Front Brakes for 3rd Gen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BlueOverTaco, Jun 16, 2020.
  1. Jun 16, 2020 at 8:10 PM
    BlueOverTaco
    BlueOverTaco [OP] Member
    Jeremiah
    Belmont, NC
    2018 Blue Pearl Taco TRD Sport
    That’s the truth!
  2. Jun 16, 2020 at 8:11 PM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    Are your brakes squealing? Stock pads have a squealer on them.
    Also it's not hard to check yourself in your driveway with a few tools
  3. Jun 16, 2020 at 8:13 PM
    BlueOverTaco
    Jeremiah
    Belmont, NC
    No there’s no squeal at all, but it’s good to know that they’ve got a squealer. That’s why I was doubting the shop cuz I didn’t hear them at all, I mean, maybe a slightly spongey brake pedal but no difference in stopping power
  4. Jun 17, 2020 at 7:47 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    When it came time for brakes on my tundra i went with ebc drilled and slotted rotors with the stock toyota ceramic brake pads. Worked very well together seemed to last forever. Had 80k miles on them with still plenty of brake pad life left. The stock solid rotors were junk.
  5. Jun 17, 2020 at 8:14 AM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    I don't think you really NEED to change the pads yet. Did you look at them?
  6. Feb 26, 2021 at 3:06 PM
    PJ1779
    PJ1779 New Member
    Paul
    2019 Limited
    I smoked my rotors with only 30K absolute junk, now I have 38K and can’t deal with the pulsing and shaking when braking at highway speeds 60-80 MPH! Especially when people mention it while in my truck!
    Dealer told me to pound sand when I felt it around 22K, I’d like to hear the groups thoughts if drilled and or slotted are the way to go. Or swap them out with smooth, and toss them every time they warp which they will....
    CenCal805 likes this.
  7. Jan 30, 2022 at 10:02 PM
    Montanabc
    Montanabc Well-Known Member
    Anthony
    2019 Barcelona red tacoma sr5 4x4
    I'm having this same issue! My steering wheels shakes as well when I'm braking at high speeds! It's embarrassing having a new truck that acts like an older vehicle! Did you fix this problem already? If so what did you do to fix it?
  8. Jan 31, 2022 at 6:47 AM
    zoo truck
    None
    Imo, the stock brake system is decent on these tacoma's far better than my 2001 tundra, and i've use the truck towing loads under 2k lbs. without a controller. At 15k miles the pads look barely used. Imo for most, they should last 40-50k miles easy.
  9. Jan 31, 2022 at 7:05 AM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I just replaced my stock brakes at 146k mi.
    shakerhood and ToyoTaco25 like this.
  10. Jan 31, 2022 at 9:31 AM
    Montanabc
    Anthony
    That's the thing I'm already at 60k miles so I'm thinking it's about time. I use my truck for mobile detailing so I pull a trailer with a 200 gallon tank of water every Saturday.
  11. Jan 31, 2022 at 2:06 PM
    dalemats
    dalemats Well-Known Member
    dale
    2017 Tacoma Limited 2WD
    2017 MGM Limited 2WD DCSB, bed mat, wheel, spare & tailgate locks, Gen 2 running boards, tri-fold cover, ShiftSense Pro v2, LED interior lights, Bracketeer fire extinguisher bracket, Pop & Lock power tailgate lock,
    I just put a second brake spring on the front caliper, no more rattling!
    You might consider this add.
  12. Jan 26, 2023 at 7:21 AM
    cragginshred
    cragginshred Well-Known Member
    Don Anderson
    2017 TRD Sport
    I'm at about 47 k and hearing a slight rumble/grind braking in the parking lot forward and back. I did go thru a lot of mud last week.
    jerrybear likes this.
  13. Jan 26, 2023 at 8:33 AM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    The brakes in the Tacoma are basically identical to a 2001 Tundra.
    Given the same type of pads, pad wear will be heavily dependent on vehicle loading and driving style. I typically get about 25,000 miles out of a set of pads on my IS350 and roughly 50,000 on the rotors. I probably get 2-3x that in the wife’s RX350. Different pads, but also different types of driving.
    Jeff
  14. Jan 26, 2023 at 8:34 AM
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    Powerstop Z36 Truck Pads would get my vote.
  15. Jan 26, 2023 at 8:47 AM
    #35
    cragginshred
    Don Anderson
    2017 TRD Sport
    I drove a lot of downhills in the mountains, that would wear them faster right? but 47k?
  16. Jan 26, 2023 at 9:06 AM
    #36
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    I guess for piece of mind, changing out at 40K~ isn't as stupid as some are suggesting. As repairs go, the cost is pretty minimal and since the front brakes do the heavy lifting with drums on the rear I can see this as a preventative measure. Speaking of rear drums, those will probably need replacing earlier.
    cragginshred likes this.
  17. Jan 26, 2023 at 9:09 AM
    #37
    jerrybear
    jerrybear Well-Known Member
    17 off-road
    went oem at 53000. could have gone a little further but i like to take advantage of when i do have the time to do it and its not over 110 degress; so there is that.
    if its close i just get it done at my convenience. i do tow and im in sandy and dusty conditions quite a bit so get some grinding from time to time from rocks and such. resurfaced rotors as well.
    so different strokes. nice to hear the distrust regarding dealerships. its well earned in most cases.
  18. Jan 26, 2023 at 9:10 AM
    #38
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    PFC Brakes
  19. Jan 26, 2023 at 10:34 AM
    #39
    zoo truck
    None
    Not my gen1 01 tundra brakes. I had the smaller size pads that year before Toyota sent the later 2001's out with similar ones as the tacoma. The rear drums, and shoes were the same. You couldn't get 20k out of the pads on that 01 tundra before they'd warp the rotors. They had a couple upgrades, one being doing the Land Cruiser brake installation for over $2k, or switch to an EBC drilled, and slotted rotor kit using the oem calipers, and pads. I did the later for about $350. It worked out great. No more warping rotors, and great pad life. I had over 75k miles and the pads were still decent.
    Jeff Lange[QUOTED] likes this.
  20. Jan 26, 2023 at 11:50 AM
    #40
    Jeff Lange
    Calgary, Canada
    Right, I did forget that the Tundra's brakes grew later that year.
    Jeff
