From Concept to Production...Level 8 MK6
Discussion in 'Discount Tire Direct' started by Discount Tire, Apr 11, 2013.
  1. Dec 7, 2013 at 3:10 PM
    #201
    Thucker
    Thucker Well-Known Member
    Portland, OR
    2010 Mag. Gray BC LB Sport 4x4
    Exactly what I was hoping to see too. I love the dark bonze color wheels on gray, but the pictures I see on the website is a really bright bronze.
  2. Dec 25, 2013 at 3:48 PM
    #202
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Just a couple from today, I'll post up some better ones later this week. Thrilled with this choice of wheels!
  3. Dec 26, 2013 at 3:43 AM
    #203
    ERMB
    ERMB Well-Known Member
    2002 Land Cruiser
    avw4x4, your truck looks great! Stance is perfect. Whats your wheel and tire sizes? I'm assuming you have the negative offset because the wheels are sticking out a bit...
  4. Dec 26, 2013 at 5:17 AM
    #204
    avw4x4
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Hey thank you, same deal as mh3kgt. 16's with a -10 offset and 285/75/16 Hankook dynapro mt's, was looking for duratracs originally but they're all on back order now. In retrospect I'm glad they were because these hankooks are pretty awesome, hope they wear alright!
  5. Dec 26, 2013 at 11:03 AM
    #205
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Jus noticed you were from Idaho.
    Where at?
  6. Jan 18, 2014 at 12:34 PM
    #206
    MI4x4Toy
    MI4x4Toy The slowest build EVER!!
    MI
    '23 TRD Sport DCLB 4x4
    16" with the -10 offset. Bronze. My local DT shop put them on this morning for me.
    9a48110ce6a4767b60c5b2c1a9e270e4_zpse0e4_fe3c7475fc09c977b83a2679adf319794f8ddf5d.jpg
    75756a94ac8b076cd582da0c481fa112_zpsad4b_c5f31ab1dad3183a62dfcb7f729bd95421a66a96.jpg
    ptrick likes this.
  7. Jan 30, 2014 at 2:05 PM
    #207
    Discount Tire
    Discount Tire [OP] Tire & Wheel Specialists Vendor
    Arizona, USA
    ^ Looks awesome!
  8. Feb 10, 2014 at 2:32 PM
    #208
    NateWA
    NateWA Small Town Tech
    Nathaniel
    Concrete, WA
    2013 Black TRD Off-Road
    DeBadged, Plasti Dipped, AT2525XL, 265/75/16 KM2, Level 8 MK6
    Those do look awesome!
    I'm looking to get the same for my truck. Do they rub at all? Have you had to trim? Looks like 265/75/16 Duratracs?
    Thanks
  9. Feb 10, 2014 at 6:09 PM
    #209
    MI4x4Toy
    MI
    No rubbing. I'm actually on factory size. 245/75-16
    Love them so far. Balanced better than my Toyota wheels ever did.
  10. Feb 19, 2014 at 2:16 PM
    #210
    ksmoove757
    ksmoove757 Well-Known Member
    Kenneth
    VA BEACH
    2012 Tacoma Sport 4x4
    What offset do I need for my 285/70 terra grapplers with 5100s set to the highest at front and rear 1.5 block?
  11. Feb 19, 2014 at 2:26 PM
    #211
    avw4x4
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Most likely 0 or slightly negative if you want them to stick out a bit more. May have some very minor trimming to do.
  12. Mar 21, 2014 at 7:39 PM
    #212
    NateWA
    Nathaniel
    Concrete, WA
    So I just got back from my local Discount Tire in Burlington Washington and have a bit of a story.
    I have been looking at wheels for a long time and finally decided on the Level 8 MK6 with 0 offset in Bronze. Got them ordered earlier this week with a set of tires and eagerly awaited the call that they were ready. Got that call today and made the 45 minute drive out of the sticks and into civilization. Arrived right on time, double checked all the info, paid the bill and handed over the keys. After a while they pulled it in and got to work. About 30 minutes later one of the guys calls me over and gives me some interesting information. He says that for some reason the bore hole in the wheel will not fit on my truck. They double checked the box, double checked their ordering system, all came back as 106mm. They apologized, gave me back the truck and said they will call Monday to see whats up.
    Does anyone have any idea if that is even possible? Bad batch of wheels? Uninformed staff? I am not really mad, just bummed I can't get my wheels and tires installed, especially after dropping that much money and time on them.
    Any insight would be great. Thanks.
  13. Mar 21, 2014 at 7:46 PM
    #213
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    Haven't heard of this issue Nate. I ordered mine online and they mounted up no problem and I was told they were hubcentric. Sounds like they were mislabeled in packaging or the machining process was off....
  14. Mar 24, 2014 at 3:29 PM
    #214
    NateWA
    Nathaniel
    Concrete, WA
    Got a phone call earlier that they had contacted the manufacturer and were told that due to the tolerance of the bore being so close that the paint can cause that to happen. The DT guy said they would clean up the bore paint and I scheduled to go down this evening after work. Will post up pics when its all said and done. Hopefully it goes better this time.
  15. Mar 24, 2014 at 8:45 PM
    #215
    NateWA
    Nathaniel
    Concrete, WA
    Well good news. That was the fix. Got them installed with a set of 265/75/16 KM2s. Extremely pleased so far.
    Bagman likes this.
  16. Apr 5, 2014 at 7:17 AM
    #216
    avw4x4
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Guess I never even said how pleased I was with discount tire, when I bought my wheels and tires I received them in like 2 days which was incredible. Also today I just found out I lost my lugnut key and they'll have 2 shipped to me in 2 days! Excellent customer service at discount tire!
  17. Apr 20, 2014 at 7:08 PM
    #217
    Casey31
    Casey31 Well-Known Member
    Casey
    Saltillo, Mississippi
    2013 Silver Streak Mica Double Cab 4WD
    2.5" in lift upfront from the dealership, 1.5" AAL in the rear, Aries Bull Bar painted Black, Badges painted Matte Gray, 17" Pacer Type 164b wheels
    I just bought a 2013 Double Cab to replace my 07 Double Cab that was totaled in a hit and run about a month ago. I had it just like I wanted it and now I'm starting over. Our new truck is a Silver Streak 4wd. Our old one was Indigo Ink with all black accessories including Pacer type 164 17x9 on 265/65r/17 General Grabbers AT2. I currently have the Rugged Trails on the stock TSS wheels in the same size. I would bet the wheels are 17x8. I can't decide between the 17x9 MK6 -12 in Gunmetal or the black Trackers. I have painted the emblems gray and blacked out the grill assembly and bull bar. I want something I can run the Rugged Trails on for another 30,000 miles and that will stick out a little past the fenders to give it a wider stance. Any suggestions would be appreciated.
  18. Apr 21, 2014 at 7:40 AM
    #218
    quantum
    quantum Well-Known Member
  19. Apr 21, 2014 at 12:03 PM
    #219
    Casey31
    Casey
    That's what I am looking for! Great look! I hate to but I may have to copy that look! What size wheels and are those the 0, -10, or -12? I am wanting the wider stance.
    I have painted the emblems a dark gray and blacked out the grill assembly and bull bar. I am planning on painting the rear bumper black as well.
  20. Apr 21, 2014 at 4:48 PM
    #220
    quantum
    16x8 Matte Gunmetal -10 offset w/ 265/75/16 Cooper Discoverer ATPs
    let me know if you need any more info or want some more pics
