Front Brake issues with new wheels & lift!
Discussion in 'Wheels & Tires' started by TPK555, Nov 25, 2010.
  1. Nov 25, 2010 at 7:45 AM
    TPK555
    TPK555 [OP] Member
    Scott
    VA
    '10 double cab 4wd
    3' Lift on 32's
    Just put new 275/65-18's on 18x9 wheels, along w/ 3" lift. Looks & drives great BUT.... during certain turning situations, at travelling speeds, and when road surfaces are random, especially any loose gravel or wet spots, the front brakes, on side or the other, will grab or pulsate as if the anti-lock is kicking in, causing a hard pull to one side or the other. Scary if not expecting it. All was good on the highways and typical road situations, only noticed when crossing the windy roads in the VA mountains. HELP!
  2. Nov 25, 2010 at 7:46 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!
    You need to have th VSC calibrated.
  3. Nov 25, 2010 at 7:47 AM
    jandrews
    '09 FourDubDee TRD OR
    Probably VSC kicking in. Some Tacomas after lift have problems with the VSC system. It needs to be recalibrated. See your dealer about that.
  4. Nov 26, 2010 at 5:55 AM
    TPK555
    TPK555 [OP] Member
    Scott
    VA
    '10 double cab 4wd
    3' Lift on 32's
    Thanks all! VSC seems to be the concensus on the issue. Will update with results of the re-cal.
  5. Nov 26, 2010 at 7:11 AM
    senna
    senna Well-Known Member
    San Jose CA.
    09 DBL CAB TRD-OR OME shocks 885 and AAL
    I agree with all the others, Just for the heck of it you can turn VSC off and see if your issue is gone.
