Front a little higher lift
Discussion in 'Suspension' started by matt74, May 3, 2013.
  1. May 3, 2013 at 8:08 AM
    matt74
    matt74 [OP] Member
    TRD
    Ok I want a 3" lift on my access cab and I want the front a little higher, I just really don't want the back higher at all and I think wen their level it kinda looks like the rear a little higher still but whatever! I need some input, should I get the BK0510 toytec lift and get the spacers that they say are for double cabs? Will I be able to put tp14 taco lean spacer on it too? Or should I get the TTHA-CK lift cuz they have bigger top plate spacers above the coil? Or does that kit still make it level? I just didn't want to spend the money for the assembled TTHA-ck cuz I'm not paying for installation of anything. Also one last thing, do I even need the rear bilsteins if I don't offroad much, cuz they don't add lift, thank you!
  2. May 3, 2013 at 8:30 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    I wouldn't stack spacers if that's what you're asking.
    Also I'd still use the billies in the rear for better ride plus the ones you get with the kit will probably have longer travel than your stock shocks.
  3. May 3, 2013 at 6:21 PM
    matt74
    matt74 [OP] Member
    TRD
    Is it a bad idea to get the spacers and not put the taco lean spacer with the cheaper toytec lift? Or is the taco lean bad, do all tacomas w/ a lift get it?
  4. May 4, 2013 at 5:51 AM
    jtav2002
    Josh
    Reading, PA
    I bought the taco lean spacer but never installed. I'm sure if I measured if might be leaning however it does look like its leaning so I didn't bother.
  5. May 6, 2013 at 9:33 AM
    matt74
    matt74 [OP] Member
    TRD
    K thanks I think I'm gonna go with the cheaper one with the spacers
  6. May 6, 2013 at 1:22 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    If you are using the factory coils, you probably won't need a lean spacer.
  7. May 10, 2013 at 8:41 AM
    matt74
    matt74 [OP] Member
    TRD
    K wat about a cheap 3" lift route and getting 5100s for the front w/ stock coils and 1.5 or 2" aal for the rear w/ everything else stock?
