Fresh air fan clicking when orange light is off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rphillips, Dec 4, 2023.
  1. Dec 4, 2023 at 8:46 AM
    rphillips
    rphillips [OP] Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Seems real odd. When recirculating air light is on all good, when that light is off, constant loud clicking sound. Sometimes light is off when I start the eng., though I know it was on and no clicking when I parked the truck, and clicking starts as soon as eng starts, push button to turn light on and clicking stops. Other days light is on at start up and stays on constantly, no clicking, can go a few days before light goes off and clicking starts again. Some days the truck turns that light off by itself, I'll push the button to turn light on, clicking will stop then a few minutes later the light will go off and clicking starts again, I'll punch the button, turn light on and clicking stops... What the heck is happening? why does, some days, that light go off without me punching the button, why won't it stay on when I turn it on? and what the heck is that clicking when the little orange light is off????? So aggravating
  2. Dec 4, 2023 at 8:57 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    TnShooter likes this.
  3. Dec 5, 2023 at 11:42 AM
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    OK, thanks for that, it does kind'f sound like maybe gears slipping while trying to move something. Why does sometimes the Taco turns from fresh to re-cir by itself and other days it stays the same all day. Not sure which way the orange light means, but some days the orange light stays on constantly, while other days, as today, appx. every 5 min. the light will automatically go off & clicking will start. I push button to turn light back on & clicking stops. Another 5 min. the orange light automatically goes off again and clicking re starts, over & over & over. Why so different on some days than others? I've tried it on A/C, Heat, Def., it does the same on all settings.
  4. Dec 5, 2023 at 11:52 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Certain years had a "feature" that it would change the recirc setting based on ambient temperature, it will also be forced on when the temp knob is set to max A/C and forced off if the mode selector is on defrost or defrost/foot unless you have done the relevant mods to disable that.
    Light on is recirculate, light off is fresh air.
    The recirculate actuator itself is nothing more than a motor and some gears, no feedback at all. The A/C Amplifier supplies power and ground to it at all times when the key is on and just reverses the polarity to change the direction it moves, a broken tooth at one end or the other will cause it to ratchet or click constantly whenever it is in that position.
  5. Dec 5, 2023 at 12:04 PM
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    OK Thanks, Any idea of how expensive should I expect to have fixed?.. Not at a dealer !!!
  6. Dec 5, 2023 at 12:10 PM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    My work around was to let it close and then unplug the motor...It's quick little clip on the left side of the actuator behind the glove box...That means it's always on "outside air"
  7. Dec 5, 2023 at 12:28 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Whatever the cost of the part is and maybe a half hour labor, you should be able to do it yourself. I can't remember for sure but I think the screws are 5.5mm, it's right behind the glovebox.
  8. Dec 14, 2023 at 2:16 PM
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Dang-it, I messed up. Ordered blend door actuator motor (Dorman # 604-332). Got glove box out, saw the motor, got the screws out and motor off, just to check, pushed the REC button and shoot, still clicking with motor out in hand. I'd took off the wrong motor, this motor faces the middle of the truck, slides on a shaft coming from the center of the truck. Looking farther I found the motor on the rec. air, it is up higher, lot harder to get to, facing the opposite direction, it goes on something coming from the right side of the truck, pointing toward the center. I can't get to those screws with tools I have, going to buy a finger ratchet, think maybe then I can reach up in there with that... Question, are both of these motors the same, just flip it the other way and slide it on a shaft? or does the one I need have a little lever or gear as I've seen on some others I've looked at... Read on another thread, here at TW, either a Dorman #604-109, a Delco # 15-73513, or a Toyota # 52494371 is what I need, but when look up and see them, they look "exactly" like what I have now, a Dorman #604-332 . I guess I can wait to see if I can get it off, but would rather know, ahead of time, what little actuator motor I will need. Any help appreciated.
  9. Dec 14, 2023 at 8:21 PM
    lr172
    lr172 Well-Known Member
    ‘11 DCLB 4.0 Auto
    Usually if they have different part numbers, something is different. Sometimes it is as simple as the angle or clocking of the attach bracket, bit something makes it unique. Most any manufacturer would rather reuse parts when they can
  10. Dec 16, 2023 at 8:26 PM
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Well, thanks but it seems it isn't going to matter. I've spent several hrs. and so far I can't get my big stiff hand and the 1/4" dr. ratchet, nor my finger ratchet in there to get that top rear screw out. Seems I need to find a mechanic with smaller, more flexible hands for this job... I've thought about post # 6, TreeFortRichard said let the flap close then unplug the wire, outside air will be on all the time. (I'd have thought with the flap closed the outside air would be "off" all the time).. Would there be any "NOTICEABLE" drawbacks if I did that?
