Freezing washer jets?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 309, Oct 25, 2020.
  1. Oct 25, 2020 at 4:39 PM
    309 [OP] Active Member
    2020 Black TRD Offroad Premium DCLB
    Today I had the privilege of driving my new 2020 Taco in the snow for the first time. Living in Colorado, this is one of the reasons I drive a 4wd truck.
    Took my kid to dance practice about 45 minutes away. During that drive the drivers side washer jet didn’t work. Not a big deal as the roads weren’t too bad yet. I knocked some ice off and poked the jet with a pen tip. Took a sec but then it was working again.
    The drive home was longer with rapidly diminishing road conditions. No ice had built up in the meantime so I gave the washers no thought and got on the freeway. Neither jet worked at all! There was no ice or other blockage visible from the cab. I managed to make it home without having to stop and fix it. I’m going to figure it out tomorrow (fuggin cold out now).
    Anybody have a clue what’s up though? I’ve had washer jets blocked by ice before but no vehicle I’ve ever had had the washers just stop working. Is there something stupid about the jets or does Toyota use freezing washer fluid? I thought all washer fluid had anti freeze properties to it?
  2. Oct 25, 2020 at 4:40 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Some washer fluid is rated to a lower temp then others. I'd start by buying new fluid and go from there.
  3. Oct 25, 2020 at 5:11 PM
    taco pops
    taco pops Well-Known Member
    Russ
    West Michigan
    2016 black SR5 Tacoma DCSB
    Side Steps, Tonneau cover
    If that happens again pour room temp water on the jet which doesn't work and try them again. Sometimes water from melted snow will plug up the nozzles
    Skydvrr and BSFord like this.
  4. Oct 25, 2020 at 5:53 PM
    NukedTaco
    NukedTaco Well-Known Member
    Wyatt
    Saratoga Springs, NY
    Only certain washer fluid won’t freeze. Your lines are probably just frozen from the factory fluid.
    wilcam47, SR-71A, Chew and 1 other person like this.
  5. Oct 25, 2020 at 5:59 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    No. In my area, they sell "summer" washer fluid that freezes at 32F, and "winter" washer fluid that freezes at -30 to -40F depending on brand, just varying percentages of alcohol content. "Summer" fluid is a bit cheaper and is advertised to clean bug splatter better (though I haven't noticed a difference). Not sure what the factory fill is, and it may be different from the Toyota-branded washer fluid at the dealer parts counter.
    SR-71A and Tullie D like this.
  6. Oct 25, 2020 at 6:56 PM
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    I always use 20/20. Never had a problem even below 0.
  7. Oct 25, 2020 at 7:29 PM
    Tripod1404
    Tripod1404 Annihilator tripod
    You are new to a location with below freezing temperatures?
    You need winter washer fluid blend that doesn’t freeze.
  8. Oct 25, 2020 at 7:37 PM
    I’m not new to the area. It’s a new truck. Purchased here in CO. It does seem likely that it’s the fluid freezing. I was just caught off guard as that’s never happened to me before and I’ve been doing this stuff for a long time.
    I’ll try a different fluid tomorrow. High is supposed to be about 15. Should make for a good test.
  9. Oct 25, 2020 at 7:39 PM
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    Up in :canada:we use -40°C windshield washer fluids. Some use summer fluid that works better for bugs and stuff like that. Myself I'm using year round the super cold kind so the lines and pump don't freeze.
    gudujarlson, Riderfan, vicali and 5 others like this.
  10. Oct 25, 2020 at 7:44 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    I'd try blowing back from the jets to the reservoir, being careful not to blow out the pump. Could be a small piece of something that snuck into the reservoir when refilled. I'd also empty the reservoir and screen the contents thru a filter just for ha-ha's. If there's any kind of crud in there, I'd bust the dealer's stones. Rinse thoroughly and refill with a lower freezing point.
    DAS Taco likes this.
  11. Oct 25, 2020 at 7:49 PM
    Tripod1404
    Fluid in the tubes leading to the jets freeze before the fluid in the reservoir, and if it already frozen, adding winter washer fluid won’t melt the already frozen fluid inside the tubes and nets. If you idle the engine for 15mins after it heats up, heat from the engine will most likely thaw the tubes.
    or park inside a heated garage for half an hour or so.
    Snowater likes this.
  12. Oct 25, 2020 at 7:54 PM
    Snowater
    Snowater Well-Known Member
    Pete
    GJ Colorado
    2000 Tacoma sr5 V6 5 speed ( silver queen)
    Dealer probably topped off fluid with water or used summer blend 32 degree washer fluid. Happened 2 times to coworker's of mine.
    First was a new CRV serviced in Denver at a Honda dealer. First 0 degree day (yes they can happen in October at 9000') washer fluid tank froze and cracked. Dealer replaced at their cost, still cost him time. Another coworker moved from Florida and her car had same summer fluid, we were able to thaw it with heat lamp and -20 winter fluid.
    I always look at what temp washer fluid is rated at after this.
    Regardless is your still seeing this thread tonight run the windshield washer sprayer until empty refill with -20 fluid tomorrow
  13. Oct 25, 2020 at 8:59 PM
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    I always just add the left over popov vodka to the reservoir and it keeps it liquid. It also smells like vodka when u clean up the windshield so you can always blame the “alcohol smell” on your truck when u get pulled over .
    JagoTaco and Junkhead like this.
  14. Oct 26, 2020 at 4:51 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Haha it'll work!
    I had an Eagle Talon back in the day, the damn door locks were always frozen! I was a bartender, so I'd bring a bottle of rail vodka out, worked every time. Probably should have looked for fix, but what 20 something year old has time for that?
  15. Oct 26, 2020 at 5:12 AM
    You Suck I Suck More
    You Suck I Suck More Well-Known Member
    Meatloaf
    North Florida
    2017 Super White DCSB TRD OR
    Your parents' favorite Airman
    Definitely frozen tubes. Every year, when I was stationed in a cold climate, I would have to educate my new troops coming from warmer climates about making sure their vehicles were winterized. It never failed that one of them wouldn't listen and I'd get a call "Sarnt I can't get the ice off my windshield" or "man that drive was crazy. I was basically blind because nothing was coming out of the windshield sprayer."
    The tubes freeze faster than the reservoir, keep that in mind as well.
    Boghog1 likes this.
  16. Oct 26, 2020 at 5:27 AM
    gearcruncher
    Canadain bumper technician
    Up in the great white north , you gotta make sure youve got that summer stuff out of the resevoir before it gets too cold or your resevoir will crack in half from ice expansion .
    Boghog1 and vicali like this.
  17. Oct 26, 2020 at 6:28 AM
    DAS Taco
    DAS
    2017 TRD Offroad
    Couple of years ago I helped somebody get into their car by dipping their key into a big blob of hand sanitizer (we always keep that in our vehicles)...they washed their car the night before.
    Boghog1 and Chew[QUOTED] like this.
  18. Oct 26, 2020 at 6:37 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    wind chill factor
    look at the graph for outside temp....... then speed o vehicle
    windshield fluid is sold with anti freee solutions of various type
    some are not good as they dont freeze yet they dont clean salt/muck off the windshield
    in VA it gets cold yet not like the midwest or mountains
    i use WINDEX...........straight Windex
    hasnt let me down yet
    wilcam47 likes this.
  19. Oct 26, 2020 at 8:20 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    Windex contains water with nothing to keep it from freezing. The MSDS states that it will freeze at 32 degrees Fahrenheit.
    Also, original Windex contains Ammonia, which will dry out and ruin any rubber components it comes in contact with, like the windshield washer hoses, the rubber trim around your windshield, and possibly the windshield wipers. They do make an ammonia free version.
    Chew likes this.
  20. Oct 26, 2020 at 8:34 AM
    eurowner
    eurowner Duke Sky
    Scoty
    I live at 7000' in south-central Colorado, use orange RainX 2-in-1 De-icer with bug remover fluid all year, on numerous vehicles, for over 20 years, and never had the washer bottle to sprayers freeze up.
