Front and rear Bumpers on 4cyl
Discussion in '4 Cylinder' started by jdebo, May 21, 2012.
  1. May 21, 2012 at 12:34 PM
    jdebo
    jdebo [OP] Active Member
    Wintersville,OH
    10 Tacoma 4x4 4cyl
    Any of u 4cyl guys install front and rear bumpers? Im thinking of brute force hybrid front 85lbs and standard rear. I need u guys thoughts.
  2. May 23, 2012 at 12:46 AM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    If you're watching weight find a vendor that works with Aluminum. Relentless Fab is another option. You can PM Billy at Bruteforce about options too he's usually very helpful with people wanting something customized a bit
  3. May 23, 2012 at 12:51 AM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    You'll be fine, it's not the bumpers that will kill your MPG its the tires.
  4. May 23, 2012 at 12:53 AM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    So adding a hundred lbs or so, and changing the aerodynamics play no effect on mpg? I found with my bumpers, if I have a more aggressive driving habit, it effects my mpg if I was to be aggressive without the bumpers.
  5. May 23, 2012 at 1:02 AM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    a bumper weighs about as much as a passenger.... as for aerodynamics you'll lose some of your top end speed. 80mph will be a dream unless you have a tail wind. With my 33's, bumper, winch, and roof rack I'm getting 17 mpg, with my 32's I'm getting 21mpg.
    Unsprung weight rotating mass will have the greater influence on mpg.
  6. May 23, 2012 at 1:05 AM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    I think he was speaking in relativity. Relative to a tire with great weight, rolling resistance, size etc a hundred lbs in bumpers will affect you less. You'd be surprised how much aggressive tread pattern alone can affect rolling resistance/mpg, let alone weight/size
  7. May 23, 2012 at 1:11 AM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    I went from 31"street tires, no front bumper, and stock rear at 18mpg avg on a full tank, to 32"bfg ats d class, and elite bumpers front and rear, and get 15ish, high 14s.
    Admitingly yes the tires make a difference. But the bumpers make it feel a hair sluggish now, more then just tires.
  8. May 23, 2012 at 6:03 AM
    jdebo
    Wintersville,OH
    10 Tacoma 4x4 4cyl
    I ended up contacting Billy. Went with his hybrid front and standard rear. 80 lbs for the front and 90lbs for the rear. I don't mind taking a small hit on mpg but just don't wanna be back in the 14-15 range again. In not going crazy on the tires this time either so I should be good! Planning to lift about 2 inches and go with 265/75's. Gonna add wheel spacers to widen my stance a little. I get offroad but nothing extreme. Mostly tight muddy trails to the fishing holes.
  9. Feb 18, 2013 at 9:06 PM
    Longo118
    Longo118 Well-Known Member
    New York
    2006 4x4
    -OME Lift w/ Dakar leafs -Wheels + Tires -All Pro IFS skid -4xInnovations Sliders -Tool box, hi-lift, shovel mount and a few others
    Any update on this? hows the MPGs and power loss after the bumpers, lift and tires?
  10. Feb 25, 2013 at 8:58 PM
    Gus 524
    Gus 524 Well-Known Member
    Justin
    MN
    09 tacoma SR5 4WD 4-cylinder
    Curious on more people's opinions.
  11. Feb 26, 2013 at 12:18 PM
    bzzr2
    bzzr2 Well-Known Member
    i noticed no change in mpg when in put a hybrid front and sliders on my reg cab. added a leer 180 and still no difference, but my new dick cepek tires might drop it down 1mpg
  12. Feb 26, 2013 at 5:26 PM
    Gus 524
    Justin
    MN
    Good to know. Crazy how big metal bumpers don't change much but tires do.
  13. Feb 26, 2013 at 9:18 PM
    bzzr2
    i expected a difference and i added the weight and there must be a slight decrease but not enough that i notice it when occasionally checking mileage.
