Front brake upgrade anyone?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kimchi Taco, Dec 15, 2017.
  1. Dec 15, 2017 at 9:27 PM
    Kimchi Taco
    Kimchi Taco [OP] Well-Known Member
    ATL
    17 TRD OR 4x4 Manual
    Interested in upgrading my 17 taco front brakes? Did some research and it seems that 5th gen 4runner brakes would work. Has anyone done one on a 3rd gen?
    srdoublecab2.7 likes this.
  2. Dec 15, 2017 at 9:30 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    3rd gen is basically a pretty 2nd gen, 5th gen Runner brakes will fit on the 2nd gen, they should fit on the 3rd gen. They are indeed larger, this may make your ABS and load sense freak out, also as you have to move more fluid with the same size master cylinder your braking make feel weaker and your pedal will be slightly lower.
  3. Dec 17, 2017 at 10:39 PM
    Kimchi Taco
    ATL
    Did not consider the sensors being an issue. Appreciate your input. Have you done the upgrade on your gen 2?
  4. Dec 17, 2017 at 10:59 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Are Tundra brake upgrades a thing on 3rd gens? A common mod on 1st gens and 3rd gen 4Runners are upgrading to the 231mm Tundra calipers. I have the 13WL Tundra/Sequioa calipers on my '98.
    I can imagine the newer generations Tundra has much beefier brakes than the 4Runner or Tacoma.
  5. Dec 17, 2017 at 11:50 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    This isn't a concern. The increased braking torque provided by the larger diameter rotors will allow for increased brake force from the same pedal travel, the brakes shouldn't feel weaker.
    I would not expect any issues with the ABS/sensors, but have no personal experience specifically with a 2016+ Tacoma and Crawl Control, etc., however I would expect it should be fine. For example, any big brake kit Toyota/Lexus has released has never included a recalibration for the ABS/VSC/etc.
    The 2005+ 4WD Tacomas already have the larger brakes that people like to use on the older Tacomas and 4Runners. It wouldn't be an upgrade unfortunately.
    Jeff
    solscooter likes this.
  6. Dec 18, 2017 at 12:06 AM
    Rogues Gambit
    Rogues Gambit Well-Known Member
    Colts Neck, NJ
    '07 A4, Planning on ordering soon
    Well, keeping on eye on this thread, as I can't leave anything stock for long and might as well see what's recommended
  7. Dec 18, 2017 at 12:10 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    TBD
    The tundra also has a different lug pattern, so those disks are definitely a no go. But yeah 2nd and 3rd gen tundra disks are beef.
    Rogues Gambit likes this.
  8. Dec 18, 2017 at 12:15 AM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Is this quest for bigger/better brakes due to a lack of stopping power from big tires, excessive speed, other?
    Or just upgrading to be upgrading?
  9. Dec 18, 2017 at 1:56 AM
    networkraptor
    networkraptor Well-Known Member
    2023 NBM ORP
    I've done big brake upgrades on several different cars (Ford, Subaru, and VW) and have never had this issue with ABS sensors or weaker brake feel. Why would this be an issue on a Toyota?
  10. Dec 18, 2017 at 3:47 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Sell the turd gen and buy a 4runner
  11. Dec 18, 2017 at 4:27 AM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Just that, appears to be changing for the sake of change. If you want better response, try a different pad, higher temp fluid or braided brake lines if you think that's needed first.
    I've got plenty of stopping power with my OR in stock configuration.
    su.b.rat and phsycle like this.
  12. Dec 18, 2017 at 4:48 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Well I have Tundra brakes on my 4runner. The abs kicks in a lot easier. If slightly applying the brakes and you hit any size bump the abs will engage as before they wouldn't. Also they "feel weaker" because the pedal engages slightly lower causing a sponge like feeling brake pedal.
  13. Dec 18, 2017 at 7:22 AM
    skyking3
    skyking3 Well-Known Member
    Tom
    2016 Silver Tacoma SR5 DCSB
    TRD cai, TRD cat back, JFR y pipe,Wilwood BBK,LEDs, Limited Homelink mirror,debadged,WeatherTechs,Dynamat Extreme sound deadening,sabm second snorkle to fender, Huper Optik ceramic tint, TRD Sema wheels, aerodynamic under body pan, OEM Audio Plus 500Q reference system, Depo faux pro headlights, real pro fog lights, OV tune, OEM aluminum filter housing, Mobtown IFS skid,TRD oil cap,TRD radiator cap, Osram Night Breaker 150 halogen headlamps, Fumoto valve,dashboard blackout,OEM tailgate power lock, MESO steering wheel logo, MESO two color dome light, TRD Pro coilovers, Artec LCA skids, Volk TE37 XT forged wheels, Roadmaster Active Suspension Garmin Minicam, Garmin minicam II
    Wilwood just came out at Sema with a big brake kit with 6 piston calipers for Tacomas that are made to be used with the stock master cylinder. They also make upgraded brake pads that fit with the OEM brakes. These are the brakes that Jay Leno recommends and uses for his vehicles. The link below will give you more information. Hope this helps.
    http://www.wilwood.com/BrakeKits/Br...oyota&model=Tacoma&option=4+x+4+(6+Lug+Wheel)
  14. Dec 18, 2017 at 8:38 AM
    Kimchi Taco
    ATL
    I beg to differ. The brakes on the current gen are just adequate. Fading is the biggest gripe I have with my brakes. Figured upgrading to the slightly bigger setup should help.
  15. Dec 18, 2017 at 8:41 AM
    Kimchi Taco
    ATL
    They are nice but not willing to drop that much on my truck for front brakes. Thanks for the link though, didnt know they made them for the current tacos.
    skyking3[QUOTED] likes this.
  16. Dec 18, 2017 at 9:23 AM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Like I said, try a different pads and a higher temp fluid: different compounds react better as brakes heat up reducing fade.
    Braided brake hoses resist expansion unlike rubber hoses giving a firmer pedal feel.
    Are you towing a lot causing the fade?
    su.b.rat and Clearwater Bill like this.
  17. Dec 18, 2017 at 9:25 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Im going with the stoptech 6 piston route since they have a 30 percent off sale on them and I got dirties with armor. If you don't have any extra weight, is there a reason why you want to upgrade the brakes? I just want mine to be snappy like how my truck used to be stock, but I got a second gen so who knows if the third gen brakes are different?
  18. Dec 18, 2017 at 9:33 AM
    Clearwater Bill
    Billy
    Largo Florida
    Fade is heat related.
    What are you doing to generate so much excess heat?
    Boghog1 and jsinnard like this.
  19. Dec 18, 2017 at 10:51 AM
    Key-Rei
    Key
    Florida
    Not saying it would, just saying it might. ;)
  20. Dec 18, 2017 at 11:03 AM
    su.b.rat
    su.b.rat broken truck
    seriously, try pads first. if you want more feel while you forcefully modulate, then try SS lines. both these mods are cheap and easily un-doable (is that a word?).
    i had a set of $3500 Wilwood racing brakes on my '70 A body with massive rotors and all the stuff. they sent me wrong pads and, until i got those replaced with the correct street use pads, these new high money brakes were unusable. the fix? the correct pads for $115.
    Clearwater Bill and jsinnard like this.
