from 27" to 30" tire on a 4 cylinder ... experience
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fchen7, Nov 23, 2011.
  1. Dec 2, 2011 at 10:16 AM
    #41
    fchen7
    fchen7 [OP] Member
    05 Base AC 4 Cyl
    Bushwacker pocket style fender flares
    I am waiting for fat bob leveling kit ... front will be raise by 2.5", rear by 1.5 ...
    the picture below is from this morning; i have the bumpers, side mirror, door handle, and flares painted ... nothing else has done to it..
  2. Dec 3, 2011 at 6:00 PM
    #42
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    looks great, thanks for the pics:thumbsup:
  3. Dec 4, 2011 at 12:58 AM
    #43
    fchen7
    fchen7 [OP] Member
    05 Base AC 4 Cyl
    thanks ... i think it looks silly now ... real silly. I had front windows tinted today, i am glad it's done. I didnt want people to see me in this car without the right tires ... :)
  4. Dec 4, 2011 at 6:07 AM
    #44
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    If gas mileage and power are concerns (and they should be) I wouldn't change the height of the tires more than an inch unless you are also going to regear on a 4 cyl truck. I've had a bunch of older toyotas over the years with 33-38" tires on them that were 22re trucks that all went down the road fine and got over 20mpg on the highway. It's all in the gearing. I actually had one 91 reg cab with 4.88's 33's and a header that got 25mpg. I miss that truck.
  5. Dec 5, 2011 at 8:39 AM
    #45
    fchen7
    fchen7 [OP] Member
    05 Base AC 4 Cyl
    I probably will go with 245/70/16. from 27" to 29.5" in diameter. Regear sounds like changing gears in transmission; i have to drive the truck for a while and the differences. I already removed the secondary charcoal air filter and installed AEF pro dry. How much did the regear cost you ?
  6. Dec 5, 2011 at 10:28 AM
    #46
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Regearing involves replacing the gears in the rear differential. The gears only cost $200-300, but if you don't know how to do the work yourself, you can easily double that price to include labor.
  7. Dec 13, 2011 at 12:57 AM
    #47
    fchen7
    fchen7 [OP] Member
    05 Base AC 4 Cyl
    I took this picture today; after the wheels and tires installation and alignment. 245/75/16 tire. Fat Bob Garage leveling kit. Tires rub the fender plastic a little bit, i need to do some shaving of plastic soon. Some loss of power. I like the way it looks. I will know more how it drives after i shave some plastic and drive for a while. With the stock tires, my speedometer was 4mph too fast (at 65mph). With the new bigger tires, it's reversed, it's now probably about 4mph too slow (at 40mph). I appreciate for all the input i received on this forum. I plan to find a machine sander to shave plastic ..
  8. Dec 13, 2011 at 12:59 AM
    #48
    Shemicals
    Shemicals Well-Known Member
    Concord - East Bay CA
    '07 5-Lug Black Sand Pearl Access Cab 2WD
    Build Page
    check out my build buddy i was running 235/75r15s for a while now i have 33x12.5r15s and i have a 5 lug.
    btw what flares are those
  9. Dec 13, 2011 at 1:12 AM
    #49
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    I'm running 265/70-16 (31.6")with no issues but I also have 4.10s. Sure it lacks power but at the end of the day its a 4 banger that still gets over 20 mpg has a bed and will last forever.
  10. Dec 13, 2011 at 10:25 AM
    #50
    fchen7
    fchen7 [OP] Member
    05 Base AC 4 Cyl
    the flares are by Bushwacker ... they make several kinds, this one is called pocket style. sometimes you can find them for under $400 at autoanything.com. They came in black.
  11. Dec 13, 2011 at 10:28 AM
    #51
    fchen7
    fchen7 [OP] Member
    05 Base AC 4 Cyl
    your truck looks good with 265/70/16. no rubbing at all ? That size is almost identical to 245/75/16. Both is about 30.5 inch in diameter. Your tacoma is a prerunner ?
  12. Dec 13, 2011 at 11:41 AM
    #52
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    No, it's a 4x4. Im digging your fender flares though man, I think i need a set my self
  13. Dec 13, 2011 at 2:36 PM
    #53
    fchen7
    fchen7 [OP] Member
    05 Base AC 4 Cyl
    the fender flares i got on the truck is for a tacoma base model accesscab; your truck already has a flare; you should check http://www.bushwacker.com/ and see if they make one for your truck. I would just call them and get the part number and order from ebay or autoanything.com.
    I just went back to the tire store and change the tires to 245/70/16. It definitely feel more powerful, no rubbing, still looks good. Even tho it's one inch smaller. I think 245/75/16 is too big for this 4 cylinder truck.
    #53
  14. Dec 13, 2011 at 2:38 PM
    #54
    Shemicals
    Build Page
    ITS NOT TOO BIG. I HAVE 33X12.5R15S AND I HAVE A 4 CYL FIVE LUG
    #54
  15. Dec 14, 2011 at 1:29 AM
    #55
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I agree I'm putting 34s on once I get my lift even with my 265/70s I'm not lacking any power to say to hell with it
