Front brake HELP!
Discussion in 'Technical Chat' started by SantaCruz'n, Jul 27, 2010.
  1. Jul 27, 2010 at 2:30 PM
    SantaCruz'n
    SantaCruz'n [OP] Well-Known Member
    Logan
    Temecula
    Saving for the 2013
    When I was changing my front brakes today (2005 Prerunner) I noticed some brake fluid leaking from the caliper piston. Its just a little. Is this really bad? What do you guys think?
  2. Jul 27, 2010 at 2:33 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    it shouldnt leak.you need to replace the O ring around the caliper piston.
  3. Jul 27, 2010 at 2:47 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    x2. Fix it. Either replace the caliper or rebuild your current one.
  4. Jul 27, 2010 at 2:50 PM
    YeahYeah
    YeahYeah Well-Known Member
    Thomas
    (My Home - Murrieta, CA) Now, Alexandria, VA
    07 Tacoma Pre-Runner
    mud flaps gone, second air-filter gone, DTRL, fog light whenever and work with hi-beams, cut exhaust (was wicked flow), flat black stock rims, ABS switch, cup holder led's (with switch), turning signal mod #45, Bilstien 5100's, grill mesh
    ya and don't not do it bc when that shit hits the rotor...... BYEBYE!
  5. Jul 27, 2010 at 2:55 PM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
  6. Jul 27, 2010 at 3:06 PM
    SantaCruz'n
    Logan
    Temecula
    Saving for the 2013
    Should I be good to drive it for a little bit?
  7. Jul 27, 2010 at 3:10 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    for a few miles. then some oil gets on the rotors and you have brake failure. it can happen.
  8. Jul 27, 2010 at 3:14 PM
    SantaCruz'n
    Logan
    Temecula
    Saving for the 2013
  9. Jul 27, 2010 at 3:15 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
  10. Jul 27, 2010 at 3:17 PM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
  11. Jul 27, 2010 at 3:18 PM
    SantaCruz'n
    Logan
    Temecula
    Saving for the 2013
    This sucks, from an easy brake change to catastrophe. WTF?!?!
    Also, how do I air bleed the brakes?
  12. Jul 27, 2010 at 4:18 PM
    SantaCruz'n
    Logan
    Temecula
    Saving for the 2013
