Front brake job
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Glocker23, Jun 8, 2015.
  1. Jun 8, 2015 at 1:06 AM
    Glocker23
    Glocker23 [OP] Drive fast take chances
    CT
    2012 DCSB Sport
    Debadged, Tonneau cover, Grillcraft MX grill, OKLED 20" light bar in grill, Aero AT2525 muffler
    So I need to do front brakes. I watched videos on it and feel it is something I can handle.
    Mainly looking to see if everyone is staying with a toyota stock pads and rotors? Or if aftermarket is preferred. Am honestly impressed with current stock setup so may stay with it or change just pads to aftermarket with stock rotors
  2. Jun 8, 2015 at 5:02 AM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    Personally I would stick with OEM pads, rotors you can go with after market.
    Just my 2 cents
  3. Jun 8, 2015 at 5:06 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I am using stock (original) rotors and installed a set of Wagner Severe Duty Brakes pads on the front...the rears still look good at 65K.
    Howard
  4. Jun 8, 2015 at 10:23 AM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    Rears should look good because the lion's share of the braking is done up front.
    As far as OEM vs aftermarket: if it ain't broke...
  5. Jun 12, 2015 at 10:32 PM
    Glocker23
    CT
    2012 DCSB Sport
    What are the part numbers for the front pads and rotors for a 2012 sport?
  6. Jun 12, 2015 at 10:42 PM
    Glocker23
    CT
    2012 DCSB Sport
    Also not sure if it matters or if I should upgrade but instead of stock tires I have Lt265/70/17s. So more tire than stock. Should I get stock rotors and ebc pads?
  7. Jun 13, 2015 at 4:23 AM
    hetkind
    Howard
    Johnson City
    only replace your rotor if they need replacing...and virtually any premium brake pad should work for you. I have used EBC on motorcycles for decades, but like the Wagner Severe duty on light trucks.
    Howard
  8. Jun 14, 2015 at 8:24 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You say OEM Stock Pads have worked fine so far. Why change? OEM stock.
    New pads so soon on a 2012? How many miles?
  9. Jun 15, 2015 at 12:32 AM
    jonkassidy
    jonkassidy Well-Known Member
    Huntington Beach Ca
    08 PreRunner SR5
    Limo tinted windows
    I just put the EBC yellowstuff pads on my 08 for towing and it really made a huge difference in how the truck stops. Just got back from a 800mile trip towing a 3700lbs trailer and I was throughly impressed with the braking power of the pads.
  10. Jun 15, 2015 at 12:42 AM
    Glocker23
    CT
    2012 DCSB Sport
    60k
  11. Jun 15, 2015 at 2:15 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    You must be hard on brakes...
  12. Jun 15, 2015 at 3:37 AM
    Glocker23
    CT
    2012 DCSB Sport
    Work mids with lots of highway. Also occasionally respond to ems calls. Also been haulinh a lot recently. A few times overloaded. Might be a little hard on them
  13. Jun 15, 2015 at 3:39 AM
    Glocker23
    CT
    2012 DCSB Sport
    Also have bigger tires now that r LT. So bigger heavier tire prob doesn't help
