Freedom Offroad UCA's causing camber issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by Zach95, Nov 15, 2020.
  1. Nov 15, 2020 at 8:34 AM
    Zach95
    Zach95 [OP] Active Member
    Zach
    CT
    2001 2.7l 4x4 5 Speed Single Cab
    Im running bilstein 5100's with a freedom offroad uca. Im using moog 81078 coils which should give around 1.5" +/- lift by themselves. I currently have the cam bolts maxed out and there is still visible positive camber. The passenger side of the truck has the coil seat at the bottom of the shock and the drivers side has the seat at the top adjustment. Switching from top to bottom seat I only lost about 1/2" of lift. I'm not sure where to go from here. I no longer have the stock ucas to compare. Does anyone have any similar experience with the FO UCA's.
    Sorry for blurry photos, my phone will no longer focus.
    driver
    passenger
  2. Nov 15, 2020 at 8:43 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Do you have the sides reversed?
    Wulf likes this.
  3. Nov 15, 2020 at 8:46 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Is the truck sitting on level ground? Looks like you have it up on jack stands.
  4. Nov 15, 2020 at 8:47 AM
    Zach95
    Zach
    CT
    I think they are on correctly, all the pictures i find have the short side of the uca on the rear side of the strut tower.
    tacotoe likes this.
  5. Nov 15, 2020 at 8:48 AM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    Drive the truck around the street and hit bumps really good to jounce the suspension, that should settle it a little.
  6. Nov 15, 2020 at 8:48 AM
    Zach95
    Zach
    CT
    Its on a fairly level part of my drive way. There is a stand underneath but its not supporting the truck.
    Hobbs likes this.
  7. Nov 15, 2020 at 11:02 AM
    Zach95
    Zach
    CT
    I set the shocks to lowest setting and it looks a little better after driving it. Driver side looks about straight, passenger side still has a little bit of camber. Ill have to get an alignment to see how bad it is.
    tacotoe and jjsul like this.
  8. Nov 30, 2020 at 7:02 AM
    tsab916
    tsab916 Well-Known Member
    Sacramento
    02 DC 4x4
    Any update on this? I'm considering buying a set of freedom offroad UCA's. Have you tried reaching out to FO?
  9. Dec 1, 2020 at 11:36 AM
    Zach95
    Zach
    CT
    I haven’t gotten the truck in for alignment. I’ve been busy with holiday travel and long hours at work. Hoping to get it in the shop next week, ill update once I get an alignment.
    DustyMcTaco likes this.
  10. Feb 3, 2021 at 1:56 PM
    Zach95
    Zach
    CT
    Sorry I kind of forgot about this thread but here's the results. They didn't even attempt to touch the camber because I have the cam bolts maxed. Took it wheeling last weekend going in for another alignment at the end of the week with new wheels and tires.
    the 1.9 camber is hardly noticeable and I plan on having a set of tall skinny highway tires for riding north so, they will be rotated fairly often. Definitely asking for some toe in because you have to fight her at 65+ on the interstate.
  11. Feb 3, 2021 at 6:08 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    New wheels and tires won’t do anything to your alignment.
    I’ve actually never heard of that brand, but they look like another total chaos lookalike.
    And what’s the deal with those cam bolts, those arent stock.
    Running Board Man likes this.
  12. Feb 3, 2021 at 6:26 PM
    Zach95
    Zach
    CT
    I had to cut the originals out. Truck basically has a new front end except for cv axles and bearings. They are designed so you can install them either way, so you don't have to remove the steering rack to remove the LCA. I installed them the same way as stock because I didn't want to cut them to clear my steering rack boots. The plates are the same size as stock so I don't think these are causing the issue. Either way I don't think I can do much without opening the slot the cam bolt rides in or bending the steering knuckle. I'm also considering adding another .5" of lift to clear the body a little more but its going to affect my camber. Town Fair Tire I get 90 days free alignments so.
    jbrandt[QUOTED] likes this.
  13. Feb 3, 2021 at 6:43 PM
    crazytacoman
    crazytacoman Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    That's a lot of rust! Have you had your frame inspected for any problem rust?
  14. Feb 3, 2021 at 6:43 PM
    mlcc
    Oregon
    What ever you do dont get another alignment from those guys go to a real shop.
  15. Feb 3, 2021 at 6:52 PM
    Zach95
    Zach
    CT
    There's a soft spot on both sides where the sway bar mounts are. Going to patch them next summer, it's nothing dangerous at this point. Maybe 3-4 inches long on the bottom of the frame, walls are solid. Kinda funny the frame and cab aren't terrible on this truck considering it spent it's whole life in Mass. Bed is gone and is either getting replaced or flatbed. I replaced almost all the hardware. Brand new front end except cv axles and rear end has been replaced down to the backing plates for the brakes.
  16. Feb 4, 2021 at 8:52 AM
    jbrandt
    Justin
    You kinda have two possibilities as I see it.
    Either:
    1) the UCAs you have are not built correctly to correct for the camber of the lift (they certainly appear installed correctly, but I've honestly never heard of that brand), or
    2) all that rust has done something fierce to your frame, and everything is, to use a technical term, cattywompus.
    I would figure out a way to measure that frame, and ensure all the control arm mounts are were they are supposed to be, relative to each other...
    Another (slim) possibility is that your LCAs are damaged or bent. That should be pretty obvious however.
    You've clearly put a lot of work into this frame already, so it'd be a shame for it to all be for naught. But better to find out now, than even later in the process.
    Get your alignment figured out before you get new tires, or you'll just eat up those new tires.
  17. Feb 4, 2021 at 9:23 AM
    Zach95
    Zach
    CT
    Not sure. The UCA’s are suppose to correct the loss of caster from the lift. I’m definitely going to bring the truck to a different shop for a second opinion. I got a free alignment when I bought the tires. I work with some people who also have their hands in the auto industry. I’m sure one of them can recommend a good shop for an alignment on a lifted vehicle.
  18. Feb 4, 2021 at 12:11 PM
    mlcc
    Oregon
    Because all the shop did was set toe and didnt even bother to do a caster sweep to see what the measurement was pure laziness.
  19. Feb 4, 2021 at 1:51 PM
    Zach95
    Zach
    CT
    So maybe the caster is to low and thats why its all over the road at highway speed. Hard telling not knowing.
  20. Jun 18, 2021 at 3:35 PM
    KrzyKjun512
    KrzyKjun512 Well-Known Member
    Chad
    2000 TRD, Original Rust-Free
    I just went through what is exacly happening to you. My left was 2 degrees positive as well. Called Freedom and their UCAs only reposition the ball joint. They dont claim to adjust for Camber. It was an oversight on my part I assumed they were all the same. Lessoned learned.
    RealLeisure and tacotoe like this.
