Front bottom of engine always looks wet..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 80schild, Jun 18, 2017.
  1. Jun 28, 2017 at 7:01 PM
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
    Essentially just pulls off...but I use a puller tool to get it off because of buildup caked on it. Can't remember if there is a thread hole for a bolt to break it free
    12TRDTacoma[QUOTED] likes this.
  2. Jun 28, 2017 at 7:04 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I really gotta change that worthless seal. It should be considered more of an orfice the way it leaks on our trucks.
  3. Jun 28, 2017 at 7:14 PM
    Boomkanani
    Goldsboro, NC
    Some stuffz
    Yea mine started to get pretty bad. I'm just glad the seal fixed it...there are instances when the crankshaft itself gets grooved and a metal sleeve is needed. I actually avoided using OEM main seal so it would sit in a different spot and hopefully prolong the grooving
  4. Jun 28, 2017 at 7:17 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Grooving? Say what?! Hat brand seal did you go with by the way? I'm contemplating between OE and a differenbrand so I'm open to ideas.
  5. Jun 28, 2017 at 7:21 PM
    Boomkanani
    Goldsboro, NC
    Some stuffz
  6. Jun 28, 2017 at 7:23 PM
    80schild
    80schild [OP] Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    My replacement seal was Felpro.
  7. Jun 28, 2017 at 9:02 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    A rubber seal is not going to be wearing a groove in a hardened steel crankshaft.
  8. Jun 28, 2017 at 9:27 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Over a long period of time yes it will. I have seen it many times. It takes many many years though
    Boomkanani likes this.
  9. Jun 29, 2017 at 11:41 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
  10. Jun 29, 2017 at 1:00 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    After about 350-400k miles on my '82 I threw mine away and got an ungrooved one. The sealing period was getting shorter and shorter as the groove developed. Based on everything being more expensive and lasting less nowadays, I could see grooving being an issue at 200k or less..................
  11. Jun 29, 2017 at 1:37 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    If you have wear where the seal meets the crankshaft / pulley it is not the rubber seal that is doing it. It is contamination and grit working into this area from the outside or you do not change the oil often enough and getting acidic. One of those two things is the cause. Rubber is not going to wear into steel. Keep it clean and you will not have an issue.
  12. Jun 29, 2017 at 1:49 PM
    Boomkanani
    Goldsboro, NC
    Some stuffz
    Makes sense. I can't say I want to remove the pulley regularly to clean there. Not to mention all the grime that collects from offroad.
  13. Jun 29, 2017 at 1:50 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    agree to disagree.........but my evidence is long gone. I did regular oil changes and used factory seals. I am OCD about fluid leaks on my vehicles and always have been. And it was the right part, same one it started out with. It was 2wd so it didn't bathe in mud.
