Front Brake Pad/Rotor Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gatortrades, Feb 20, 2010.
  1. Feb 20, 2010 at 11:23 AM
    gatortrades
    gatortrades [OP] Member
    05 Doublecab, PreRunner, SR5, TRD Off-Road
    Might be a stupid question, but if your truck is in park, will the brake pads rub against the rotor when you rotate the tire? I was changing my front driver tire and when I spun the rotor around, the pads were in contact with the rotor.
    When it is in park, what brakes stop the wheels from moving? Thanks.
  2. Feb 20, 2010 at 11:27 AM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    No, it should spin. Even in park. If you press the brake pedal, THEN they wont spin. Even if you set the emergency brake, the fronts will continue to rotate. It only locks the rear.
  3. Feb 20, 2010 at 11:57 AM
    gatortrades
    Thank you.
    so if they should spin free, there should be no contact at all. They don't keep the wheel from spinning, but I can hear the contact when I spin the rotor. So what should I do with that? Mechanic?
  4. Feb 20, 2010 at 12:15 PM
    badguybuster
    Michael
    No, the pistons only release far enough to allow the wheels to spin. So, yes, you may hear a slight noise and the rotor spins along the pads.
  5. Feb 20, 2010 at 1:31 PM
    buck
    buck the-eh-team.com
    Ontario, Canada
    08 DC V6 4x4 TRD Indigo Ink
    High-flow coconut smiley-face air freshener.
    It's just a bit of light brake drag, completely normal.
