Front brake rotor removal on PreRunner
Discussion in '1st Gen. Tacomas (1995-2004)' started by hardtaco, Jun 3, 2009.
  1. Jun 3, 2009 at 4:42 PM
    hardtaco
    hardtaco [OP] Well-Known Member
    Sarasota, FL
    08 PreRunner DCSB
    What all is involved in removing the front brake rotors on a 2004 Tacoma Double cab PreRunner 3.4L ? Do they just slide off of the wheel studs, or is there more to it than that?
  2. Jun 3, 2009 at 5:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Remove the caliper, and they will slide right off. :)
  3. Jun 3, 2009 at 6:36 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep.......easy as pie!!
  4. Jun 4, 2009 at 2:07 AM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    Pie is good!!!
  5. Jun 4, 2009 at 2:30 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    unless there rusted on, then just hit the rotor with a hammer
  6. Mar 10, 2012 at 4:21 PM
    Astro Bob
    Astro Bob New Member
    Bob
    Upland, CA
    09 PreRunner SR5 6 Lug
    I'm not sure if the 5 lug rotors have them, but 6 lug rotors have two threaded holes on opposite sides of the hub. Just thread the proper sized bolts into those holes and tighten uniformly. If you've saturated the hub/ wheel studs with penetrating oil (while tapping on the edge of the old rotor) and alternately tightening the 2 bolts- you should eventually hear a loud POP. Hopefully, that will be the sound of the rotor breaking loose and nothing else :) The good news is, using this method lowers the chance of messing up the wheel bearings.
  7. Mar 10, 2012 at 10:59 PM
    Astro Bob
    Bob
    Upland, CA
    I was amazed to find that the rotors that were sold from a major auto supply chain did not have those two threaded holes on either side of the rotor hub- used for removal. After some measurements I found the factory specs are: a "H" bit (metric)- 6.7564 mm. or .26600 inch or slightly larger than 17/64". The tap for the threading would be: 8 mm. with a 1.25 mm thread pitch- 6.900 mm dia. or .27165 inch dia. Adding these two holes will make future rotor removal a snap- no hammering required.
