FRONT BRAKE LINE HELP
Discussion in 'Suspension' started by XPOTRON, Feb 23, 2013.
  1. Feb 23, 2013 at 4:28 PM
    XPOTRON
    XPOTRON [OP] Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    Were all gunna be that guy once so here it goes, no time to search. Cant get the damn lines off the front and my 10mm wrench keeps rounding off!! :mad: is there a special trick to gettin them off?
  2. Feb 23, 2013 at 4:29 PM
    hudhawk
    hudhawk #texasforever
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Vise grips?
  3. Feb 23, 2013 at 4:30 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
  4. Feb 23, 2013 at 4:30 PM
    XPOTRON
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    No luck, and the nut is gettin worse
  5. Feb 23, 2013 at 4:32 PM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Tube wrench?
  6. Feb 23, 2013 at 4:41 PM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    The tacoma brake lines have very soft, aluminium like, nuts. The ideal tool to use on them is a Flare nut wrench. It will help reduce the chances of stripping the bolt head.
  7. Feb 23, 2013 at 4:42 PM
    PLC721
    Patrick
    Chandler, Az
    Davids the man!
  8. Feb 23, 2013 at 4:45 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    I F-ed up one of my rear brake threads, even with the tool it will be a hard bolt to loosen.
    I do recommend buying a quality 10mm flare nut wrench because the tolerances on the Harbor Freight wrench will fit loose and strip the thread
  9. Feb 24, 2013 at 10:09 AM
    XPOTRON
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    thanks pat and david! still didnt get them off since we didnt have a flare nut wrench layin around, in the mean time we kinda stretched everything down and theres plenty stock brake line to be had.
