Frightening Steering
Discussion in 'New Members' started by Bsander118, May 24, 2017.
  1. May 24, 2017 at 11:26 AM
    Bsander118
    Bsander118 [OP] New Member
    Benjamin
    2005 Blue Toyota Tacoma TRD OFF ROAD
    Hey y'all! Brand new to the tacoma world and I wanted to ask if something was normal for Tacoma's or if theres a problem with mine. The steering is crazy sensitive. The truck will pull left or right if the road is slanted, but drives perfectly straight on flat. Low speeds its no problem, but if I hit a pot hole at 70, the steering sometimes jumps one way if I'm not white knuckling it. Is this normal for Tacoma's or is it a problem/the specific set-up on the truck?
    Update: unfortunately I don't know much about the truck. I know the tires are not stock, I don't think it is lifted, but it has some yellow struts in front that do not look stock. It has been in a rollover, but it was completely repaired and the alignment was "checked" although I have trust issues with mechanics when Im not sure what they are actually doing.
  2. May 24, 2017 at 11:31 AM
    Bman4X5
    Bman4X5 There is no substitute for square inches.
    Bruce
    Upland CA
    '15 AC/OR
    Bilstein, Dakar/Icon, Prinsu, CBI, Pelfreybilt, Tepui
    We could use some more information:
    Do you have a lift?
    Has your truck been aligned?
    The problem you describe is known as 'bump steer', and is commonly the result of inadequate camber settings at the front wheels, and can be made worse by lifting the front, which necessitates higher-than-spec camber settings.
    Bsander118[OP] likes this.
  3. May 24, 2017 at 12:08 PM
    Bman4X5
    Bruce
    Upland CA
    '15 AC/OR
    Have your alignment checked again. If you are not lifted, you want your camber to be around 2 degrees. This is a safety issue, and needs to be addressed ASAP.
  4. May 24, 2017 at 12:10 PM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    How old are you shocks? Just swapped mine and got a alignment, totally different ride now.
  5. May 25, 2017 at 9:00 AM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    Welcome!
