Front brakes or rear?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bamahoyt, Jun 15, 2014.
  1. Jun 15, 2014 at 6:01 PM
    Bamahoyt
    Bamahoyt [OP] Well-Known Member
    Ted
    Knoxville, TN
    2014 TRD Sport DC LB 4x4
    So I had a problem with my e-brake sticking a little while ago and I noticed that when It would barely stick, when I hit 50-60mph I would get a vibration. I fixed the e-brake sticking situation but have noticed yesterday that I had a very similar vibration and it seems to be coming from the rear brakes because when I brake, it gets much worse. I was just wondering if seems like it would be the rear because I didn't know if there was something that could cause it in the rear like the front has (like warped rotors). Thanks for any advice. I also could not find a good write up for replacing rear drum brakes if someone might know where that is located. Thanks!
  2. Jun 15, 2014 at 6:27 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  3. Jun 16, 2014 at 8:57 PM
    electricjet
    electricjet Electricjet
    Tucson, AZ
    '01 Prerunner DC
    K&N, Magnaflow cats and exhaust. Electric fans.
    Does the extended cab have a drive shaft support bearing like the doublecab has? If so check the rubber holding the bearing if it is shot then the driveshaft can bounce around and cause a vibration that is felt in the seat as if it is coming from the rear. If you are driving an unloaded truck most of the time you are taxing the rear brakes very little.
    Pull the drums check all of the hardware and be sure nothing is broken. Adjust the shoes and try another drive. Worn shocks can also contribute to wheel hop and axle movement under braking.
  4. Jun 19, 2014 at 2:06 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Generally speaking if you feel the vibration in the steering wheel its the front. If you feel it in your seat, its the rear.
  5. Jun 20, 2014 at 12:38 PM
    VintageFast
    VintageFast Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    I converted to the Tundra brakes and my shake went away. Your rotors are probably warped.
