FRONT 2" LONG TRAVEL BATTLE
Discussion in 'Long Travel Suspension' started by The_Black_Pearl, Oct 4, 2017.
Which kit would you run?
  1. All Pro 2" LT Kit
    6.1%
  2. Baja Kits 2" LT Kit
    15.7%
  3. Solo Motorsports 2" LT Race Kit
    12.2%
  4. Total Chaos 2" LT Race Kit
    75.7%
Multiple votes are allowed.
  1. Oct 12, 2017 at 9:06 PM
    #121
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Can you run a DMZ SUA kit without glass?
    I'm not intending to create an argument. Genuinely curious. I've been debating with myself on a +2 and the TC SUA kit vs +3.5 kit with a real LT SUA kit. Some of the trails I do get pretty narrow and I'm 2wd. The trails I'll do 4x4 I'm completely worried about width.
  2. Oct 12, 2017 at 9:10 PM
    #122
    concentric_killa
    concentric_killa Well-Known Member
    2011 4x4 DBL Cab Taco
    +3.5 TC Long Travel DMZ Spring Under Nitro 4:56 Gears Custom Snorkel List Goes On..
    The only reason I run wheel spacers is so my tires don't contact my bypasses. If the bypasses where inside the frame rails you could get away without running wheel spacers. As far as glass fenders, you will have to cut your bedsides due to the increased wheel travel. I ran 33"s and stock bedsides and LT upfront for a while. I finally added glass bedsides because I was tired of having my tires rub on my stock bedsides and wanted to maintain max resale value.
    eccracer104[QUOTED] likes this.
  3. Oct 12, 2017 at 9:12 PM
    #123
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Yeah why not. Might have to take the flares off and cut the inner fender liner if you have tires that are bigger than 33"
  4. Oct 12, 2017 at 9:15 PM
    #124
    TireFire
    Olympic Peninsula
    If you're 2wd build a go fast rig unless you enjoy gettin stuck all the time.
    Edit: not trying to tell you what to do, just what I would do
  5. Oct 12, 2017 at 10:09 PM
    #125
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Buy a first gen and go wide and be right around stock width of a second gen :spy:
    Spintly likes this.
  6. Oct 12, 2017 at 10:13 PM
    #126
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    This thread is nearly a repeat of the mid travel vs long travel and to lesser of a degree let's talk rear suspension threads in case anyone enjoys this debate and wants more lol :wave:
    Coot83 and TireFire like this.
  7. Oct 13, 2017 at 5:09 AM
    #127
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Honestly I don't really notice although there is a difference of 2 inches per side. With a 2+, TC says to cut if not running glass for a reason, but Im sure you could have fun banging up your stock fenders if not. From what I have seen, many guys who link the rear tend to have either 3.5 or wider like 4.5-6.5 kits. At that point you are racing through stuff that the casual full LT guy is cruising through.
    ChadsPride likes this.
  8. Oct 22, 2017 at 6:44 PM
    #128
    blairb
    blairb Member
    Blair
    South OC, CA
    2008 4Runner- Long Travel Expo Build
    Total Chaos +2" Long Travel Race Kit, Armor, Etc...
    Another vote for the Total Chaos +2" Race Kit.
    I have been running it on my 4Runner since right when they launched and I love it. Mind you I don't have any of the other LT kits to compare it to, but it was a huge upgrade from my previous setup (Fox Extended Travel and Camburg 1" UCA's). Great build quality and have had zero issues other than a loose CV boot that puked grease my first trip out (my fault).
    No glass needed for my truck and with the spidertrax I am running in the rear, the widths are similar enough that I never worry about it.
  9. Jun 26, 2019 at 2:24 PM
    #129
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    I was about to ask about this on the LT thread, but the search box prevails
    Thanks @Ripcord
  10. Mar 2, 2020 at 9:15 AM
    #130
    DefinitelyThor
    DefinitelyThor Well-Known Member
    Utah
    2018 Black Trd Pro
    stupid question, but as someone who has a habit of bottoming out mid travel how important would a hyro bump be for the front and what kits allow for it in the +2 lt kit?
  11. Mar 2, 2020 at 9:43 AM
    #131
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    is your suspension tuned for your driving style? If not I’d start there.
  12. Mar 2, 2020 at 10:26 AM
    #132
    DefinitelyThor
    Utah
    2018 Black Trd Pro
    i have a mid travel with really soft foxes that do well for my driving style, it's just not enough shock so im looking in to lt and was just wondering how the hydro bumps do up front and if they are really important for a soft setup like i want to run since they are almost a necessity with a lt rear setup from what i can gather
  13. Mar 2, 2020 at 10:36 AM
    #133
    DefinitelyThor
    Utah
    2018 Black Trd Pro
    im not against it by any means but i really enjoy the idea of getting an lt kit and reinforcing everything on the truck(the group i wheel with are all a little crazy and I am put in the same category as a guy who jumps a jeep with 8' smoothies) my truck has acquired the nickname "baldr" for its reliability and id like to keep from breaking anything. on a side note would a lt rear and a mid front make sense if its something like a dmzfab sua kit with only 14" shocks(straped around 15-16" of travel" instead of the recommended 16-18"?
  14. Mar 2, 2020 at 11:10 AM
    #134
    glorifiedwelder
    jason
    Santa Clarita, ca
    sounds like it’s setup too soft for your driving style
  15. Mar 2, 2020 at 11:12 AM
    #135
    DefinitelyThor
    Utah
    2018 Black Trd Pro
    it might be but if i don't keep it soft than it doesn't stay planted and i get bucked really hard from side to side and the back is honestly just hell
  16. Mar 2, 2020 at 11:16 AM
    #136
    glorifiedwelder
    jason
    Santa Clarita, ca
    It could also have to do with how you drive the truck. If it’s not being driven correctly for the terrain it’s not gonna stay on top of things and you’re gonna get bounced around
  17. Mar 2, 2020 at 11:21 AM
    #137
    DefinitelyThor
    Utah
    2018 Black Trd Pro
    i'll give you that one, but in my mind if i'm going to build a truck why not build it to the way it's driven and not necessarily the "smart" way. hence my look into the wheel travel filled world of lt
  18. Mar 2, 2020 at 11:33 AM
    #138
    glorifiedwelder
    jason
    Santa Clarita, ca
    You can build it anyway you want, but if it’s not driven correctly it won’t make any difference.
    if you choose to go the long travel route the answers to all the questions you’ve asked have been posted in this sub forum a bunch of times.
    desertjunkie760 and whatstcp like this.
  19. Mar 2, 2020 at 12:12 PM
    #139
    DefinitelyThor
    Utah
    2018 Black Trd Pro
    thanks for the help, and i do believe that you have a point of build it right and hydro bumps are not a necessary by any means
  20. Mar 2, 2020 at 12:22 PM
    #140
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    LT may be a great option for the future, but the cost of that vs sending us your shocks to get revalved is quite a bit cheaper. If the coilovers you're running have not been tuned, then yes they are way too soft.
