Front brakes locking-up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Levelland65, Oct 30, 2016.
  1. Oct 30, 2016 at 9:29 AM
    Levelland65
    Levelland65 [OP] Member
    Jeff
    Wimberley, TX
    Taco 4X4 LB
    I have a 2013 Tacoma 4X4 4-door with 118K miles.
    My set: 265 Nitto A/T tires, 2-1/2” lift — Bilstein 5100/OMU springs front and back, which was added when the truck had 16K miles. Last week I had two new tires put on at discount tire — both tires were put on the rear of the truck (I would have added four new tires but I’m hurting for cash). Soon after picking up my truck I began having very specific issues with braking. The issue only occurs when I am at a speed of 35-50 MPH and only on right hand corners with a slight downhill grade. As I enter the corner and start braking the front breaks seem to lock up and the truck lunges into oncoming traffic.
    This issue is dangerous and scary when it occurs and I hoping someone can help me with this issue.
  2. Oct 30, 2016 at 9:31 AM
    Paul123
    Paul123 Web-Wheeler
    Paul
    Reno
    2014 TRDOR pyrite mica, 3" lift 33's, 4.56’s
    You need to get your vsc reprogrammed at the dealer. Should cost maybe $100. Sometimes when you lift our trucks it throws the sensors out of wack and the vsc thinks you're gonna roll around corners. Pretty easy fix
  3. Oct 30, 2016 at 9:40 AM
    Levelland65
    Jeff
    Wimberley, TX
    Taco 4X4 LB
    Thanks Paul. As I read through the forums this seems to be very common. The weird part is that I started having this issue 100,000 miles after adding my lift. Most folks seem to have the issue soon after adding their lift. Really appreciate the quick feedback!
  4. Oct 30, 2016 at 9:58 AM
    Levelland65
    Jeff
    Wimberley, TX
    Taco 4X4 LB
    I forgot to add this (and not sure if it matters). The "issue" has always occurred during dry perfect conditions... no ice, wet/slippery or oily road surface
