Front 5100 with Revtek 3" spacer lift?
Discussion in 'Suspension' started by Jedidiah, Aug 15, 2009.
  1. Aug 15, 2009 at 5:21 PM
    Jedidiah
    Jedidiah [OP] TakeItEasy
    Oregon
    BHLM Bilstein 5100's BFG AT 285's HID (6000K) Maglite Grillcraft Grill debadged
    Anyone out there running the 5100 set at stock height while also running the revtek 3" spacer lift?
    any thoughts or ideas?
    Thanks,
    Sylas
  2. Aug 15, 2009 at 5:31 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    Running the Revtek spacer w/ 5100s would be absolutely no different then running the 5100s at 2.5 w/ a 10mm top plate spacer.
  3. Aug 15, 2009 at 9:10 PM
    Jedidiah
    Oregon
    I heard its not good if you run a spacer with the bilsteins set at the highest notch...
  4. Aug 15, 2009 at 9:11 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I would just ditch the spacer and set the Billy's at 2.5''. You'll get a MUCH better ride out of it.
  5. Aug 15, 2009 at 9:41 PM
    toytaco970
    toytaco970 Well-Known Member
    avon/vail, co
    05 trd offroad 4x4
    Front: Icon IVD coated extended travel coilovers Rear: 5125's with AAL and 1" block. Front sway bar removed. Brute Force Fab bumpers AllPro stuff: UCAs , front skid plate, sliders, rear u-bolt flip kit, e-locker guard Kenwood/Garmin single DIN DVD-NAV system, amp and sub. V1 radar, Foglight anytime mod,
    Been running the revtek spacer with 5100's on second notch for some time now... works great, no issues
  6. Aug 15, 2009 at 11:20 PM
    Jedidiah
    Oregon
    cool thanks i was wondering if it would cause issues!
    thanks
  7. Aug 15, 2009 at 11:28 PM
    SC4333
    Grant
    San Antonio, TX
    It is definitely possible to run this setup, although I would highly advice against it. The shocks are for one, not valved for such a high spring rate which will occur when having such a high preload on the spring, and two, you will experience what most all people would consider a very harsh ride.
    On top of these issues you will also need upper control arms at this point. With the setup mentioned, you will be at around 3 inches of lift which will cause the caster to be way out of spec.
  8. Aug 16, 2009 at 12:10 AM
    Jedidiah
    Oregon
    Thanks for the info! this is the info i was looking for...i just couldnt find it!
    thanks man!
  9. Aug 16, 2009 at 12:48 AM
    toytaco970
    avon/vail, co
    05 trd offroad 4x4
    Forgot to mention I do have AllPro UCAs as well. They are definitely needed for correct alignment. You will have all kinds of vibration issues without them. I also removed the front sway bar and that also helped with the ride but it is still a very firm ride. It is a 4x4 truck after all, its not gonna ride like a sedan no matter what you do.
