From one thing to the next...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yotacoma08, Dec 13, 2019.
Which one do you think
  1. O2 sensors
    0 vote(s)
    0.0%
  2. Fuel injectors
    2 vote(s)
    100.0%
  3. Vacuum leak I could have overlooked
    0 vote(s)
    0.0%
  1. Dec 13, 2019 at 3:31 PM
    Yotacoma08
    Yotacoma08 [OP] Cut the corner or do it over again
    Tanner
    Mississippi
    2008 Silver Tacoma Fuel rims
    Fuel rims, black brush guards, blacked out emblems, TRD cold air intake, and interior mods.
    Hey guys, I made a post a few months back regarding my Tacoma's poor performance. With a lot of people's help on this forum I narrowed down the big issue to the fuel pump. So, after like 3 months I finally have replaced the pump. Made a huge difference without a doubt. I can actually take off from a stop quickly without horrible hesitation, but I've ran into another issue regarding performance once again and I'm hoping yall can help me out.
    The issue is not nearly as bad as before but there's still just a little situation that involves something to do with air and fuel. I'm still getting some hesitation at a cruising speed when i put my foot down. Down shifts like it should and revs up but there does not seem to be any strength behind the revs. I'll be at like 3k rpm and will slowly climb with speed and revolutions like a dang snail. Overall the truck runs so much better, it's just doing kinda what it did before just not nearly as severe. I'm getting no check engine light yet or at least have not had one for a while. During the warmer months it would throw a lean code and on a cold night it threw a rich code all before i changed the fuel pump. I assumed it had all to do with the pump because a guy told me it can throw lean codes. What's interesting is that it threw an rich code one time on that cold night. I hooked my not so sophisticated scan tool to the truck after the pump change. (which was today) Had no codes. I checked data and fuel trims seem normal... I guess. They are a lot different than they use to be. One thing that stood out was O2 sensor voltage. Bank 1 was running like 0.3v and bank 2 was like 3.5v. I believe 3.5v if too high. Here's a list of everything i have checked or replaced so far in the last year:
    MAF Sensor
    Spark plugs
    Cleaned throttle body
    Checked all air hoses very closely
    Did a vacuum test for leaks and catalytic restrictions
    Replaced fuel pump
    Truck has 335k miles
    Any help is appreciated. Merry Chistmas
  2. Dec 13, 2019 at 6:17 PM
    Tacosail
    Tacosail Well-Known Member
    Jerry
    Hermanville Heights, Ohio
    '13 white ACLB
    '17 wheels,int. Wipers , bed mat , relocate trailer plug , husky floor liners , Lund nerf bars, wet Okole seat covers- heat & lumbar.
    Maybe disconnect the battery, wait ten minutes and reconnect. Should reset the brain and after awhile, will relearn how to drive with a new fuel pump. And maybe not, but the time and costs involved should be manageable.
  3. Dec 13, 2019 at 6:33 PM
    Clearwater Bill
    Billy
    Largo Florida
    Miles on vehicle?
    Last time transmission was serviced?
    Your description is similar to a slipping trans
    Kolter45 likes this.
  4. Dec 13, 2019 at 6:49 PM
    aktaco12
    aktaco12 Well-Known Member
    AK
    2012 4x4 DCLB TRD Sport
    Just thinking the same but who knows?! Won't hurt to check it anyway.
  5. Dec 13, 2019 at 6:52 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    Sounds like the VVTi solenoid or the PCV valve. The PCV valve is very cheap $10 part, but the VVTi solenoid is $300. Either part can cause similar symptoms as you describe especially without a CEL or throwing codes.
  6. Dec 13, 2019 at 7:22 PM
    Yotacoma08
    Tanner
    Mississippi
    335k miles. I got the transmission serviced on the 280k or 290k mark. I had a feeling of that too but the situation seems to be sporadic and I've really only driven the truck 20 miles after I replaced the pump but I'll pay attention to that as well.
  7. Dec 13, 2019 at 7:27 PM
    Yotacoma08
    Tanner
    Mississippi
    I seriously forgot about the PCV. I'll look into that for sure. Same with solenoids.
  8. Dec 13, 2019 at 8:33 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    With miles that high has anyone thought about checking the gas pedal? these trucks are drive by wire.
    Tacosail likes this.
