Front brake question
Discussion in '1st Gen. Tacomas (1995-2004)' started by hardtaco, Jun 1, 2009.
  1. Jun 1, 2009 at 3:35 AM
    hardtaco
    hardtaco [OP] Well-Known Member
    Sarasota, FL
    08 PreRunner DCSB
    I am getting ready to replace my front brake pads again after putting only 20,000 miles on them in 2 years. I guess I bought some garbage pads. My question is, if using non OEM pads, do I install the metal plate spacer on the back side of my new pads, as the originals had? I put them on the last time I changed the pads out, and I am wondering if I should have left them off for any reason.
  2. Jun 1, 2009 at 5:37 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Yes, you should put it back on.
  3. Jun 1, 2009 at 6:32 AM
    ViperR
    ViperR Active Member
    NC
    bare-bones
    Some pads, such as NAPA, include new spacers that have an adhesive peal-off that you atatch. Some have a plate riveted on to the pads base and you don't re use the OEM spacer.
  4. Jun 1, 2009 at 9:05 AM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    Depends on the Pad.
  5. Jun 1, 2009 at 10:01 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If the new pads don't have an extra pad or steal sheeting (squeel stopper),then YES ...you need to install them.
  6. Jun 1, 2009 at 7:15 PM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    get the ceramics! amazing stoping power, no squeel and a lot less dust! worth the extra cash! HANDS DOWN!
  7. Jun 1, 2009 at 7:37 PM
    PrezidentRedz
    Redz
    Owings, MD
    Actually Ceramics have less stopping power! I just ordered the Porterfield Kevlar Carbon Pads, and Slotted and Drilled Rotors. there going to make alot of Dust but I will be able to stop my damm truck! lol :D
  8. Jun 2, 2009 at 4:06 AM
    Janster
    Jandy
    Lancaster, PA
    The pad material itself doesn't have anything to do with the anti squeel shim that we're referring to. You still need the shim regardless of pad material. It helps prevent squeeks/squeels when you're NOT on the brakes.
