From Concept to Production...Level 8 MK6
Discussion in 'Discount Tire Direct' started by Discount Tire, Apr 11, 2013.
  1. Jul 15, 2016 at 6:37 PM
    #601
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Mine as well as my buddy's 4runner studs are a bit short with aftermarket wheels. Must be the design of the lug nuts being able to grab more thread as stock? I didn't have any problems, but they're definitely a little short.
  2. Jul 15, 2016 at 7:25 PM
    #602
    gabbo2112
    gabbo2112 Well-Known Member
    New York
    2020 TRD Off Road
    I was referring to the fact that the wheel studs were too short not too sure what you don't understand rcsb jon...
  3. Jul 16, 2016 at 6:50 PM
    #603
    rcsb jon
    rcsb jon Well-Known Member
    Pittsburgh
    '17 Ridgeline RTL-T | AWD | White | Ebony
    -WeatherTech liners
    31 pages with ppl using these wheels... you're the 1st to have your perceived issue
    a. you and your good friend with the garage are wrong
    b. discount tire direct sent you the wrong lug nuts
    c. toyota gave you short studs
  4. Jul 18, 2016 at 6:33 PM
    #604
    jamiec
    jamiec Man who keep hands in pockets feel cocky all day
    Jamie
    Chillicothe, Ohio
    2017 Prius three touring. Sold the Taco
    Funny, I was just searching the forums about the short stud issue. My rear drums were squealing so I took them apart to lube everything up. That's when I noticed my studs seem short. I've been running them like that for 1 year without problems but they definitely are short. I've had the wheels and tires installed and the tire guy didn't mention it. I've also had my oil changed and tires rotated 3 times at the dealership and they haven't mentioned it either. If I had to guess, I'm only getting 1/4 to 3/8 inch of thread in my lugs. Maybe I need to put longer studs in mine as well.
    gabbo2112 likes this.
  5. Jul 19, 2016 at 7:20 PM
    #605
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    You could have used extended lug nuts instead of replacing the lugs.
    Lots of guys apparently aren't using extended lug nuts, but my '10 definitely needed them. I only had about 1/4" of thread engagement with regular spline drive nuts. Only about 1/2 the recommended engagement.
  6. Jul 19, 2016 at 7:46 PM
    #606
    jamiec
    Jamie
    Chillicothe, Ohio
    I contacted the OP and he recommended I have at least 7 turns of the lug. I checked mine out today and I have 11. So I guess I will be fine. I may order some extended lug nuts though
  7. Jul 20, 2016 at 4:42 AM
    #607
    Polymerhead
    Missouri
    Rule of thumb is to have thread engagement at least equivalent to the diameter of the lug. So, 7 FULL turns (not half turns) at 1.5mm per turn would get you about 10.5mm of engagement. That's pretty close to the 12mm lug diameter. 11 FULL turns would be plenty. I bought non-extended lug nuts initially and they worked, but I only got a couple turns before bottoming out. It seemed dangerous to me, so I did some research and it turns out it was definitely less than ideal.
    Scares me to think about all the people that are installing these with non-extended lug nuts and thinking it's ok. Extended lugs might cost a few bucks more than non-extended, but it's cheap insurance doing the job right. And they look the same when installed, since the extension goes down into the wheel, so I'm not sure why anyone would want to run non-extended lugs, at least in the second gen trucks. I have no experience with third gen.
  8. Jul 26, 2016 at 3:34 PM
    #608
    matadorCE
    matadorCE Well-Known Member
    Melbourne, FL
    '05 Prerunner Accesscab TRD Offroad
    Without having to go through 30+ pages, I just want to know what width and offset to get to not rub on stock suspension with mudflaps for 17" on these wheels and what tire size would fit and not rub?
  9. Jul 26, 2016 at 7:53 PM
    #609
    jztacoma
    jztacoma Trust me I’m an Engineer
    Upstate NY
    2024 Tacoma TRD Offroad
    Semi Stockish
    265/70R17 is the largest tire you can fit with a 17 inch rim on stock suspension.
    4.5 inch backspace is the general go to for most people, gives the truck a nice stance. 4.11 will rub on the mud flaps (found that out for myself).
    Stock rims are around 5.5 inch back space I believe with a 7.5 inch wide rim.
    Most aftermarket are either an 8 or 9 inch wide rim.
    So you either want an 8 inch wide 0 offset or a 9 inch wide -12 offset to get the 4.5 inch backspace. I believe those are the right specs. Google wheel backspace calculator and something should come up just to make sure.
    There's different size combos 255/75R17 for example that may work. But rule of thumb nothing over a 32 inch tire on stock suspension
    Andrew H and canopycarl like this.
  10. Jul 27, 2016 at 10:56 AM
    #610
    matadorCE
    Melbourne, FL
    Thanks a lot, jztacoma!
  11. Jul 27, 2016 at 11:19 AM
    #611
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    A lot depends on what kind of tire you get too. If you get an aggressive one with really deep tread, you'll rub. I had the size stated above (265/70r17) on stock suspension and I had to remove the front mud flaps. That was with 8" wide 0mm offset, which is 4.5 backspacing. They stick out 1.5" more than stock.
  12. Jul 27, 2016 at 11:29 AM
    #612
    rcsb jon
    Pittsburgh
    -WeatherTech liners
    Caboose69 likes this.
  13. Aug 10, 2016 at 2:04 AM
    #613
    GZ1
    GZ1 My Frame Isn't Rusty
    Andy
    SWFla
    '13 PreRunner TRD sport
    Window tint count?
    Are there any pics of a black DCSB with bronze/gold 17's??
  14. Aug 17, 2016 at 8:04 AM
    #614
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    Anyone running the gunmetal on the pyrite mica. If so could you please post some pis .
  15. Aug 17, 2016 at 8:09 AM
    #615
    tacoma guy
    Joe
    Phoenix Az.
    Did you end up going with the extended lugs and if so do you have a lick or part number ? I agree with you on this Thanks !
  16. Aug 17, 2016 at 10:09 AM
    #616
    tacoma guy
    Joe
    Phoenix Az.
    I talked to discount tire this morning and the store manager told me that they are offering the extended lugs now for these wheels . :thumbsup:
  17. Aug 17, 2016 at 10:24 AM
    #617
    jamiec
    Jamie
    Chillicothe, Ohio
    Too bad they wouldn't give a set to people who already have the wheels
  18. Aug 17, 2016 at 10:38 AM
    #618
    tacoma guy
    Joe
    Phoenix Az.
    Yeah he said that instead of buying the original ones you can buy the extended ones. They are like $ 3.00 ea.
  19. Aug 22, 2016 at 2:04 PM
    #619
    matadorCE
    Melbourne, FL
    I put in an order over the weekend for a set of these in bronze, hopefully they'll get to me by the end of the week. Now to find some different center caps since i'm not a fan of the big white "8".
    JustBlaze likes this.
  20. Aug 22, 2016 at 4:50 PM
    #620
    PuyallupJon
    PuyallupJon 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
    Soak a rag in acetone and lightly wipe off the 8. If you have to you can always plastidip the cap a color matched bronze and then get some TRD stickers.
    Bagman likes this.
