Front brakes seized after wash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hank Heel, May 13, 2017.
  1. May 13, 2017 at 8:45 PM
    Hank Heel
    Hank Heel [OP] Well-Known Member
    WA
    Second time I've washed the truck since September, I should probably stop washing all together, nothing good comes out of it
    I remember this happening to another member, would like to know the outcome.
    Also they didn't seize per se, seems like a mechanical glitch in the hill assist, I felt the second it released, felt a thump in the brake pedal. My wife was next to me, she was disappointed in the new truck.
    Took 3 restarts and a bunch of cycling from reverse to drive, about 5 minutes to get it going.
    RustyTacoVT, LordIsGod and REDNECKTEX like this.
  2. May 13, 2017 at 8:47 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    It's normal in alot of vehicles. Happens to 2nd gens all the time.
    UrbanT@co and TheCookieMonster like this.
  3. May 13, 2017 at 8:49 PM
    cascadetaco
    cascadetaco Toyota Addict
    central oregon
    2017 SR 4cyl 4x4 5speed
    Normal? hmmm never happened in anything I have ever driven.
  4. May 13, 2017 at 8:52 PM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    There are tons of thread on this website about it. Use the search function.
    Joe23 and TheCookieMonster like this.
  5. May 13, 2017 at 8:53 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Never had it happen to me on any vehicle I have ever owned, washed my Tacoma this morning and didn't leave for 6 or 7 hours later and all was fine.
  6. May 13, 2017 at 8:54 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    I have washed my SR weekly since I got it and have not experienced this issue. Do you wash it and let it sit overnight?
    lynyrd3 and shakerhood like this.
  7. May 13, 2017 at 8:54 PM
    Hank Heel
    WA
    Never heard.
    I know that if the rotors are hot and your wash them, there's will be some adhesion within a caliper, but this wasn't it, this is brakes holding for whatever reason
  8. May 13, 2017 at 8:54 PM
    Optimaltaco
    Optimaltaco Well-Known Member
    Dave
    Cochrane, AB
    '17 Tacoma DCSB TRD Off-Road
    TRD Pro - Grill and Rear Tail-Lights OEM Roof Rack FN overland 17x8.5” -6 BFG KO2 Morimoto 2 stroke LED headlights 30” auxbeam light bar Custom built Canopy Readylift 3" spacer kit Deaver 1.5-2" AAL Amber hazard strobe lighting
    Never had anything like that happen to me, and I have washed the truck in below 0 Celsius weather.
  9. May 13, 2017 at 8:55 PM
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    I agree, I've driven a lot of different vehicles over a lot of years in a lot of different climates and that's never happened to me either. But now I own a taco so .....
    Nfarrall and shakerhood like this.
  10. May 13, 2017 at 8:55 PM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Some member stated they had to put it on 4low to break the brakes free. Are you sure it wasn't that?
  11. May 13, 2017 at 8:56 PM
    shakerhood
    Southern Ohio
    In the other Threads the guys are claiming the Drums are Seized from washing, go figure.
    GPsevinSixx likes this.
  12. May 13, 2017 at 8:57 PM
    Hiluxski
    Ventura California
    What's causing this ? If it's a known issue and their are lots of threads on it what's the cause and what's the cure?
    ShemRahBuck likes this.
  13. May 13, 2017 at 8:58 PM
    Hank Heel
    WA
    I'm positive, I'm mechanically competent
  14. May 13, 2017 at 8:59 PM
    Hiluxski
    Ventura California
    That's so amazing, drum brakes have been around since brakes were invented. What did Toyota decide to do different ?
  15. May 13, 2017 at 9:05 PM
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    +1. Have never had anything of the sort happen with any vehicle I have ever owned.
    I always make sure to "pulse" the brakes when driving off after a wash to dry the pads/rotors a bit, but that's it.
  16. May 13, 2017 at 9:09 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    You think so huh?
    Hmm...
    shakerhood likes this.
  17. May 13, 2017 at 9:09 PM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Hank, what and where exactly did you direct water pressure? Just a regular wash and rinse? Nothing with open hood or direct spray into braking components?
    I've done all of the above mentioned with a pressure washer to wash mud off and luckily, didn't have this happen. Did a heavy mud rinse twice and one snow grime (ground volcanic rock) pressure wash. You've got us all concerned, especially if you're mechanically competent.
    Did you engage your parking brake? I use it all/ every time. Keeps cables free and the shoes adjusted properly also.
    Oldman808, 0210 and shakerhood like this.
  18. May 13, 2017 at 9:20 PM
    Hank Heel
    WA
    No pressure washer, no hood open, just regular wash and rinse with a garden hose.
    I also use my parking brake every time I park, so they're "conditioned"
    This wasn't rear brakes, this was front I'm sure of that
    Cazzwell likes this.
  19. May 13, 2017 at 9:33 PM
    GPsevinSixx
    Ros Angerus
    I'd check the ABS connectors at the rear axle and front spindles. Water intrusion might be making them behave strange since they are what controls/senses the pulsing of the traction aids.
    Those are the only things I can think of that could get wet and affect what you described. Next time you wash it, dry everything around the ABS connector areas externally and pop all the connectors off to see if you have any water intrusion. Factory may have popped the connectors on and tweaked the seals. It does happen.
    Hank Heel[OP] likes this.
  20. May 13, 2017 at 9:40 PM
    Hank Heel
    WA
    Thanks for the suggestion, I'll take a look
