Front brake rotors warped after 15000 miles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nyebone4x4, Jun 21, 2016.
  1. Jun 21, 2016 at 5:56 PM
    nyebone4x4
    nyebone4x4 [OP] New Member
    2015 White Tacoma 4x4 TRD
    My 2015 Tacoma 4x4 needs the front rotors to be replaced after 1500 miles. Nasty shimmy braking at about 50 mph going down hill. The dealer is gonna make it right. Anyone else out there have this issue?
  2. Jun 22, 2016 at 4:07 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    GPsevinSixx, tomwil, 06Tacooo and 5 others like this.
  3. Jun 22, 2016 at 4:36 AM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    An out of balanced front wheel causes the same effect.
  4. Jun 22, 2016 at 5:32 AM
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    Read their instructions for bedding new brakes. How do you clean the pad material if they were improperly bedded the first time?
  5. Jun 22, 2016 at 5:58 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Obviously there is something wrong with the brakes. Could be seized causing them to be rubbing.
    Make sure you get an answer as to what was causing the problem and don't just accept them turning the pads and rotors.
  6. Jun 22, 2016 at 6:20 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    I've used the Zeckhausen procedure on my past vehicles to fix brakes that were improperly bedded when new. Basically the goal of the procedure is to do repeat hard stops from high speed so that you make everything hot enough to burn off the deposits.
    If you do the procedure right, the rotors will get glowing hot and once they cool down they'll have a nice blue/brown color that indicates they've been hardened. At that point, they are less likely to form deposits again.
    digitaLbraVo likes this.
  7. Jun 22, 2016 at 7:17 AM
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Thanks!
  8. Jun 22, 2016 at 8:30 AM
    2015WhiteOR
    Gainesville TX
    If you do the procedure, it is important that you avoid coming to a complete stop until the rotors have cooled completely.
    I went out and found a section of highway that wasn't very busy because I intended on pulling over onto the shoulder for each stop. You definitely don't want to stop in the middle of the road, and you don't want to rely on stopping at stop signs or traffic lights.
    While at full speed (in my case around 70 mph), brake as hard as you can, without engaging ABS, while pulling onto the shoulder. As soon as you're around 5 to 10 mph, speed back up and merge back onto the highway. As soon as you hit full speed, repeat the stopping procedure. Do this a few times and then find some way to drive around for a good 15-20 minutes without coming to a complete stop. What you want to avoid is allowing the brake pads to rest against the extremely hot rotor since that will screw up the procedure.
  9. Jun 22, 2016 at 8:33 AM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    Drive through water recently? Could warp the rotors by sending them hot into cold water.
  10. Jun 22, 2016 at 8:34 AM
    digitaLbraVo
    Interesting proces!
  11. Jun 23, 2016 at 5:36 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Go through Post # 1. It has a lot of good links.
  12. Jun 23, 2016 at 6:27 AM
    SocalTaco15
    SocalTaco15 Well-Known Member
    Glen
    Socal, Orange County
    Can confirm. My rotors had that warped feeling at 10 k, but it is better after I used that procedure.
    DVexile and ChadsPride like this.
  13. Jun 23, 2016 at 9:49 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Standard procedure for bedding in brakes.... do it on all my vehicles, makes brakes last longer and stop better over their life. SUPER noticeable on motorcycles where you have fine control with your hands.
  14. Apr 7, 2017 at 11:30 AM
    Championsumo
    Championsumo Well-Known Member
    Tulsa, OK
    2015 DCSB 4X4 TRD Sport
    I took mine in today at 27k for the same issue. Dealer logged it as improperly machined rotors, turned the rotors and replaced pads under warranty. All is good.
  15. Apr 8, 2017 at 4:48 AM
    PackCon
    Connor
    I feel the need to say, it takes a pretty significant amount of heat to warp a plate of metal like a rotor. Most people do not do this unless they race with high performance breakes or have been doing a lot of mountain driving.
    Warped rotors need to be thrown out. You can't "turn" them. What is happening is people usually are slamming on their brakes often enough to heat the rotor and pad so when you come to a complete stop some of the brake pad material burns onto the rotor. Do this enough and the braking surface becomes uneven giving you a shimmy while you drive.
    This is why bedding should be done on new brakes. Crates a better, even friction surface for braking.
    Warped rotors are NOT the issue 99% of the time. It's become a misused term, leading people to piss away more money in brake shops.
    2015WhiteOR and DVexile like this.
  16. Apr 8, 2017 at 5:03 AM
    Clearwater Bill
    Billy
    Largo Florida
    To be more specific to what @Jimmyh says above, rotors don't warp.
    http://www.stoptech.com/technical-support/technical-white-papers/-warped-brake-disc-and-other-myths
    They do get 'warped feeling' from improper bedding and/or low grade pads.
    They do eventually wear beyond a serviceable thickness. But since they are harder than pads, that normally takes 2-3 sets of pads.
    So, when your tech 'dresses' the rotor, they are basically skimming off the old pad material, and maybe enough metal to smooth out any grooving that has occurred.
    The nice thing about the 'on vehicle' unit mentioned above (as opposed to a regular brake lathe) is that it accounts for any run out error that may be in the actual hub assembly. I don't know about recent years, but for a long time the on vehicle method was the only way to turn/clean rotors on a Honda product, because the effort to remove/change them was ridiculous.
  17. Apr 8, 2017 at 2:46 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    I take exception to that report as I distorted the crap out of the front rotors on my 2003 Mustang Cobra just by rapidly decelerating to shed 75 mph in 1/3 mile or so--it was the 75 mph between 145 and 70.
    It was early summer of 2006, I had been cruising along minding my own business on I-10 Eastbound west of Lake City FL--it was early in the evening--when the "threat detector" went off solidly. My experience with that older radar unit was that I had 1/3rd mile or so before the radar would get a fix, so I dropped it into 5th gear and stood (literally) on the brakes; the brakes made a terrible squawking and cabin filled with putrid smoke; I made it but I'd bet the rotors were glowing cherry red as I went by that cop.
    They were warped visibly, looked like big belleville washers...
  18. Apr 8, 2017 at 3:14 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
  19. Apr 8, 2017 at 3:23 PM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    That does not happen.
  20. Apr 8, 2017 at 3:23 PM
    JayRolla
    Colorado Springs
    Pics?
