Front Brake Baking Plate Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACOREVB, May 26, 2020.
  1. May 26, 2020 at 7:42 AM
    TACOREVB
    TACOREVB [OP] Member
    Grant
    2008 RED DCLB 4x4 TRD
    Hello,
    To start off, I am not looking to remove the plates or find a 2 piece version. I am going through the front suspension and replacing as much as I can to double the life of my 220kmi 2008 4wd. I have bluepit koyos on the way and am looking to replace the inner wheel seal and brake backing plate while doing the job.
    I have found them here:
    https://www.toyotapartsdeal.com/oem...ta&Model=Tacoma&Year=2008&Submodel=&Filter=()
    But I see 3 different part numbers (right side example): 47781-04030, 47781-04040, and 47781-04050
    Does anyone know what the variations are on these? or another link that will fit?
    Thanks -Grant
  2. May 26, 2020 at 10:48 AM
    Crow Horse
    Crow Horse Well-Known Member
    Central NY
    2012 DCSB TRDOR
    It would appear to be production dates and how you Tacoma is equipped. Just a guess....
  3. May 26, 2020 at 2:19 PM
    TACOREVB
    Grant
    I have a trd sport with tow package but I have no clue on option numbers or if its from the VIN. Do I need my original vehicle option sheet to figure out which one??
    Im considering just sanding and recoating the factory ones
  4. May 26, 2020 at 2:25 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    youre talking about the dust shield on the front brakes?? i took those off like at 20k miles back in 2009 :laugh: i wouldnt put them back on tbh
  5. May 26, 2020 at 3:15 PM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    Check "fitting vehicle options" with the ID sticker on your door jamb....
    TACOREVB[OP] and Gunshot-6A like this.
