From 18's to 20's. Whatcha think?
Discussion in 'Street Trucks' started by ryanjboutin, Sep 2, 2012.
  1. Sep 5, 2012 at 6:35 PM
    ryanjboutin
    ryanjboutin [OP] Weapons grade dickhead.
    Las Vegas
    2013 4x4 TRD OR
    Mid travel, 33's, typical shit.
    I need them.
    If I go any wider the rear tires will be outside of the bedside.
    I already had to trim the underside of the flares so they won't rub.
  2. Sep 5, 2012 at 6:39 PM
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    Pasadena CA
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit Xscorpion dual 0g wire ring terminal (3) Big 3 upgrade (0g wiring) HID kit (headlights - 3k) HID kit (fog light 3k) Bullz Audio 0g wire Exterior: Blacked out OEM headlight housing Front grille swap (to chrome, painted bed liner) XR front bumper valance (dipped red) Aftermarket fog light kit w/OEM switch Rear bumper swap (to chrome) 99 Cents Store tailgate lock Suspension: DJM 3/4" drop kit 1" spindle spacer kit (Addional nuts and longer bolts added) 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs Rims: 18x9.5 Asuka ST 15-2 rims et26 all around 1" billet aluminum wheel spacers 225/40/18 tires all around Neochrome lock nuts Pepboys valve stem caps Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Pioneer DEH 5000ub Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" JBL GTO 1014 (2) 4 ohm svc in dual ported box JDM Fuchsia shift knob (old Dickies pants shift boot)
    they just look gwak on a lowered taco. having them blend in seamlessly would be cool. Like they weren't there but are.
  3. Sep 20, 2012 at 5:03 PM
    NoelsMyKuya
    NoelsMyKuya Well-Known Member
    Aaron
    San Deezy
    05 Access Cab sr5
    I thought of going flares before, but i think it takes away the clean body lines of the truck. If you're worried about going wider or rubbing, just rent out an Eastwood feder roller and pull it out a little.
    You pick up the wheels yet? Are you going full reverse lip or step?
  4. Sep 20, 2012 at 6:11 PM
    113tac
    113tac Well-Known Member
    Stephen
    va
    05 4 banger
    tint 35/20 colormatched (by me) grill.
    those look sick! the only thing about that style is that they are a bitch to clean haha
  5. Sep 20, 2012 at 7:28 PM
    07TacoRidah
    Pasadena CA
    Wire wheels are a million times worse lol
  6. Sep 20, 2012 at 7:30 PM
    113tac
    Stephen
    va
    05 4 banger
    haha true
  7. Sep 20, 2012 at 7:32 PM
    scocar
    scocar being weird again....still
    Gunter Von Glitterschnitzel
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Back to square one after the 2001. So...
    I never noticed until now, and all you guys are saying flush fenders, but the lines in that pshop actually are reminiscent of late 40s early 50s lines on American sedans/coupes. Intriguing...
  8. Sep 20, 2012 at 8:14 PM
    07TacoRidah
    Pasadena CA
    Dodge Dakotas and the Rams are like that too. Although the body lines are there naturally and they basically give it a "modern" style look to the 40/50's style, imo adding in the fender flares just over exaggerates the body lines.
  9. Sep 20, 2012 at 8:30 PM
    scocar
    2015 DCLB 4x4 SR5
    Ah, flares versus just fenders. Gotcha.
  10. Sep 20, 2012 at 9:58 PM
    ryanjboutin
    Las Vegas
    2013 4x4 TRD OR
    I tried a fender roller last year.
    In order to roll bedsides on ours, you have to remove the center bracket over the rear tires. That caused the bedside to wrinkle as it was being rolled because the metal is so thin.
    That's why I needed new bedsides. It's just easier to find flared bedsides because of all the silver trucks with fiberglass bedsides. lol
  11. Sep 21, 2012 at 5:02 PM
    weazleburger
    weazleburger Well-Known Member
    Baton Rouge, LA
    07 base reg cab 5-speed
    agreed
  12. Sep 21, 2012 at 8:09 PM
    IDtrucks
    IDtrucks Just out for a rip are ya bud?
    Mark
    Boise ID
    YES, do it! Those wheels will look sick, and the 20s will fill in that 2nd gen fender well.
    Im pretty sure I suggested upping the rim size a little while back, and you said "i like to keep it factory" ;)
    and as you know already, i am a big fan of the 4x4 flares. almost makes it look more squatty, which i like in a mini truck
  13. Sep 21, 2012 at 8:13 PM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    i’d get 20’s if i had your truck. but since i don’t and i’m going for off road, i’m going to stay at 16 or 17”s.
  14. Sep 22, 2012 at 4:45 AM
    Kelson
    Kelson My Truck is Cuter than Yours
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    need less offset.
    s 20s are a little bit big imho, but i don't like big rims in general. fakas stay givum to much unsprung mass lidat. ainolike. but should look cherry :D
    anyway. i had 9.5" varrstoens front but with less offset when i borrowed them and they were on 245s and with the stretch the tire would sit flush with my stock fenders.
    if you ran 10.5" in back it would be herrafrush. although i didn't really care for the staggered setup on the truck...kinda a bit more understeer and kind of alot of push.
  15. Sep 22, 2012 at 9:26 AM
    #35
    ryanjboutin
    Las Vegas
    2013 4x4 TRD OR
    Ehfaka.
    I think I'm going to stick with the XR rims for now.
    Probably just do spacers to get them out to flush status.
  16. Sep 22, 2012 at 9:48 AM
    #36
    07TacoRidah
    Pasadena CA
    was wondering, do you have more pix of this when you had them on? I have only seen one and it was from the back view, I saw the rears sticking out some though. Any idea of the offset of the fronts? I know the limit on the 2nd gens is like 9.5" but that's if you are using the right offset.
  17. Sep 22, 2012 at 9:51 AM
    #37
    DEEVON911
    DEEVON911 Semi-pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Late to this, but for a low truck, I always think the best look is, the bigger the better.
  18. Sep 22, 2012 at 6:05 PM
    #38
    Kelson
    Kelson
    Honolulu, Hawaii
    herraspaced?
    the backs poke'd quite a bit, but with fender flares i think it would sit flush. the fronts with the 9.5" the rim itself was sitting outside of the fender and the inside was flush with it (herrafrush like) but that's with a stretched tire.
    with fender flares and the right offset I am confident enough to say that 10.5" all around would fit with no problem at all.
    there are a few XRs with 10.5" rims up front.
    pics are here: http://www.tacomaworld.com/forum/2nd-gen-builds/17539-kelsons-reg-cab-13.html
    Front: 19X9.5 245/35-19 +22
    Rear: 19X10.5 +22 275/35-19 +22
  19. Sep 22, 2012 at 11:11 PM
    #39
    ryanjboutin
    Las Vegas
    2013 4x4 TRD OR
    #herra
    The rears, with that offset...herra, or a lil poke past fender?
    Also, the fronts had to be stretched as fuck, and the rears stretched too?
  20. Oct 11, 2012 at 5:05 PM
    #40
    07TacoRidah
    Pasadena CA
