Front Brake Replacement Kit?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tyler Andrews, Oct 31, 2017.
  1. Jan 31, 2018 at 8:34 PM
    #41
    Tyler Andrews
    Tyler Andrews [OP] Well-Known Member
    Tyler
    Portland
    2018 Super White Sport 4x4
    I was referring to the Summit z36 brake kit. Are you referring to the tundra brake upgrade?
  2. Jan 31, 2018 at 8:34 PM
    #42
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Yeah - are those not 13WL calipers?
  3. Jan 31, 2018 at 8:38 PM
    #43
    Tyler Andrews
    Tyler
    Portland
    To be honest I have no clue
  4. Jan 31, 2018 at 8:46 PM
    #44
    BartMaster1234
    Tyler
    Flux Capacitor
    They look like it to me. That's the brake upgrade that you want - the Tundra and Sequoia used 231mm brake calipers which was called the 13WL.
    Those will fit but you need to trim your dust shield and use the correct brake lines. LC Engineering and Wheelers sell the lines and hardware. I recommend LC Engineering's kit because it uses the hard flared lines instead of the banjo bolt the Tacoma uses.
  5. Jan 31, 2018 at 8:58 PM
    #45
    Tyler Andrews
    Tyler
    Portland
    I appreciate the insights man! ordering up!
  6. Jan 31, 2018 at 9:31 PM
    #46
    1997tacomav6
    Denver
    Do you have 16" rims??
    BartMaster1234 likes this.
  7. Jan 31, 2018 at 10:13 PM
    #47
    BartMaster1234
    Tyler
    Flux Capacitor
    No problem. I just want to confirm that you have 16" rims, they won't fit otherwise.
  8. Feb 11, 2018 at 12:24 PM
    #48
    Tyler Andrews
    Tyler
    Portland
    Yes I have 16' wheels.
    Currently installing the kit, passenger side went really well, however, I am encountering an issue with the driver side you guys might be able to help with. I am installing wheeler's front brake lines and the banjo bolt isn't fitting properly into the caliper. It will NOT screw all the way down to the point where there isn't any play. I have the two copper washers on and it still spins after being torqued down properly. Possibly need another washer for a total of 3 or 4?
  9. Feb 11, 2018 at 12:44 PM
    #49
    tony2018
    tony2018 Well-Known Member
    You might have to drill the end of the banjo bolt. I think thats what some have said about using wheelers.
    This is probably the 2nd time someone has claimed this issue. I wonder what changed on wheelers end?
  10. Feb 11, 2018 at 1:43 PM
    #50
    1997tacomav6
    Denver
    Did you try switching the passenger bolt for the drivers side bolt that you know that works. If the passenger bolt works on both calipers then you know the other bolt is no good, if the passenger bolt doesn't work on the drivers side, then you know it's the caliper.
    Sicyota04 likes this.
