From Concept to Production...Level 8 MK6
Discussion in 'Discount Tire Direct' started by Discount Tire, Apr 11, 2013.
  1. Apr 22, 2017 at 6:29 AM
    #781
    kappy079
    kappy079 Member
    Kevin
    Virginia Beach
    2015 TACOMA SR5 4x4 ACLB
    Where did you get the center caps?
  2. Apr 22, 2017 at 9:12 AM
    #782
    Yota831
    Yota831 Well-Known Member
    Santa Cruz
    2024 Tacoma SR5 4x4
    I got them from my local Toyota dealer. List price was $12 each. I got them for $9 each.
    kappy079[QUOTED] likes this.
  3. Apr 25, 2017 at 3:27 PM
    #783
    kappy079
    kappy079 Member
    Kevin
    Virginia Beach
    What black lugs did you use?
  4. Apr 28, 2017 at 2:14 AM
    #784
    kappy079
    kappy079 Member
    Kevin
    Virginia Beach
    Have you had any rubbing or had to do any trimming?
  5. Apr 28, 2017 at 9:20 PM
    #785
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    17x8 with a 0 offset in gunmetal gray. I could not be happier. The stance is much improved. The whole look is better.
  6. May 2, 2017 at 12:53 PM
    #786
    kappy079
    kappy079 Member
    Kevin
    Virginia Beach
    Picked up some 265/75r16 hankook dynapros and black 0 offset MK6 can't wait to put them on!!
    Thunder Fist likes this.
  7. May 2, 2017 at 1:07 PM
    #787
    kappy079
    kappy079 Member
    Kevin
    Virginia Beach
  8. May 2, 2017 at 1:11 PM
    #788
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I still love mine!
    kappy079 likes this.
  9. May 2, 2017 at 2:05 PM
    #789
    jamiec
    jamiec Man who keep hands in pockets feel cocky all day
    Jamie
    Chillicothe, Ohio
    2017 Prius three touring. Sold the Taco
    Me too!
    kappy079 and fatfurious2[QUOTED] like this.
  10. May 2, 2017 at 4:06 PM
    #790
    hobiecat111629
    hobiecat111629 Well-Known Member
    2015 Tacoma Access Cab
    Great find, I didn't think about gen locking lugs. I was just looking for a 24 pack.
    I'm picking up my new tires Thursday and the discount tire guy said that since I bought wheels last year and tires this year hat he'd just swap them out on Thursday.
  11. May 2, 2017 at 5:34 PM
    #791
    kappy079
    kappy079 Member
    Kevin
    Virginia Beach
    What kind of side steps are those? Truck looks awesome man!!
  12. May 2, 2017 at 6:35 PM
    #792
    Thunder Fist
    David
    Birmingham, AL
    Like, so many.
    Thank you so much! Those are CTX. I found them on eBay for about $200. I needed them ASAP or I would have saved for the Magnums. They do their job though.
  13. May 7, 2017 at 12:57 PM
    #793
    kappy079
    kappy079 Member
    Kevin
    Virginia Beach
    dirtnsmores and j.d.mason like this.
  14. May 8, 2017 at 3:50 PM
    #794
    Khonception
    Khonception Well-Known Member
    Khon
    Ft worth Tx
    17 DC OR/13 DC/08 DC OR
    17x9 -12 offset. 285/70/17. Stock suspension. Minor trimming of inner portion fender flares. Also had to push fender lining in after heating with a heat gun. No rubbing on the streets, haven't tried off roading yet. Used goof off for the "8" logo
  15. May 8, 2017 at 3:57 PM
    #795
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
  16. May 9, 2017 at 9:26 AM
    #796
    j.d.mason
    j.d.mason Well-Known Member
    Toronto, Canada
    2014 White TRD Sport DCLB
    I'm trying to debate between 16x8 -10 offset, or 17x9 -12 offset. What would some of the advantages/disadvantages to each wheel be? Tire size would likely either be 265/75/16 or 285/75/16 (or something comparable in a 17"... 275/70/17 or 285/70/17). Will it have an effect on trimming significantly? What about the protrusion from the wheel well - will the extra 2mm offset be noticeable?
    Your thoughts are greatly appreciated!
  17. May 9, 2017 at 9:32 AM
    #797
    jztacoma
    jztacoma Trust me I’m an Engineer
    Upstate NY
    2024 Tacoma TRD Offroad
    Semi Stockish
    I always recommend 17 inch just because of the more tire options out there. But a 16 inch rim and tire are less then a 17.
    As for the offset differences since the 17 inch is a 9 inch wide rim and with a -12 offset it will have a 4.5 inch backspace. The 16 inch with a 8 inch wide rim and -10 offset has a 4.11 inch backspace. I ran the 16x8 -10 and it does stick significantly out of the fender well with a 265/75/16 Tire. Assuming you are planning to do a suspension lift going off of the tire sizes, the 17x9 -12 would be the best since it will give you enough back space to clear all the suspension components, won't push the wheel & tire out to far where it will excessively contact sheet metal and body mounts, and with a 9 inch wide rim can support a 285 or even a 315 wide tire.
    Mclmabert14 likes this.
  18. May 13, 2017 at 5:19 PM
    #798
    423 TACO
    423 TACO Well-Known Member
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    Anyone know if there's a current coupon code for the ebay store?
  19. May 25, 2017 at 10:10 PM
    #799
    Burglecut
    Burglecut Member
    Boise
    2014 DCLB TRD Sport
    5100's, OME 887's, 2" aal, JBA UCA's.
    I am buying these 17x8 and debating between 0 and -12 offset. I will be doing a lift 3" front 2" rear and mounting BFC ko2's 275/70/17, and I want to avoid rubbing. Which offset would you recommend? Thank you for your help!
  20. May 26, 2017 at 1:08 PM
    #800
    Discount Tire
    Discount Tire [OP] Tire & Wheel Specialists Vendor
    Arizona, USA
    Either offset works, but the -12 offset will sit ~1/2-inch further out when compared to the 0 offset. The 17x8 0 offset would be the direction I'd lean.
    Shoot us a PM if we can help you with a set :thumbsup:
    cuda2k likes this.
