Front brake pads, should I use lube?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by timothom, Jun 11, 2019.
  1. Jun 11, 2019 at 8:22 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Ah that's hot! :)
    Sideways1[QUOTED] likes this.
  2. Jun 11, 2019 at 8:46 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I should have bought all new hardware like that! Mine was still fine, just not pretty.
  3. Jun 12, 2019 at 5:14 AM
    timothom
    timothom [OP] Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    I appreciate the insite. There is a noise I should chase instead of throwing parts at it. I have a manual tranny, I engine brake pretty well, and my truck has been lightly used. If 50k is early then I probably have lots of pad left.
    There is a sounds that annoys me, I can hear it when the windows are down. It's constant, quiet, and it changes with the ground speed of the vechical. It also goes away when I give a slight brake tap. So I was thinking it was the tweeters telling me the pads are gone. I had no idea there was a secondary spring kit to prevent this from happening.
  4. Jun 12, 2019 at 5:58 AM
    weeksz
    weeksz Well-Known Member
    Adam
    Traverse City, MI
    2017 DCLB Limited
    Stickers mostly
    I just had some noise (low grinding sound) front the front of my 2009. Figured it was brakes but I couldn't feel anything in the pedal. Visual inspection with wheel on showed lots of pad life left. When I removed the wheel I saw that one of the inside caliper pistons was siezed and wore my pad diaginally all the way down the backing plate. New pad, new rotor, new caliper. Gas milage gas gone up 3mpg since.
    Does it drive straight under hard braking?
  5. Jun 12, 2019 at 6:03 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C DCLB TRD SPORT
    I lubricate any moving part on the caliper assembly, especially up here in Canada.
    EdgemanVA and timothom[OP] like this.
  6. Jun 12, 2019 at 8:27 AM
    timothom
    Seems to drive straight under hard brakeing.
    I live in a hard winter/salt on the roads area. I'm definatly going to have to jack up and take off the front wheels this weekend for a look. Probably be cleaning/lubing everything up in the front. Damn road salt.
  7. Aug 16, 2020 at 3:38 PM
    rickydood
    rickydood Member
    2012 M. Gray Prerunner
    Ooh what brake pads and rotors are those? Love em!
  8. Aug 17, 2020 at 6:24 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    I also dab a little grease on the back side of the pads. Not anything heavy, just where it touches the pistons.
  9. Aug 17, 2020 at 7:13 AM
    Lgeekdws
    Lgeekdws Well-Known Member
    2015 Magnetic Grey V6 4x4 SR5
    In addition to lubing the pins, I use the red anti squeal goop on the back of the pads at contact areas to the caliper. The one time I didn't on my Audi the damn thing sounded like a railroad locomotive doing an emergency stop.
  10. Aug 17, 2020 at 7:17 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Noise does not necessarily mean you need new pads...
    EdgemanVA likes this.
