Front Axle & Wheel Hub removed an installation
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mr.Vencha808, Jan 13, 2021.
  1. Jan 13, 2021 at 11:02 PM
    Mr.Vencha808
    Mr.Vencha808 [OP] Member
    Lopaka
    2016 Tacoma 4x4TRDSport
    6” BDS Lift Fox Suspension With Reservoirs also with 3” stackable spacers... 4” Block With 2 Toy Teck Add A Leaf Springs... On 22x14 in Hostile Wheels 35’s Nitto Trail Mud Grappler Tires...
    So I Have A lifted 2016 Tacoma an been wanting to change out front axles wheel hub assembly... I’ve ordered the parts already have it on hand.. I just got my 8”clamshell bushing for driver side in today but most of my problems an noises are on my the passenger side...
    so my question is can I use the
    8”clamshell bearing on the passenger side?? Or it’s only made for the left side only??
  2. Jan 13, 2021 at 11:08 PM
    Car Ram-Rod
    Car Ram-Rod Well-Known Member
    What noises are you hearing on the passenger side?
    The “clam shell bushing” you’re talking about is the one that replaces the driver side factory needle bearing?
  3. Jan 13, 2021 at 11:22 PM
    Mr.Vencha808
    Lopaka
    Yes I know but is it only for the driver side?? Or can I use it on both sides??
  4. Jan 13, 2021 at 11:29 PM
    Car Ram-Rod
    Pretty sure it’s drivers side only.
    what kind of noise you hearing in the passenger side?
  5. Jan 13, 2021 at 11:33 PM
    Mr.Vencha808
    Lopaka
    I’m hearing a humming sound most definitely it’s the wheel bearing.. an also Rattling noise sounds like somethings bouncing around somewhere in that area... it’s not a broken stud I know that for sure.. i can hear it when I’m slowing dwn to a complete stop..
  6. Jan 13, 2021 at 11:56 PM
    Car Ram-Rod
    What size wheels and tires are your running?
  7. Jan 13, 2021 at 11:59 PM
    Mr.Vencha808
    Lopaka
    I had 22x14 hostile on 35” Trail Nitto Mud Grappler M/T With 1.5” wheel spacer.. took those off an now I’m using stalk snow flakes wheels with stalk tires...
  8. Jan 14, 2021 at 12:01 AM
    Mr.Vencha808
    Lopaka
    53423A9C-CB18-4487-AD5B-E04D3C48D5E3.jpg These is what I had on
  9. Jan 14, 2021 at 12:02 AM
    Mr.Vencha808
    Lopaka
  10. Jan 14, 2021 at 12:30 AM
    Car Ram-Rod
    Yeah it’s probably the wheel bearing. You said you changing both side wheel bearings anyway so wouldn’t hurt to start there and see how the thing changes or stays the same.
  11. Jan 14, 2021 at 12:37 AM
    Mr.Vencha808
    Lopaka
    Well I’m change those an my axels but driver side I’m gonna put in the 8”clamshell bearing.. an was wondering if the passenger side has the same thing or it just has needle bearings?? An That’s I should change?? As well!? Since I’m already goin in that far??
  12. Jan 14, 2021 at 1:14 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Passenger side uses different bearing.
    Both side use same # oil seals.
    Below from the ECGS site
    TOYOTA 8" CLAMSHELL PASSENGER SIDE TUBE BEARING
    Pricing: $30.00
    This is the bearing in the passenger side tube of the T8 clamshell. It is a ball bearing OE replacement it is what supports the CV axle on Pass side directly behind axle seal.
    Fits 05 to present Toyota front axle tubes.
    Mr.Vencha808[OP] likes this.
  13. Jan 14, 2021 at 1:23 AM
    Mr.Vencha808
    Lopaka
    Yes I have that one as well to install.. just wasn’t sure if that was for wheel hub... cuz I ordered the whole wheel hub assembly.. an was like darn it.. don’t tell me I have the wrong one lol
  14. Jan 14, 2021 at 1:24 AM
    Mr.Vencha808
    Lopaka
    So the passenger side if I’m not mistaken I have to take out C clip holding in the bearing?? Then press the bearing out after that??
  15. Jan 14, 2021 at 2:15 AM
    muddog321
    FL
    The bearing above is passenger side and your ECGS clamshell bushing drivers side (that replaces a weaker needle/roller bearing drivers side) go into the front diff housing to support the inner end of the CVs. CVs go in secured by the CV axle attached clip that comes out/goes in attached to CV. After you pull the CVs out a puller is used to remove those housing bearings and get new oil seals as you may mangle them - up to you but cheap and already will be in there.
    The wheel hub or bearing is the one piece assembly that the outboard spline of the CV goes thru and has a big nut to hold on all bolted to the steering knuckle.
    Many videos [posted on all of this.
  16. Jan 14, 2021 at 6:36 AM
    Car Ram-Rod
    Wheel bearing you won’t be taking out. You said you have new hub assemblies so when you remove the hub you just bolt in the new hub you bought.
    the ECGS bushing you have to take out the CV axle from the drivers side of the differential and then remove the needle bearing and replace with the new bushing.
    Ive never heard of guys replacing the passenger side bearing but I’m sure people do it. Probably a similar process to the driver side
