Front brake wear on my tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Paulrv6, Jan 22, 2017.
  1. Jan 22, 2017 at 4:09 PM
    Paulrv6
    Paulrv6 [OP] Well-Known Member
    paul
    2005 Tacoma
    Hi folks just joined this forum. I have a 2005 tacoma with 44000 miles and the break pedal feels real low. I use the truck for pulling my boat and highway travels, not allot of stop and go. The calipers do have a ridge from the wear so they appear to be worn down. Is this normal for this mileage? It seems like I have to press the pedal down fairly hard to get it to stop. What should I replace them with with? Thanks for the help.
    paul
  2. Jan 22, 2017 at 4:11 PM
    Bishop84
    Bishop84 Well-Known Member
    Ridge wear is usually attributed to aftermarket pads in my experience. Seized sliders usually cause premature wear on the whole pad. Same with seized calipers.
    Use OEM and you'll have less headaches. Make sure to press the calipers all the way back to ensure they are free.
    Also, adjust your rear drums! It can make a huge difference in pedal feel.
    Pabloeeto and Rambo54 like this.
  3. Jan 22, 2017 at 4:16 PM
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
    Have your rear brake shoes adjusted (or DIY), Last summer I replaced my rear shoes and didn't adjust them out enough (closer to the drum) and as soon as I hit my brakes the pedal sank to the floor. After adjusting it with a tad bit of drag it went back to normal.
    You could have air in the system as well, but I would start with adjusting the rear before bleeding the system.
  4. Jan 22, 2017 at 4:18 PM
    Pabloeeto
    Paul
    San Diego
    Also to expand on my previous post, if the rear drums are out of adjustment, they won't contact the drum under normal braking. This causes the fronts to do all the work and they'll wear quicker.
    spitdog likes this.
  5. Jan 22, 2017 at 4:26 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Calipers self adjust as the pads ware. That is why the brake fluid level goes down (it fills the void) as the pads ware a very good indication of pad ware if it's full with new pads when it gets to add you need to have a good look at your pads. The pads do not cover the entire rotor they will leave a line as all of the brakes parts ware rears are the same way. Rears to some extent self adjust but it is only enough to keep the pistons from coming out of the bores (big problem with long ago brakes) so a rear brake adjustment may also be in order.
  6. Jan 22, 2017 at 6:07 PM
    Paulrv6
    paul
    2005 Tacoma
    Thanks for the reply. I bought this truck new so I know the history. Don't front brakes wear out long before rears do on all vehicles? There is a ridge about 1/4" from the OD of rotor. They are currently what was put on from the factory. Thanks
    paul
  7. Jan 22, 2017 at 11:20 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    That ridge is normal, happens all the time.
  8. Jan 23, 2017 at 12:40 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Rear Brake Adjustment from the shop manual:
    Note: the Bolded in Parenthesis is my words.
    ADJUST REAR DRUM BRAKE SHOE CLEARANCE
    (a) Provisionally install the hub nuts. ( Lug Nuts to hold the drum in place ).
    (b) Remove the hole plug, and turn the adjuster to expand the shoe until the drum locks.
    (c) Using a screwdriver, release the adjuster 15 notches.
    (d) Install the hole plug.
  9. Jan 23, 2017 at 1:43 AM
    Doug2000
    Doug2000 Well-Known Member
    London, Ontario, Canada
    2017 Tundra 5.7L
    My truck has 85000 miles, original brakes on the back, the front, I machined the rotors and new pads at 65000 miles. I only use Toyota parts, there is a difference.
    Adding, lots of highway, but also lots of towing trailers without brakes.
  10. Jan 23, 2017 at 1:59 AM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    In am not knocking the OEM stuff but I recommend you put a set of adaptive one pads in the front along with premium rotors from Napa. I changed mine from OEM at 35k due to mostly city driving and these pads normally last 70k. It is what most of your police departments use and is an awesome pad. It's all I use. Change the rotors just to make the job easy.
    Also if the pins your pads ride on inside the caliper have corrosion on them go ahead and get new ones. They are less than $5 I think.
  11. Jan 23, 2017 at 5:00 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Yes the rears will out last the front brakes at least 2:1 because of the weight transfer when you brake. In your case I would inspect the rears more than any thing else it maybe your only chance. The rear drums untouched become good friends and they can be a real problem to get off at 200K (yes you guys I know all about the bolts to remove the drums and all so about the fact a stuck drum will rip the threads out). Most likely a good cleaning and some anti seize on the axle and drum will be all you need.
  12. Jan 23, 2017 at 5:22 AM
    nh_yota
    nh_yota Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    My Tacoma is coming up on 85k miles with original brakes front and rear. The fronts are due for replacement but have not worn down to the wear indicators yet. I have all the parts but don't have the time.
  13. Jan 23, 2017 at 5:26 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    In that case I hope you bought new rotors.
  14. Jan 23, 2017 at 5:51 AM
    nh_yota
    Jeff
    Portsmouth, NH
    Yes - pads, rotors and pins.
    The problem is that the pins are seized and I need to find time to get them out.
  15. Jan 23, 2017 at 6:56 AM
    gearcruncher
    Canadain bumper technician
    I have a 2010 trd sport with the 5 speed automatic .
    I take the brakes apart every spring and fall , clean them up , lube them up as well as adjust them and put them back into service .
    Still running factory brakes at 200k
    Using the e brake every time you park is what they recommend and I follow this as religion
    If you spend the time , your brakes will last a lifetime .
    If you consider the environment your brakes have to function properly in , taking some extra measures pays off .
    fla_sun likes this.
  16. Jan 23, 2017 at 2:47 PM
    Paulrv6
    paul
    2005 Tacoma
    Wow this was great as far as all the response. But my original question was at 44000 is it typical to get enough wear on the front pads/rotors to cause the pedal to be significantly lower? These are all original factory components. I am going to inspect and adjust the rear brakes and measure the front rotors and check the pins to see if they are bound. I am going to replace the pads and rotors regardless so does toyota make a higher performance rotor/pad combination for the tacoma? I probably will stay with toyota parts but would like more positive stopping power. It doesn't feel like I could stop real quick if I wanted. Thank you again.
    paul
  17. Jan 23, 2017 at 3:30 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    Lemme add a few thing I didn't see in the responses. I've had 2 Toyota Service Reps that own Tacoma's and others on this forum, recommend staying with OEM Pads & Rotors.
    I'm looking at "Towing Duty" Pads, tho more brake dust. There are good aftermarket alternatives.
    Search TacomaWorld for some recommendations
    There is a TRD Brake Upgrade for a couple grand
    You might consider Stainless Steel Brake Lines. I bought from TW Member OCTaco here.
    Little over $100. More responsive pedal feel, especially during hard braking.
    Also Bleed your brakes. Have seen recommendation, once a year.
    Have Brake fluid completely flushed and replaced, it degrades with time. Especially if it's never been done.
    Also, if I've got the figures right, 12 years old and 44,000 miles.
    If it sits for a couple weeks, you'll develop rust on the rotors and if you don't feather your brakes when you first start off,
    you'll embed the rust into the pads, in turn grinding down your rotors with the rust.
    I have a 2000 Toyota Solara with 32,000 mi. Learned by experience.
    And my thoughts on your question, low pedal, brake fluid. The Rotor wear is gonna happen.
    Rusty Rotors accelerates it.
    CC
