Front brakes seem too sensitive
Discussion in '1st Gen. Tacomas (1995-2004)' started by VintageFast, May 27, 2016.
  1. May 27, 2016 at 11:49 AM
    VintageFast
    VintageFast [OP] Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    Why is it that my front brakes seem too sensitive? I converted to Tundra brakes a couple of years ago and everything was great. Now the brakes seem too touchy and lock up quite a bit. The pads and rotors are fine. I'm running BFG AT 265 x 75 tires and they're about a year old.
  2. May 27, 2016 at 11:50 AM
    Aw9d
    Aw9d That one guy
    I'd bleed them and put in fresh fluid and see what happens.
  3. May 27, 2016 at 11:52 AM
    Clearwater Bill
    Billy
    Largo Florida
    When were the slider pins last serviced? You may not be getting full release, thus the calipers grab a bit sooner.
    When you say 'lock up', do you mean ABS activates?
  4. May 27, 2016 at 12:33 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Do pre-runners have a LSPV in the back? If so, then you can adjust that to apply more braking force to the rear.
  5. May 27, 2016 at 1:07 PM
    VintageFast
    Jim
    DFW, Texas
    02 Prerunner 3.4
    I don't have ABS. How do I adjust the LSPV?
  6. May 27, 2016 at 1:47 PM
    tan4x4
    Rick
    Folsom, CA
    The LSPV (Load Sensing Proportioning Valve) is a hydraulic valve attached to the frame. A horizontal (roughly) rod attached to it, goes up and down with the axle movement, to control the hydraulic pressure to the rear brake cylinders.
    More braking force goes to the rear brakes when more weight is added to the bed (which causes springs to compress and the axles get closer to the frame).
    This is a photo of the adjuster.
    Note the small bracket attached to the frame with 2 bolts.
    Note the verticle rod attached to it (threaded on top with 2 adjusting nuts).
    Mine is currently adjusted to raise the horizontal rod as much as it can (increasing force to the rear brakes).
  7. May 30, 2016 at 5:34 PM
    VintageFast
    Jim
    DFW, Texas
    02 Prerunner 3.4
    Got it. Made everything better. I read in another thread somewhere about if you lift you need to raise that part proportionate to your lift. I lifted 2". So I need to raise the accurator by 2". Marlin Crawler has a bracket.
  8. May 31, 2016 at 12:52 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    interesting how the lift was not mentioned in your brake problem .
  9. May 31, 2016 at 6:09 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
  10. May 31, 2016 at 7:19 AM
    tan4x4
    Rick
    Folsom, CA
    If you have a vise, and a drill, you could make your own bracket :D
  11. May 31, 2016 at 10:06 AM
    VintageFast
    Jim
    DFW, Texas
    02 Prerunner 3.4
    I do. And a bandsaw and 1/8" aluminum plate. I'm looking for a photo to get an idea of what I want to make.
  12. Jun 1, 2016 at 1:01 PM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    Heres mine
  13. Jun 1, 2016 at 1:01 PM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    I had the same problem on a 1993 Pickup. Part of the problem was the rear shoes wouldn't self adjust. Maybe I wasn't backing up enough ?
    Everything was lubed . I even replaced the star wheels.
  14. Jun 1, 2016 at 6:32 PM
    VintageFast
    Jim
    DFW, Texas
    02 Prerunner 3.4
    Thanks. I went to short on my bracket. I now need what I need to do. Here's what I did. At least I have rear brakes now. 20160601_194817.jpg
  15. Jun 1, 2016 at 6:41 PM
    VintageFast
    Jim
    DFW, Texas
    02 Prerunner 3.4
    I had no idea about the BPV. Nobody even mentioned it when you lift even 2". Toytec...Wheelers.. noone. Live and learn. I hope this thread can help someone with a similar situation.
  16. Jun 1, 2016 at 6:48 PM
    mlcc
    Oregon
    My kit came with the bpv bracket i actually didnt even know what it was as it wasnt even in the pics or instructions I had to search for information on what it was.
