Fridge Noises
Discussion in '3rd Gen. Tacomas (2016-2023)' started by I_squared_r, Dec 21, 2021.
  1. Dec 21, 2021 at 3:05 PM
    I_squared_r
    I_squared_r [OP] Well-Known Member
    NYC/Colombia
    2020 Black Tacoma OR DCSB 4x4
    I bought a Iceco JP40 and I put it behind my back seat. I started to hear a bad sound like a bad strut or somebody hitting the bottom of my truck with a hammer. I went to investigate and found the fridge sounds like a large metal ball is loose inside. I took off the cover of the fridge and traced the sound to the compressor, like the pump is loose inside. I contacted Iceco and had them warranty it, but the new fridge has the same sound! The fridge works fine, but I was hoping for a relatively quiet fridge. Now i'm thinking about getting a ARB or Dometic instead! Do all fridges make this noise??
  2. Dec 21, 2021 at 5:19 PM
    Hafaday
    Hafaday Well-Known Member
    Bill
    Richmond, VA.
    19, DCSB, Off Road. 23 KLX300, 14JKU
    That's weird on both of them doing the same thing. Not faulting the brand either. that said, and not trying to sway you at all because these things are pricy.. I can hardly hear my ARB. Doesn't mean that one day it will take a dump.
  3. Dec 21, 2021 at 5:34 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Lured by title. Disappoint
    t2c, wilcam47, philth and 2 others like this.
  4. Dec 21, 2021 at 6:55 PM
    tacoshell88
    tacoshell88 Not that well known member
    Michelle
    Somewhere along the Mexican border
    2021 DC Cement TRDOF
    That’s how you know your refrigerator is running
    philth likes this.
  5. Dec 21, 2021 at 7:35 PM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    Is your fridge running?
    Better go catch it!
    SR-71A, philth, vivid02 and 1 other person like this.
  6. Dec 21, 2021 at 7:38 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Is the fridge level?
    Kahpo and TacoRated like this.
  7. Dec 21, 2021 at 7:39 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Try a tie wrap on one of the compressor mounts. If the sound is simply the motor than that’s it. If it is a vibration you may be able to minimize it. It’s likely innate.
  8. Dec 22, 2021 at 5:42 AM
    I_squared_r
    NYC/Colombia
    I'll try to explain better. If I were to remove the compressor, and give it a light shake, the pump will bounce against the side. And this noise is very loud inside the cab. It's at the same decibel of talking level.
    The local REI has a dometic fridge. Too large for my use, but i'll go see if it makes the same sound
  9. Dec 22, 2021 at 5:53 AM
    I_squared_r
    NYC/Colombia
    Yeah, Iceco sources the compressor from Secop so they are at the mercy of what they send. I think ARB uses a Secop compressor also. If you were to give the fridge a shake, does it make a knocking sound?
  10. Dec 22, 2021 at 5:54 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I assume the compressor is rubber mounted? Maybe experiment with higher / lower durometer isolation feet.
  11. Dec 22, 2021 at 6:46 AM
    codyjphoto
    codyjphoto Well-Known Member
    Cody
    2015 gx460
    A bunch of junk
    My vl45 does the same thing. I consider it to be a small price to pay for cold beer on demand.
    I_squared_r[OP] likes this.
  12. Dec 22, 2021 at 6:58 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I can tell you my amana refrigerator in my home will make's alot of fart, and popping noises all day at different times. It can sound like someone firing a .22 short in the house. Otherwise all is normal...food is kept cold and the freezer keeps stuff frozen.
  13. Dec 22, 2021 at 9:00 AM
    Hafaday
    Bill
    Richmond, VA.
    Rite rite. I’ve never heard a sound out of it that I recall, even off road. Will check after work and give it a shake. Will have to remove the beers first. Currently being used as a beer cooler.
  14. Dec 22, 2021 at 9:06 AM
    I_squared_r
    NYC/Colombia
    Then probably the sound is specific to Iceco. Thanks for the help! I definitely will buy a different fridge if it doesn't have this sound. I'm stubborn about having the cab relatively quiet. The sound of something rolling around the back seat or knocking is enough to bother me.
    Which means, I have a new Iceco JP40 for sale for anyone who doesn't care about these type of noises lol
    Hafaday[QUOTED] likes this.
  15. Dec 22, 2021 at 9:11 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
  16. Dec 22, 2021 at 9:12 AM
    Hafaday
    Bill
    Richmond, VA.
    Gotcha. Check around with all the web sites that you can think of that sell the fridge you want, to see if you can find some kinda sale. That is exactly how I fell into my ARB after drooling over them for years. I Got that puppy at $250. off the list price.
  17. Dec 22, 2021 at 4:12 PM
    Hafaday
    Bill
    Richmond, VA.
    @I_squared_r it's running at a cool 38 degrees and not a sound out of it while shaking or on any kind of angle at all. Also been running non stop for a good 8-10 months.
  18. Dec 23, 2021 at 6:29 AM
    I_squared_r
    NYC/Colombia
    Thanks for taking the time to see. Looks like I will be saving for a quieter fridge.
  19. Jan 10, 2023 at 3:20 PM
    mrmcbark
    mrmcbark New Member
    2022 GX460
    Registered here just reply to this thread – same issue with my Iceco JP40 in my GX460. This has been driving me nuts. At first I thought it was the basket inside the fridge, so I removed that. Then I thought it was the few millimeters of play in the Iceco slide, so I removed the fridge and drove around with the empty slide, no more rattle. So I shook the fridge around and mother-F if the thing doesn't clunk around like it's got a coconut inside. Was thinking about opening it up seeing what's up but sounds like you did the work for me and it's the compressor. Kind of a bummer as it was a large investment.
  20. Jan 10, 2023 at 3:47 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    My two ARB fridges both have the clunking sound you're describing. I'm fairly certain all fridge compressors do.
    I've only noticed it in my ARB's when carrying them and they "bounce" against my hip. It's exactly what you're describing.
    I've also noticed it in full size and mini fridges.
