Fried cat's
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rashnu, Dec 3, 2010.
  1. Dec 3, 2010 at 10:13 AM
    Rashnu
    Rashnu [OP] Well-Known Member
    '16 T4R TEP
    Stock
    So my bro's truck failed smog check the other day. The tech told him that both of his cats were fried. Any suggestions on what to check first that would cause this? Excessive fuel dump maybe? Bad injectors?
  2. Dec 3, 2010 at 10:15 AM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    lol i thought you meant like a literal fried cat ha ha once a cat is messed up about your only choice is to replace it
  3. Dec 3, 2010 at 10:16 AM
    Chachie
    Chachie Well-Known Member
    Justin
    Nor Cal
    '06 TRD OR, 4x4, Auto, 6" Fabtech, 35's
    Locker mod, Anytime fog mod, always 400w mod.
    Im just going to leave this here...
  4. Dec 3, 2010 at 10:18 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    What truck is it? How many miles?
  5. Dec 3, 2010 at 10:23 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Damn, I thought this was going to be a chinese food thread...
  6. Dec 3, 2010 at 1:25 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
  7. Dec 3, 2010 at 2:32 PM
    Whitfield
    Whitfield Well-Known Member
    Central Virginia
    99 TRD X-cab on 35's / 96 X-cab on 33's
    Selling my 96 Tacoma to fund the FJ80 build up.
    Sounds like a fuel rich condition ~ What kind of drivability isues?
    Check engine should be lit up. If not verify it works. Does the computer go into closed loop. You are gonna need an OBDII scanner.
  8. Dec 4, 2010 at 10:31 AM
    Rashnu
    '16 T4R TEP
    Stock
    It is a 2002 off road access cab. I think it has around 120,000 miles on it. The check engine light is on. There are no driveability issues. It still runs like a champ. We just swapped out the rear cat, but doesn't make a difference until we figure out why the originals went bad.
  9. Dec 4, 2010 at 10:34 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i can tell ya this.....if its still running strong.....you aint got bad cats. when a cat goes bad...they'll clog up and the truck will feel like its dying when you try to get up to speed. get the codes read somewhere like autozone. im betting on it being an 02 sensor......and they failed inspection cause of the cel.
  10. Dec 4, 2010 at 11:38 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    I would agree. If the CATS are fried at 120,000.......it is because they are expensive and the mechanic is seeing $$$$$$$.
    If it is running fine, and throwing a CEL, then O2 sensor is my bet too.
