Front Brake Job (advice)
Discussion in 'Technical Chat' started by KodiakToyTRD, Nov 13, 2010.
  1. Nov 13, 2010 at 6:34 PM
    KodiakToyTRD
    KodiakToyTRD [OP] Well-Known Member
    CO
    2013 Scion FR-S Whiteout
    Picked up my front brake rotors and pads today at Carquest (I work there so major discount). Will be doing the install hopefully tomorrow along with the oil change.
    Is there anything special I need to know about Tacoma brakes, any quirks etc? I am familiar with vehicles, been working on or around them for about 10 years now but never worked on a Tacoma. Just looking for some insight before I dig in and get surprised on a Sunday afternoon with no auto parts stores open!
  2. Nov 13, 2010 at 9:30 PM
    KodiakToyTRD
    CO
    Bump. No body done any BJ's lately?
  3. Nov 13, 2010 at 9:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Nothing to worry about. Its about as easy a job as any vehicle can get.
  4. Nov 13, 2010 at 9:33 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    no real quirks, idk if 2nd gen is too different but just keep up with the shims and clips....no i havent done any bjs lately, have you? :eek:
  5. Nov 13, 2010 at 9:37 PM
    KodiakToyTRD
    CO
    Well there was this one time at band camp...:anonymous:
  6. Nov 15, 2010 at 10:52 AM
    CB6979
    CB6979 Active Member
    Mason, OH
    06 Tacoma SR5
    Tinted Tail Lights, De-Badged, Murdered Grill and Rear Bumper, DVD Head Unit, Tinted Windows. More to come when $$$ allows
    Just did mine. Easy job, but you have to BFH the rotors. They tend to rust to the hub.
  7. Nov 15, 2010 at 11:03 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Hey, it's only skin right...:rolleyes:
    Some things just shouldn't be reduced to akronyms...
  8. Nov 15, 2010 at 11:08 AM
    Peru
    Peru Well-Known Member
    Jonathan
    Redmond WA
    SR5 -- V6 -- 2005 -- 4X4
    none
    what happens if you do not use the shims?
  9. Nov 17, 2010 at 2:42 AM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    No need for the bfh....There are holes for jack bolts. Just find the bolt that fits and tighten them and the rotor comes right off..
  10. Nov 17, 2010 at 3:28 AM
    brians05taco
    brians05taco Well-Known Member
    Brian
    Lafayette,La.
    05 prerunner white debadged 4.0
    lifted, bedcover,BHLM, grill, etc...
    mine was a piece of cake not problems pad change even easier...
  11. Nov 17, 2010 at 4:17 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    usually it can result in brake noise
  12. Nov 17, 2010 at 4:20 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I hope the 2nd gens changed the design, because my first gen is a PITA. The 1st gens have 2 smooth pins that hold the pads in place and those pins are made of insta-rust metal, I had to heat them and let them soak overnight in PBblast to get them to slide out last time I did my brakes.
  13. Nov 17, 2010 at 5:59 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Make sure everything that is metal on metal contact is totally cleaned then coated with a thin coat of anti squeal coating. 3m makes a good one, works for the guide pins too.
    Don't reuse the guide pins if they corrode and/or seize, you get uneven wear or locked brakes. Clean all preservative off the new rotors and keep contaminents off the new friction material.
    +1 on the shims keeping the noise away. The pads vibrate when you brake, the shims help dampen it and so does the anti-squeal compound.
  14. Nov 18, 2010 at 8:33 AM
    CB6979
    Mason, OH
    06 Tacoma SR5
    Good Call!
