from 27" to 30" tire on a 4 cylinder ... experience
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fchen7, Nov 23, 2011.
  1. Nov 24, 2011 at 10:07 PM
    fchen7
    fchen7 [OP] Member
    05 Base AC 4 Cyl
    Bushwacker pocket style fender flares
    5 lug automatic - 3.58
    5 lug manual - 3.31
    higher gear ratio in automatic than manual ..... does this mean automatic in highest gear (4th) will use less gas than the manual in 5th gear ??
  2. Nov 24, 2011 at 10:14 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Manual transmissions generally have a lower numerical gear ratio than a comparable automatic. Higher numerical gear ratio leads to higher RPM's for a given speed, which equates to increased fuel consumption.
  3. Nov 24, 2011 at 10:21 PM
    fchen7
    fchen7 [OP] Member
    05 Base AC 4 Cyl
    i see. I got it reversed. I usually can average 28mpg on hwy in a manual 4 cylinder; i should expect less in the automatic i just got.
  4. Nov 24, 2011 at 10:28 PM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    I'm running 29" also honestly I didn't feel that much of a difference, but if there was a loss, the improvement in handling was well worth it. The skinny 215 tires make the truck feel like it was all over the road
  5. Nov 24, 2011 at 10:29 PM
    fchen7
    fchen7 [OP] Member
    05 Base AC 4 Cyl
    again. better pictures this time ...
  6. Nov 25, 2011 at 12:14 AM
    takao96753
    takao96753 Member
    mike
    KIHEI
    2010 Reg Cab 4wd
    thank you for the gear ratio information I calculated my MPG 24.7
  7. Nov 25, 2011 at 3:38 AM
    fchen7
    fchen7 [OP] Member
    05 Base AC 4 Cyl
    235/75/15 ?
  8. Nov 25, 2011 at 6:39 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I'm on the fence. I know my truck would look awesome with some 235's on it, but I get amazing MPG right now, so I don't know if I want to sacrifice that.
  9. Nov 25, 2011 at 8:54 AM
    epa4wd
    Eduardo
    2019 SR
    235/55/18
  10. Nov 25, 2011 at 9:06 AM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    These pics are killing me, please put those flares on with bigger tires.
  11. Nov 26, 2011 at 12:26 AM
    fchen7
    fchen7 [OP] Member
    05 Base AC 4 Cyl
    haha. .. i will ... that's why i am here asking tire questions ... :)
  12. Nov 26, 2011 at 12:28 AM
    fchen7
    fchen7 [OP] Member
    05 Base AC 4 Cyl
    235/55/18 ..... can i see some picture please ...
  13. Nov 26, 2011 at 8:09 AM
    takao96753
    takao96753 Member
    mike
    KIHEI
    2010 Reg Cab 4wd
    Fchen my vehicle is a stock 4x4 I get 24.7 mpg in Hawaii its considered a highway but mainland a surface street.
  14. Nov 26, 2011 at 7:32 PM
    fchen7
    fchen7 [OP] Member
    05 Base AC 4 Cyl
    would i have problem with this tire if i plan to keep truck stock ?
    245/70/16 is 29.5 inch in diameter
    what about 245/75/16 ? it's 30.5 inch diameter ...
    stock tire is 215/70/15 ... 26.9 inch ..
    thanks .. i am getting new tires in a few days..
  15. Nov 27, 2011 at 7:16 PM
    #35
    takao96753
    takao96753 Member
    mike
    KIHEI
    2010 Reg Cab 4wd
    245 is the height and I think 70 or 75 is the width as far if it'll fit I have no idea mine is stock 4x4
  16. Nov 27, 2011 at 7:19 PM
    #36
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I believe the largest you can go is 235/75/15
    245 is the width, in mm. 70 is the sidewall height, as a percentage of the width.
  17. Nov 27, 2011 at 7:35 PM
    #37
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    :popcorn: awaiting those pics of the new tires, fender flares on a 5 Lugger......
  18. Nov 28, 2011 at 5:49 AM
    #38
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    245 is the width in mm.
    70/75 is the aspect ratio of the width to sidewall height.
    R15/16 is the diameter of the rim in inches.
  19. Nov 28, 2011 at 9:17 AM
    #39
    fchen7
    fchen7 [OP] Member
    05 Base AC 4 Cyl
    i think i am going with 245/70/16 .... will post pictures in a day or two... maybe today..
  20. Nov 28, 2011 at 11:12 AM
    #40
    TexasTacoma37
    They may not fit, see my post above.
