From spacers to 5100's
Discussion in 'Suspension' started by T-rev, Mar 7, 2011.
  1. Mar 7, 2011 at 7:42 AM
    T-rev
    T-rev [OP] Resident Mall Crawler
    Tempe, AZ
    2017 TRD Offroad
    I have a 2008 Sport 4x4 and right now I am running a 3" spacer from Revtek with 285/65/18 Nitto's (10 ply sidewall). The ride is horrible on/off road. On road the truck is jarring and bouncy on rough roads. Off road is just about the same, on top of losing down travel from the spacer itself. I will soon be switching to a 6 ply sidewall tire and along with that the Revtek kit is going out. My question is, has anybody gone from a spacer kit to the 5100's? If so, how much of a difference did it make to you? I plan on setting the front to 2.5" on stock coils or matching the 5100's with Eibach coils and setting them at the 0.85" setting. If anybody has either of these setups please feel free to throw your opinion out there. Realistically I am off road less than 5% of the time, so I have no need for coil overs or anything off road specific. I am looking for on road comfort, with off road functionality when I need it. Thanks in advance.
  2. Mar 8, 2011 at 7:07 PM
    T-rev
    Tempe, AZ
    2017 TRD Offroad
    Bump, anyone?
  3. Mar 9, 2011 at 3:39 PM
    T-rev
    Tempe, AZ
    2017 TRD Offroad
    Back to the top!
  4. Mar 9, 2011 at 4:18 PM
    FLtaco
    FLtaco Well-Known Member
    Nick
    Cocoa beach, fl
    05 prerunner dc
    Painted stock wheels, bfg km2s, 5100s front and rear, tc spindles, add a leaf, 3" block, debaged, flowmaster exhaust, 2nd air filter removed, wheel spacers and k&n air filter
    I went from spacers to 5100s at 2.5. And ride quality is better. 1 being stock and 10 being spacer I'd rate it a 6. So half as bad as the spacer compared to stock almost. That's just my opinion. Doing rears aswell makes it was better though.
    When I did mine my stock setup had 5 years of wear and tear though
  5. Mar 9, 2011 at 6:29 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    I would say get the eibachs with the 5100's. The stock spring just can't handle the preload. I ended up getting the spring with the adjustable collar from toytec cause I wanted it adjustable but basically the same thing. When it first went on it was stiffer than I thought it would be but dirt roads it softened up instantly. Then I removed my sway bar and it made a huge difference. It essentially lowers the spring rate and chills the stiffness out. Come out wheeling with us sometime if u want and can check it out.
  6. Mar 9, 2011 at 6:31 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    as soon as i get money i will go from spacers to icon ext travel coilovers :D
  7. Mar 9, 2011 at 6:40 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Better option! Think ill eventually get these for more travel but I'm liking these toytec's!
