Front brake pulsation
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ancientangler, Nov 20, 2017.
  1. Nov 20, 2017 at 9:49 AM
    Ancientangler
    Ancientangler [OP] New Member
    2002 Tacoma 4WD TRD
    Aside from worn rotors, is there anything else which might cause a pulsing sensation in the brake pedal? The pads have about 6mm left on them. I have an excellent mechanic, but he's sometimes more of a pefectionist than my budget can stand at the moment. As much as I'd like to have everything brand new at the same time, I can't at the moment. So, I'm thinking "just rotors". The mechanic says "I'd rather not..."
    The pads are a real mystery. They have about 110K miles on them. They're still smooth, no glazing. I've never gotten mileage like that on front pads.
    Thoughts?
  2. Nov 20, 2017 at 10:03 AM
    TaCoJoE650
    TaCoJoE650 Cars are the sculptures of our everyday lives.
    Joey
    Bay Area
    99 tacoma 2WD 2.4L
    You wanna do pads whenever you replace/resurface rotors. Sounds like rotors are warped. Wouldn't bother turning at this point. Just do it right the first time.check caliper slides and make sure nice and smooth while in there. Rotors get warped due to overheating and can also be caused by calipers slides sticking.
    Just my 2centd though
    kgt0001 and wilcam47 like this.
  3. Nov 20, 2017 at 11:19 AM
    guacamoleparty
    guacamoleparty Member
    2001 SR5 Access Cab PreRunner
    I had pulsing in brakes on on 01 and it was dirty brake fluid. Complete exchange of fluids removed the problem (thought it was warped rotors), worth a look!
  4. Nov 20, 2017 at 11:38 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    The difference in cost to upgrade to Tundra brakes is not that much more. Then problem solved for good.
  5. Nov 20, 2017 at 11:44 AM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    New rotors with old pads is like flushing money down the toilet. This is a simple job. Why pay someone to do it.
    wilcam47 likes this.
  6. Nov 20, 2017 at 11:47 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    yep easy as taking off the tire! once you do that you are half way through it ;) Sounds like rotors and pads need changed.
