Front axle seal part #
Discussion in 'Technical Chat' started by 07Tacoma806, Nov 9, 2011.
  1. Nov 9, 2011 at 6:24 AM
    07Tacoma806
    07Tacoma806 [OP] Member
    Amarillo
    2" spacer, URD short throw shifter, headlight mod
    Ok so I'm new to tw and I was wondering if any of you have or know the part number for the front axle seals. My father was helping me swap out a cv axle and it was a real pain in the rear so we just went to town on it and damaged the inner seal
  2. Nov 9, 2011 at 6:29 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  3. Nov 9, 2011 at 12:03 PM
    07Tacoma806
    Amarillo
    Thanks a lot! I searched everywhere and couldn't get a straight answer
  4. Nov 10, 2011 at 5:33 AM
    SampleFool
    SampleFool Three Percenter
    Ga
    Silver
    08 off-road
    Good luck with them, if you dont have a slide hammer it will be harder to get out the cv axels. Saves you alot of money though, so worth it.
  5. Mar 14, 2012 at 10:19 AM
    GotLift37
    GotLift37 Bangers Runner
    down south
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion
    did you ever replace the axle seal? im having troubles installing the new one on the driverside
  6. Mar 14, 2012 at 10:32 AM
    jds0912
    jds0912 Well-Known Member
    Justin
    Baltimore, MD
    2007 Tacoma TRD Off Road
    Some shit I got on craigslist
    I had to change both of mine after a horrible stuck in a deep mud hole. I believe I got instructions from TTORA. Basically once you get the CV's out, pop the old seals out with a flat head screw driver, or claw hammer (very carefully), and tap the new one in using a 2x4 block and rubber hammer to make sure you dont put them in too far or unevenly. I just stuck it in part way by hand, placed the block on the diff oil seal and tapped in a ciruclar motion until they were in. Havent had any leaks since.
  7. Mar 14, 2012 at 10:47 AM
    GotLift37
    down south
    07 4Runner 4WD
    thanks.. does the part number for the drive side end in 12 or 13? i may have the wrong seal. it seems like it doesnt want to fit
  8. Mar 14, 2012 at 10:55 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Driverside is a 12. The passenger side is 13 and a little bigger.
  9. Mar 14, 2012 at 1:30 PM
    GotLift37
    down south
    07 4Runner 4WD
    ok I have the correct part but it just doesnt want to go in there and i dont want to ruin it. I have a bearing race and seal driver set. sizes vary from 1.565"-3.180" Im just in need of help lol I know I can do it but just need it to be explained a little better
