web sight. Found out thst they kind of cluster similar joints together, including by part number, so that helped narrow it down....so then I hopped on advanced auto parts web sight, tho not the best parts store, they give the most info in the description for their parts......when searching k6696, which by the way will also fit, but has less range of movement then 6694, it gave me a part interchange option. I clicked it and it brought me to k6694....same diameter, same length, and the correct ball stud taper....so grabbed the old joint, calipers, and cruised down to advanced auto and they let me measure away to my hearts content.....thats also when I discovered the difference in the range of motion between 6694 and 6696.........also found out that they weren't exclusively moog part numbers, that they were unique to that style of joint and that other companies made those same joints....the moog were around $45 each.......I ended up at oreilly auto with some from precision chassis for 25 each, fully serviceable brand new joints.....even had a guy that worked at our les schwab tire shop right down the info because he said they have actually turned down ball joint work on ppls rigs that had "unbranded" UCA's because they couldn't get parts...........I still visually check the joints everyday pretty much, just to satisfy my mind, and so far so good.....
    MY50cal likes this.
  4. Feb 15, 2023 at 6:25 PM
    #244
    junkyarddogg
    junkyarddogg Well-Known Member
    New Jersey
    2021 TRD Off Road
    Do these UCA's allow for increased caster? I'm currently on stock UCAs on a 2 inch lift with 285's. Are these good enough or do I need SPC's? I'm just worried about the bad ball joint issues.
  5. May 8, 2023 at 8:02 AM
    #245
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    bumpity. I need to replace the UCAs on my 07 after installing lift to correct the postive camber - how are these holding up for everyone? And did it correct the positive camber?
    Thanks
  6. May 12, 2023 at 6:42 AM
    #246
    TaylorTRD
    TaylorTRD Big ole log thumper
    Taylor
    Eastern Berks/Lehigh Valley PA
    14 Tacoma DCLB TRD Sport 4x4
    TRD catback exhaust, Volant CAI with Powercore filter, Meso Customs Red/White LED map lights, Sequential smoked 3rd brake light, Morimoto XB LED foglights
    Just got a set of these barely used off Extreme Terrain the other day for a steal, should have them in the mail today. Glad I found this thread about them and they seem to be of decent quality for their price. I wasn't trying to spend over $300 for a set of UCA's, that just sounds ridiculous to me. Now to start piecing together the rest of my suspension setup.
    MY50cal likes this.
  7. Jul 20, 2023 at 10:48 AM
    #247
    D2.
    Dan
    Nova Scotia, Canada
    Just got my Moog K6694's from Rock Auto today.
    hopefully I'll have them on the truck soon, Thanks again @Idaho_Taco89
    MY50cal likes this.
  8. Jul 22, 2023 at 11:32 PM
    #248
    guest_707
    guest_707 Well-Known Member
    I'm hoping someone can point me in the right direction. I was originally looking at the JBA upc for my truck. Turns out on their tire fitment list, the 255/85r16s I run won't clear without rubbing and I'd need over 4 inches of backspacing to clear the JBAs. I currently run oem wheels (specifically the bronze trail edition rims) and so I decided to look elsewhere. Anyone run these Freedom Offroad ones and have oem wheels with 255.85r16s? I do light off roading sometimes crawling over small-medium size rocks and frame twister type obstacles but mostly a daily driver and looking to improve freeway driving instead of the constant steering micro-corrections as if I was driving a Wrangler. Do these upcs have zerks for greasing up the joints like the JBAs do?
    Edit: These are the wheels I run
    https://parts.elmhursttoyota.com/p-...wheel-set-w-center-caps-tacobrnztrailwheelset
  9. Feb 10, 2024 at 2:51 PM
    #249
    Hector82
    Hector82 Member
    Hector
    TRD off 22
    I'm on the same task but I got the Wulf UCA the ball joint is a little different, smaller basically, on hat is 2.05 and 1.77 on the press side. K6694 and 96 are bigger . Can you tell if you find any PDF like chart where to star looking.
  10. Jun 24, 2024 at 8:07 AM
    #250
    Tecgeek13
    Tecgeek13 New Member
    Brian
    Hey just came across this thread, do any of you guys know if the bushing is oem size? I'd like to get some of these and put poly bushings in. Much appreciated!
  11. Jun 24, 2024 at 8:56 AM
    #251
    Hector82
    Hector82 Member
    Hector
    TRD off 22
    No idea
