Front and rear shocks
Discussion in '1st Gen. Tacomas (1995-2004)' started by CVP71, Nov 9, 2008.
  1. Nov 9, 2008 at 10:04 PM
    CVP71
    CVP71 [OP] Member
    SR5 PreRunner Super White
    Headlamp relay/wiring upgrade w/Sylania SilverStar Ultras.
    I have a 2004 Tacoma PreRunner SR5 Xtra Cab V-6 with 151,000. This truck has been an excellent truck. However, this was the first Toyota truck I've ever owned. What life expectancy can I consider for the shocks? It has been maintained every 4k and has been driven on the highways and state secondary roads in North Carolina with no loads.
  2. Nov 9, 2008 at 10:20 PM
    medic2230
    Murph
    Bama! Roll Tide
    I've got a 2000 taco Xtra Cab 4x4 with the original shocks up front still and the trd bilsteins in the back I swapped out at about 4-5 yrs just cause a friend that has an offroad shop had them from a take off when he did a lift. Mine still ride fine. Dunno really what the life expectancy is of them though.
    Murph
  3. Nov 9, 2008 at 10:29 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    I changed my OEM ones out at 90K, made a world of difference.
  4. Nov 9, 2008 at 10:39 PM
    CVP71
    CVP71 [OP] Member
    Thanks! Did you use OEM or aftermarket?
  5. Nov 10, 2008 at 12:44 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I put Billy HD shocks (aftermarket).
  6. Nov 10, 2008 at 9:07 AM
    crazydaze_95
    crazydaze_95 Well-Known Member
    ne md
    mall crawler till the jeep dies
    6inch fabtech lift kit, 35inch mickey thomphson atz, 16inch pro comp rims, deck plate mod, k&n air filter, diff lock grey wire mod, b&m trans cooler, flowmaster 40 muffler, clarion dxz755mc head unit, pioneer 6x8 3 ways in all four doors, infinity basslink powered subwoofer, mesh grille, power moonroof, geared to 4.88, fabtech light bar, custom skid plate.
    i have two sets of trd shocks if interested. one set is off a double cab and the other set is from an extended cab. both 2004 with low miles 30,000.
    asking 110 bucks shipped per set
  7. Nov 10, 2008 at 9:13 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i installed a set of bilstein 5100's on all 4 corners of my 04 double cab.........love the ride, way better than stock. i also have a set of front trd coils off my 04......only have 46k miles on them.....asking $40 plus shipping for the set............and they will lift the front of an extra cab about 1.5 inches. just a heads up!!
  8. Nov 10, 2008 at 9:23 PM
    CVP71
    CVP71 [OP] Member
    Thanks guys. I'm considering some aftermarkets. I'm also afraid of ther labor rate. I can install the rear shocks, but I don't have all of the tools necessary to do the front. A lift would be nice with an air wrench.
  9. Nov 10, 2008 at 9:30 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    Just take the front shocks with your old setup and take it to a shop and have them install the new shocks and/or springs for you. I'm gathering it shouldn't be more than $40/side.
  10. Nov 11, 2008 at 5:49 AM
    CVP71
    CVP71 [OP] Member
    I think you need a coil spring compressor, is that correct? If so, I could change them at home.
  11. Nov 11, 2008 at 7:37 AM
    Bs 02 Taco
    Bs 02 Taco Well-Known Member
    Amelia, Ohio
    02 Tacoma 4x4 regular cab 5 speed
    Swiss cap Deckplate Stupid door chime Synthetics AFE pro dry JVC Ipod compatible head unit Vanilla air freshener :) 25%tint
    Hey fellas,
    Would any of your "gently used" shocks fit my 02 regular cab?
    Its got @ 115,000 on it and really rolls from side to side with my cap on.
    Without the cap it is a bouncy little bugger ;)
  12. Nov 11, 2008 at 7:53 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    Yes, but if you've never used those compressors then I would suggest taking them to a qualified mechanic to do so. Those compressors are very dangerous to those that have no experience with them.
  13. Nov 11, 2008 at 3:54 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    Yeah i wouldnt recommend doing them at home, very dangerous
  14. Nov 11, 2008 at 9:26 PM
    CVP71
    CVP71 [OP] Member
    I downloaded the FSM from the link I found here. The FSM indicates to lower the floor jack to release the pressure on the springs. I'm guessing they are not using spring compressors, but apparently use the floor jack under the lower A-frame to relieve the pressure on the spring so the shock can be loosened and removed. I'm not too fond of spring compressors either!
    Any thoughts?
    Thanks,
    Rick
  15. Nov 11, 2008 at 10:49 PM
    humanoid
    humanoid bite me
    Sunny SoCal
  16. Nov 11, 2008 at 11:15 PM
    CVP71
    CVP71 [OP] Member
    Thanks, humanoid. These helped out. I could remove the entire unit and take it and have the new shock installed and bring it home. If the technician screws up, it's on them, especially if they get hurt!
  17. Nov 16, 2008 at 9:43 PM
    CVP71
    CVP71 [OP] Member
  18. Nov 25, 2008 at 9:09 AM
    Ricky B
    Ricky B Well-Known Member
    Arkansas
    1998 XCAB
    Not trying to sidetrack this thread, but if I bought the blistens 5100's I don't need a spacer for the front they will turn up 2.5 inches and a 2.5 lift for the back. Also is it safe to say that the back shocks with lift is easy to do and have the fronts done by someone? Rick
  19. Nov 25, 2008 at 1:49 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    well.....yes and no. you dont need a spacer for the front with the 5100's and yes..they will lift the front 2.5 inches.........but the 5100's themselves arent going to lift the rear of the truck. you will either need an aal or a block to accomplish that. the 5100's are "good for" a little lift in the rear, but just the rear shocks will not lift the rear.
  20. Nov 26, 2008 at 7:40 AM
    Ricky B
    Arkansas
    1998 XCAB
    Thanks Tacomaman that is what I meant to say. I should have said with the 5100's and a spacer on the rear. So you need a spacer for the rear and the 5100's and just the 5100's for the front??? Rick
