Front Brake Replacement Trouble
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BeaverYota, Feb 14, 2015.
  1. Feb 15, 2015 at 12:20 PM
    devkurf
    devkurf Member at Large
    midwest
    thats not a tacoma, just an illustration of how to do it with that setup
  2. Feb 15, 2015 at 12:21 PM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
  3. Feb 15, 2015 at 12:24 PM
    JBecker
    JBecker Well-Known Member
    Virginia
    2015 AC SR 4X4 2.7 Manual
    My 05 4Runner seized a piston on one of the calipers. This was at about 80,000 miles. Seems like a common issue on these trucks. I got a re manufactured one for it.
  4. Feb 15, 2015 at 12:26 PM
    devkurf
    midwest
  5. Feb 15, 2015 at 12:59 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Just have to make sure you are doing it at the same time not to mess up the abs shit. Atleast that's what I read lol.
  6. Feb 15, 2015 at 1:07 PM
    BeaverYota
    BeaverYota [OP] Oregon State Edition
    Josh
    Lake St. Louis, MO
    Sold...
    I do want to ask, how do you do the c clamp method. Cause I couldn't get it to work for me, mostly because I could not find an effective way to hook it up. The picture didn't help me much cause its not a tacoma caliper.
  7. Feb 15, 2015 at 1:25 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Its the same theory with the c clamp and wood block. How can you not understand how to do it after looking at that picture? The only thing being done wrong is the c clamp is applying pressure on one side when it should be being distributed evenly.
    Take a picture of what your calipers look like since they are different.
  8. Feb 15, 2015 at 1:32 PM
    BeaverYota
    Josh
    Lake St. Louis, MO
    Sold...
    Look I'm not stupid if that's what you're thinking.
    I have the fixed brake caliper. Are you taking the caliper off to use the clamp? I've never bothered to take the caliper off if I was just replacing the pads. So if it has to be taken off to use the c clamp method, then that's why I'm not getting it in my head is cause I was just visualizing it on the rotor. I can't take a picture because everything is assembled right now.
    But that picture looks like it's only one side of a caliper and it's taken off the rotor. I don't even see where the other side would be, was it completely removed?
  9. Feb 15, 2015 at 1:44 PM
    JBecker
    Virginia
    That pic is of a floating caliper.
  10. Feb 15, 2015 at 1:48 PM
    JBecker
    Virginia
    And I'd suggest pulling the caliper off. It will make it much easier to free it up, or determine if you need a replacement.
  11. Feb 15, 2015 at 1:53 PM
    devkurf
    midwest
    Its gonna look like this, just with one on each side. You can do it with them on. In place of the wood you can use the old pads to press the c-clamps back on if you arent putting them back on. You may have to crack the bleeder open a little to let the pressure off. Just make sure to keep the master cylinder topped off with fluid.
  12. Feb 15, 2015 at 1:54 PM
    BeaverYota
    Josh
    Lake St. Louis, MO
    Sold...
    Gotcha. That makes more sense. Gonna say the block of wood wouldn't fit in there, especially if I left the caliper on. Makes more sense knowing that was a floating caliper. Thanks for the help guys. It's all clear now.
  13. Feb 15, 2015 at 1:55 PM
    devkurf
    midwest
    sorry the pic didnt show up in my last post
    [​IMG][/IMG]
  14. Feb 15, 2015 at 1:57 PM
    BeaverYota
    Josh
    Lake St. Louis, MO
    Sold...
    Now that makes more sense. Awesome. Thank you.
    I just have to wait for my parts to come in so I can replace my calipers and all. Thanks guys
    Pretty much I'm gonna replace the calipers, brake pads (already have), new rotors are already on, and there will be stainless steel brake lines I'll install as well, hopefully fixing the squishy brake pedal feeling.
  15. Feb 15, 2015 at 6:23 PM
    #35
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Glad to hear you figured it out man. I know you aren't stupid, and I definitely understand that some things or guys are just more visual than others who might understand by just read in it. I'm definitely more visual.
