Freezing because I have no heat.
Discussion in 'Technical Chat' started by chasebrooks14, Dec 26, 2013.
  1. Dec 26, 2013 at 1:47 PM
    chasebrooks14
    chasebrooks14 [OP] Well-Known Member
    Chase
    Dahlonega, Georgia
    2008 Acura TSX (RIP LaToya)
    Mickey Thompson Classic iii, Green LED interior floor lights, After market Kenwood touch screen radio, 20% window tint, Blacked out bumpers and grill, blacked out tail lights, Pioneer door speakers, bed lined toolbox, LED tailgate light bar w/ reverse lights, Bilstein 5100 all 4 corners and top setting up front, Trd Coils, New 1.5" lift leaf pack and shackles, White gages with blue needles. 32x11.5 Cooper STTs, 1.25" Spidertrax spacers
    I guess my truck decided that winter was a great time to make the heat not work. My cold a/c works just fine but when turned all the way on hot, it only gets luke warm. anyone know where to start on this problem?
  2. Dec 26, 2013 at 1:49 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    thermostat would be my 1st suggestion
  3. Dec 26, 2013 at 1:51 PM
    medic2230
    Murph
    Bama! Roll Tide
    The cable that runs to the valve under the hood that directs the water to the heater exchanger. Make sure the cable is working.
  4. Dec 26, 2013 at 1:52 PM
    seanboy
    seanboy Well-Known Member
    '13 TRD Sport
    Check coolant level, along with the others mentioned above.
  5. Dec 26, 2013 at 7:24 PM
    chasebrooks14
    Chase
    Dahlonega, Georgia
    thanks!
    will do!
    thanks guys!
  6. Dec 27, 2013 at 11:32 AM
    03is300ztk
    03is300ztk Well-Known Member
    Zach
    Somewhere in the hills NC
    07 Tacoma 4X4
    Grillcraft, with front and rear bumper/bed in the works.
    Ummm heater core if the valve is opening.
  7. Jan 5, 2014 at 11:37 AM
    chasebrooks14
    Chase
    Dahlonega, Georgia
    I might have to add in that my temp needle in the dash works fine. it warms up just fine and always works properly.
  8. Jan 5, 2014 at 11:40 AM
    03is300ztk
    Zach
    07 Tacoma 4X4
    Sounds like heater core problrms
  9. Jan 5, 2014 at 11:51 AM
    chasebrooks14
    Chase
    Dahlonega, Georgia
    so im checking the temp of all the hoses for the heat, and theyre all hot and seem to be working just fine. the cable works and everything. if it is the heater core, is that hard to replace?
  10. Jan 5, 2014 at 12:03 PM
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    Heater cores only go bad if they're leaking or plugged and not letting fluid through.
  11. Jan 5, 2014 at 12:05 PM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    If the hoses going in and out of the heater core are hot then the heater core is likely fine. You say it only makes warm air so the next place to look is the flap in the duct work that the temperture control cable is connected to. That flap changes where the air is coming from and if it is broken or stuck then it will not allow the air to be drawn through the heater core and you won't get hot air.
  12. Jan 6, 2014 at 8:47 PM
    chasebrooks14
    Chase
    Dahlonega, Georgia
    thanks guys! ill let yall know if I have anymore questions
  13. Jan 27, 2014 at 10:18 AM
    617mike9c1
    617mike9c1 Well-Known Member
    Newton, MA
    2008 DCLB Sport 4wd
    A little of this and a little of that
    Sounds exactly like what my 08 is dealing with right now. My rig is at the one of the more reputable dealer around here (if there was such a thing) and the service manager said this will be around $1200. FML
  14. Jan 28, 2014 at 2:22 PM
    617mike9c1
    Newton, MA
    2008 DCLB Sport 4wd
    Glad I found the letter for my Toyota extended warranty yesterday!!! Just saved me $1200 that they were going to charge! Now, that $$ can be put into a OME kit for the Spring. :D
  15. Jan 28, 2014 at 4:30 PM
    L J
    Illinois
    I have never needed to show proof of my warranty. They just enter my VIN and it comes up. It just ran out so now it's on me. What did they find wrong that cost $1200 to fix?
  16. Jan 29, 2014 at 11:28 AM
    617mike9c1
    Newton, MA
    2008 DCLB Sport 4wd
    I just bought my used 08 about 4 weeks ago and when I went to different dealer, they entered my VIN into their system but nothing popped up in terms of warranty info. Damn! So I thought I was on the hook for the entire bill. This was for T-SB-0072-09... the HVAC Vent issue. I wasn't getting sh!t for heat through the vents unless I drive 15 minutes and then crank the fan speed up to setting # 4 to feel the slightest warmth from the vents.
    The $1200 was (supposedly) mainly for the labor of tearing into the dash to swap out the flapper door. Funny thing is after reading more about this T-SB, I recall reading that the job was supposed to be 4.7 hours of labor so I'm not sure how he got 1200 from 4.7 hours plus a small part. After bringing in my warranty card to the dealer and watching the service guy call Corp Toyota to file a claim, I noticed that the service rep jotted down 4.7 hours on my service sheet. So be wary of how much they will charge you for this service. It shoudn't be 1200 when it is all said and done in my opinion.
