Front actuator bench test ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chop, Feb 13, 2017.
  1. Feb 13, 2017 at 4:00 PM
    chop
    chop [OP] Well-Known Member
    byron
    British Columbia
    08 Tacoma 4x4 dclb TRD Sport 4.0L
    3"lift , arb front bumper,ome 886 coils, icon xrt leafs goodyear duratraxs firestone air bags
    hay guys I think I have a front diff actuator problem ?
    Can someone please explain how to test it to see if it is faulty.
    The dash light blinks and won't go into 4x4 , doesn't shift . It's in 2wd for now !
    O ya it's a 08 tacoma 4 litre
  2. Feb 13, 2017 at 7:20 PM
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    Change the title from "Help" to something more descriptive and you may get some actual replies and spare yourself the wrath of TacomaWorld in the process
    T-Rex266 likes this.
  3. Feb 13, 2017 at 7:23 PM
    Pigpen
    Dan
    Northwest Montana
    ^^ What he said. We'll help once it's changed.
    Waiting
  4. Feb 13, 2017 at 7:34 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
