From 18's to 20's. Whatcha think?
Discussion in 'Street Trucks' started by ryanjboutin, Sep 2, 2012.
  1. Oct 12, 2012 at 7:27 AM
    #41
    ryanjboutin
    ryanjboutin [OP] Weapons grade dickhead.
    Las Vegas
    2013 4x4 TRD OR
    Mid travel, 33's, typical shit.
    1. I'm skeptical of that article because it says the fenders are rolled for a nice stance. lol
    2. I have a 4 banger that doesn't even make 200 whp, whereas that s/c'd XR is making, according to the article, around 340 whp. I have no need for 10.5" wide rims; they're just going to lower fuel economy.
    3. His notch isn't boxed, big no-no.
  2. Oct 12, 2012 at 7:32 AM
    #42
    Large
    Large Red
    Ryan, that's one of the cleanest RC's I've seen. +1
  3. Oct 12, 2012 at 3:42 PM
    #43
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    Pasadena CA
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit Xscorpion dual 0g wire ring terminal (3) Big 3 upgrade (0g wiring) HID kit (headlights - 3k) HID kit (fog light 3k) Bullz Audio 0g wire Exterior: Blacked out OEM headlight housing Front grille swap (to chrome, painted bed liner) XR front bumper valance (dipped red) Aftermarket fog light kit w/OEM switch Rear bumper swap (to chrome) 99 Cents Store tailgate lock Suspension: DJM 3/4" drop kit 1" spindle spacer kit (Addional nuts and longer bolts added) 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs Rims: 18x9.5 Asuka ST 15-2 rims et26 all around 1" billet aluminum wheel spacers 225/40/18 tires all around Neochrome lock nuts Pepboys valve stem caps Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Pioneer DEH 5000ub Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" JBL GTO 1014 (2) 4 ohm svc in dual ported box JDM Fuchsia shift knob (old Dickies pants shift boot)
    1. had I completely read the article instead of looking at the pictures ... ... :(
    2. how does the width of the rim effect the fuel econ? Since I'm going for a kind of JDM style drop (still debating on either 8.5" wide or 9" ... just want it to look clean not like a flower pot sticking out all crazy like) ... this kind of worries me a little. The OE Muranos are @ 7.5" width.
    3. tsk tsk YES VERY BIG NO NO INDEED! I'm not going to notch just yet :eek:
  4. Oct 12, 2012 at 3:50 PM
    #44
    chris4x4
    chris4x4 With sufficient thrust, pigs fly just fine. Staff Member
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Larger contact patch = more rolling resistance.
  5. Oct 12, 2012 at 4:17 PM
    #45
    07TacoRidah
    Pasadena CA
    would it be a bad idea to go with a 8.5" or 9" wide rim?
    going for this kind of look for my rims. nothing too much but just nice enough to give it that clean flow look to it.
    these are 18x9.5" all around.
  6. Oct 12, 2012 at 4:29 PM
    #46
    dud122
    dud122 rabble rabble rabble
    Dan
    Riverdale Park, MD
    2002 Tacoma DC
    OME up front, Dakar in the back, Elite front bumper, Tactical rear bumper with tire swing, Revenge Fab. sliders, Camburg UCA's, Safari Snorkle, FJ TRD wheels, Truxedo, Bed Rug, Lights, CB, Switches, LED's... OH MY!
    that still looks a little pokey to me... i think it looks best when the outter edge of the rim is in line with the curve of the fender, like if you were to lower the car more the edge of the fender would rest on the lip of the wheel...
    for ex:
    with that said, i definitely say go with the bigger wheel. i really like the look of the xrunners but they always seem to have such small wheels, both stock and when people put on aftermarket ones. with all the oversized style panels of the tacoma i really think you need the bigger wheels to pull it off.
    just my .02
  7. Oct 13, 2012 at 9:58 AM
    #47
    ryanjboutin
    Las Vegas
    2013 4x4 TRD OR
    This, it creates drag.
    You don't need a wide rim to get that more-than-hella-flush look. haha
    Just do some homework and find a wheel set with the proper offset.
    The stock XR wheel is an 8" wide rim with a large (+30) offset, so it looks sunken into the vehicle.
    If you put an 8" wide rim with a lower (0 or +15 or -15) offset, it will stick out all Mexican style, just how you like it.
    Or...as I plan to do, just use wheel spacers and trim some fenders because I like using stock Toyota parts to be custom.
  8. Oct 13, 2012 at 10:48 AM
    #48
    07TacoRidah
    Pasadena CA
    I do like how stretched tires look but bot the overly stretched ones lol.
    been trying to figure out what's the best offset ... it's fairly tricky. mainly because I don't have rims to see what it looks like. :( EWWWWWWWWWW F'D THAT!!!! I HATE FLOWER POTS!!! lol I'm mainly looking to get that small poke out w/the stretched tire effect.
    I was thinking spacers, but then I would have to extend my lugs? As of now it looks as if the lug nuts themselves on my OE Muranos are fairly short :mad: or maybe it's just the lug nut holes :confused:
  9. Oct 13, 2012 at 10:53 AM
    #49
    ryanjboutin
    Las Vegas
    2013 4x4 TRD OR
    I had spacers on mine when it was lifted, no extended studs needed.
  10. Jan 4, 2013 at 8:56 PM
    #50
    Hot Taco
    Hot Taco Well-Known Member
    Richfield, WI
    2013 Base Regular Cab
    Beefed Taco 3" Lowering Blocks Bilstein Shocks/Struts DJM 3" Front Lowering Kit Custom C-Notch Intermittent Wipers LED tail lights
    Some food-for-thought (even though the OP has chosen to stay with his 18's)...
    Twenty inch wheels do look cool, but our little 4-banger trucks don't have much horsepower like X-Runners do and big wheels are heavy... really heavy. Not only are the wheels heavier the larger the diameter and wider they are, the tires get heavier, most likely because of all the extra material needed to reinforce the sidewalls. I wish more wheel web sites posted wheel and tire weights. The Tire Rack usually does, but it's one of the few sites that does.
    What's worse is that all the weight is further from the center of the wheel, which will be noticeable. If you've ever watched a figure skater (like in the Olympics), when she wants to spin slowly, she moves her arms away from her body. When she pulls then in, she spins quickly. Same principle applies when you buy large wheels and the weight is far from the center of the wheel. (See "centripetal force" for a nerdy explanation)
    Thus, heavy wheels have a lot of disadvantages:
    • Slower acceleration
    • Poorer braking performance
    • Suspension performance degrades
    I can only assuming fuel economy will suffer as well, but I have no proof of that.
    As for the width of a wheel, apparently the wider the wheel, the better the wheel will perform, but the ride quality will suffer, among other things. For more info, see The Tire Rack web site.
  11. May 10, 2013 at 1:10 AM
    #51
    Brendo Ballz808
    Brendo Ballz808 Slammed or lifted.. ANYTHING IS BETTER THAN STOCK
    BRENDEN
    Oahu
    SNOFLAKE
    Check out my build:)
    thats the stretch I'm tryna go for maybe a lil less but i don't want it to poke that far I'm stryna make the tire tuck and have the rim just sit flush with the fender or a lil out
    but thats not to badd of a stretch it has a wide look to it aggressive not toooooo much rim hanging where its ridiculous (imo)
    and what u know thats the same size wheel ill be running hehe
    we shall see very soon
  12. May 11, 2013 at 4:11 PM
    #52
    ryanjboutin
    Las Vegas
    2013 4x4 TRD OR
    #stancewillmakeherdance
  13. May 11, 2013 at 8:54 PM
    #53
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    Yes sir!!! Hahah
