Front ARB locker strong enough?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cclogan8, Oct 6, 2017.
  1. Oct 6, 2017 at 12:01 PM
    Cclogan8
    Cclogan8 [OP] Well-Known Member
    Logan, Utah
    16 Taco DCLB
    Its getting bad, Im almost broke.
    I’m having 488’s installed in my 16TRD in a couple weeks. I’m considering having an ARB installed at the same time in the front. I thought I read that people have had problems with them blowing up in the front because independent suspension is not as strong as an axle? Is this true? Is there much cause for concern having an ARB in the front? Thanks.
  2. Oct 6, 2017 at 12:33 PM
    eon_blue
    Azusa, CA
    Yes it is true, though it's usually the front CV axles you have to worry about the most. They are not nearly as strong as a solid straight axle and will break under the stress of a locked front diff IF it isn't used properly. Just have to use it carefully (don't spin the tires like crazy if you're stuck, don't make sharp turns when locked in the front, etc.) and it's usually fine. I usually leave my rear locker turned on for most of the trails I do and I'm mindful of it, never had any issue. A front locker on IFS I would only activate when necessary.
    A rear locker and 4wd is usually enough for the average off-roader, front lockers are overkill for all but extreme rock crawling circumstances IMO.
    eccracer104 and Cclogan8[OP] like this.
  3. Oct 6, 2017 at 12:46 PM
    Cclogan8
    Logan, Utah
    16 Taco DCLB
    So basically if I’m rallying it throught the snow with a trailer I’m highly likely to damage it? That’s most likely what I’d use for.
  4. Oct 6, 2017 at 12:52 PM
    eon_blue
    Azusa, CA
    Snow wheeling isn't my forte, I'll let someone else chime in on that. I wouldn't use a front locker though unless I was approaching an obstacle that required it to climb over/through.
    EatSleepTacos likes this.
  5. Oct 6, 2017 at 12:53 PM
    Quicksand Jesus
    Quicksand Jesus Well-Known Member
    Derrick
    Littleton, Colorado
    2002 Toyota Tacoma TRD DCSB
    3" OME Lift with Dakar Leaf Pack - SPC Upper Control Arms - Trail Gear Weld On Rock Sliders - 285/70/16 BFG KO 2's - Fuel Matt Black Anza Wheels - Bushwhacker Cut In Fender Flairs- Deck Plate Mod - Paranoid Fab Scangage Mount - URD Throttle Body Gasket - Flowmaster American Thunder Cat Back Exhaust - Compustar Security, Remote Start, Keyless Entry.
    I am in the same boat and have done some research on it. Slee Offroad in Golden Co is one of the foremost Toyota specialist and they tell me they lock the front IFS all the time. Again only in cretin circumstances can you use it. When I re-gear I'm gonna lock the front.
    Cclogan8[OP] likes this.
  6. Oct 6, 2017 at 12:54 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    I would think it would be fine in snow since there's not much traction, but still should be careful
  7. Oct 6, 2017 at 1:17 PM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    In my experience lockers tend to push you all over in the snow. Open - open works pretty good until you stop then you might need the added traction lockers could help with.
  8. Oct 6, 2017 at 1:26 PM
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    Why are you rallying through the snow with a trailer hooked up?
    Midknight, JDAM and eon_blue like this.
  9. Oct 6, 2017 at 1:45 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
  10. Oct 6, 2017 at 1:46 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    this made me laugh harder than I probably should have.
  11. Oct 6, 2017 at 1:46 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Like it was said earlier OP, watch those CVs. You'll break them way before you break the actual locker.
    What's the tire size you'll be running? I'm guessing 35s with the 4.88 gears?
  12. Oct 6, 2017 at 1:48 PM
    goose443
    goose443 Well-Known Member
    Austin
    Texas
    2016 Tacoma TRD Off Road 4x4
    That place is the best
  13. Oct 6, 2017 at 2:11 PM
    Cclogan8
    Logan, Utah
    16 Taco DCLB
    I’m running 285’s for tire. I rally with my snowmobile trailer up a 1 mile road 2-3x week. The state won’t plow so it’s seriously just like the cats meme.
    greeneggsnspam and RangerComa like this.
  14. Oct 6, 2017 at 2:35 PM
    TheTacoma
    TheTacoma Well-Known Member
    Birmingham, AL
    2017 DCSB, TRD OR 4x4, Quicksand. SOS Bolt-on Sliders. 285x75r16. Kings
  15. Oct 6, 2017 at 2:48 PM
    Louisd75
    Louisd75 Well-Known Member
    Northwest Washington
    '02 Xtra Cab, '15 DCSB
    If you're re-gearing and can afford it then you might as well do it. As for using to help with mobbing through the snow, I'd recommend against that. If you're running locked on a slippery surface with any sort of camber to the road you will wind up sliding towards the downhill side. Lockers really shine when you're stuck and spinning one wheel, though honestly I've found that if I'm stuck spinning a wheel in the snow engaging the locker most often makes it so that I'm spinning two wheels. But that's also why I carry a shovel and chains.
